SS52B THRU SS5200B
Reverse Voltage - 20 to 200 Volts
Forward Current - 5.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
Built-in strain relief,ideal for automated placement
0.185(4.70)
0.160(4.06)
High forward surge current capability
High temperature soldering guaranteed:
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.096(2.44)
0.084(2.13)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
Mechanical Data
0.220(5.59)
0.200(5.08)
Case: JEDEC DO-214AA/SMB molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.003 ounce, 0.095 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
VRRM
Maximum RMS voltage
Maximum DC blocking voltage
VRMS
VDC
SS52B
SS53B
SS54B
SS55B
SS56B
SS58B
SS510B SS5150B SS5200B
MDD
SS52B
MDD
SS53B
MDD
SS54B
MDD
SS55B
MDD
SS56B
MDD
SS58B
MDD
SS510B
MDD
SS5150B
MDD
SS5200B
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
UNITS
V
V
V
Maximum average forward rectified current
at TL(see fig.1)
I(AV)
5.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
150
A
Maximum instantaneous forward voltage at 5.0A
VF
0.55
IR
1.0
50
500
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
CJ
Typical thermal resistance (NOTE 2)
RJA
Operating junction temperature range
TJ
Storage temperature range
TSTG
0.70
0.85
0.3
25
300
50.0
-50 to +150
-50 to +150
V
mA
pF
℃/W
Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2 ”(5.0x5.0mm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
SS52B THRU SS5200B
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
6.0
5.0
4.0
3.0
2.0
1.0
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
10 2
SS510B -SS520B
10 1
T J =25°C
10 0
60
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
T J =25°C
Junction Capacitance (pF)
1
SS52B /SS54B
SS56B
SS58B /SS520B
0.1
1.0
1.5
500
100
SS52B /SS54B
S S 5 46F
B/S
- SSS552200FB
0.1
10
1
100
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
175
150
125
100
75
50
25
1000
2.0
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C / W)
Instaneous Forward Current (A)
T J =75°C
SS52B /SS56B
Case Temperature (°C)
Peak Forward Surage Current (A)
T J =100°C
10 3
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
SS52B THRU SS5200B
Packing information
unit:mm
P0
P1
Item
Symbol
Tolerance
SMB
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 50
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMB
13"
3,000
4.0
6,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
48,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Unit (inch)
Symbol
Unit (mm)
A
2.8
0.110
B
0.094
C
2.4
4.6
0.181
D
2.2
0.086
E
7.0
0.276
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SS5150B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.63792
- 50+0.51709
- 400+0.41135
- 800+0.40518
- 国内价格
- 5+0.85485
- 50+0.71458
- 150+0.64448
- 500+0.59179
- 3000+0.40396
- 6000+0.38290
- 国内价格
- 100+0.36047
- 1000+0.34182
- 国内价格
- 5+0.84950
- 50+0.71000
- 150+0.63940
- 500+0.58590
- 3000+0.40000
- 6000+0.37910
- 国内价格
- 5+0.77569
- 50+0.64841
- 600+0.53699
- 1200+0.52894
- 3000+0.36655
- 国内价格
- 1+0.39080
- 3000+0.34590
