WSF3087
N-Ch MOSFET
General Description
Product Summery
The WSF3087 is the highest performance trench
N-ch MOSFET with extreme high cell density ,
which provide excellent RDSON and gate
charge for most of the synchronous buck
converter applications .
BVDSS
RDSON
ID
30V
5.0mΩ
70A
Applications
The WSF3087 meet the RoHS and Green
Product requirement , 100% EAS
guaranteed with full function reliability
approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
TO-252 Pin Configuration
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Rating
Symbol
Parameter
VDS
Drain-Source Voltage
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=100℃
ID@TA=25℃
ID@TA=70℃
IDM
10s
Steady State
30
V
±20
V
1
70
A
1
60
A
Continuous Drain Current, VGS @ 10V
1
21
1
18
Pulsed Drain Current
Units
A
15
A
11
2
3
150
A
EAS
Single Pulse Avalanche Energy
232
mJ
IAS
Avalanche Current
41
A
51
W
PD@TC=25℃
4
Total Power Dissipation
4
PD@TA=25℃
TSTG
Storage Temperature Range
6
-55 to 175
W
TJ
Operating Junction Temperature Range
-55 to 175
2.0
Thermal Data
Symbol
Parameter
Max.
Unit
RθJA
Thermal Resistance Junction-ambient (Steady State)1
62
℃/W
RθJA
Thermal Resistance Junction-Ambient 1 (t ≤10s)
25
℃/W
2.8
℃/W
RθJC
www.winsok.tw
Typ.
1
Thermal Resistance Junction-Case
Page 1
Rev 2: May.2019
WSF3087
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.028
V/℃
5.0
6.0
8.0
9.5
VGS=10V , ID=30A
VGS=4.5V , ID=15A
mΩ
1.0
1.5
2.5
V
-6.16
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=30A
43
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.7
3.1
Ω
Qg
Total Gate Charge (4.5V)
Qgs
Gate-Source Charge
7.6
10.6
Qgd
Gate-Drain Charge
7.2
10.1
VGS(th)
Gate Threshold Voltage
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
VGS=VDS , ID =250uA
VDS=15V , VGS=4.5V , ID=15A
uA
nC
11
15.6
Rise Time
VDD=15V , VGS=10V , RG=3.3Ω
15
27
Turn-Off Delay Time
ID=15A
37.3
74.6
Fall Time
10.6
21.2
Ciss
Input Capacitance
2100
Coss
Output Capacitance
550
Crss
Reverse Transfer Capacitance
180
Min.
Typ.
Max.
Unit
55
mJ
Min.
Typ.
Max.
Unit
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=15V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.1mH , IAS=24A
Diode Characteristics
Symbol
Parameter
Conditions
1,6
IS
Continuous Source Current
ISM
Pulsed Source Current2,6
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=30A , dI/dt=100A/µs , TJ=25℃
30
A
155
A
1.3
V
25
nS
21
nC
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSF3087”相匹配的价格&库存,您可以联系我们找货
