WSP05N15
N-Ch MOSFET
General Description
Product Summery
The WSP05N15 is the highest performance
trench N-Ch MOSFET with extreme high
cell density,which provide excellent RDSON
and gate charge for most of the
synchronous buck converter applications .
BVDSS
RDSON
ID
150V
37mΩ
6A
Applications
The WSF05N10 meet the RoHS and Green
Product requirement , 100% EAS guaranteed
with full function reliability approved.
z Power Management for Boost Converters.
z Synchronous Rectifiers for SMPS.
z LED Backlighting.
Features
SOP-8 Pin Configuration
z Advanced high cell density Trench technology
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
150
V
VGS
Gate-Source Voltage
ID@Tc=25℃
ID@Tc=70℃
IDM
±25
V
1
6.0
A
1
4.8
A
24
A
mJ
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
2
3
EAS
Single Pulse Avalanche Energy
36
IAS
Avalanche Current
12
A
4
PD@TA=25℃
Total Power Dissipation
3.5
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-ambient
RθJC
1
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
1
Max.
Unit
70
℃/W
24
℃/W
Rev 2: Apr.2019
WSP05N15
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
150
V
Reference to 25℃ , ID=1mA
0.098
V/℃
VGS=10V , ID=6A
37
45
48
78
2.0
3.0
4.0
V
-5.52
mV/℃
VDS=80V , VGS=0V , TJ=25℃
10
VDS=80V , VGS=0V , TJ=55℃
100
VGS=0V , ID=250uA
VGS=6V , ID=2A
VGS=VDS , ID =250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=3A
6.2
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.5
3.2
Ω
Qg
Total Gate Charge (10V)
23
33
Qgs
Gate-Source Charge
6
Qgd
Gate-Drain Charge
9.9
VDS=50V , VGS=10V , ID=3A
uA
nC
5.5
21.6
Rise Time
VDD=30V , VGS=10V , RG=6Ω
27
48.6
Turn-Off Delay Time
ID=1A ,RL=30Ω.
56
112
Fall Time
24
48
Ciss
Input Capacitance
1160
1500
Coss
Output Capacitance
90
Crss
Reverse Transfer Capacitance
45
Min.
Typ.
Max.
Unit
mJ
Min.
Typ.
Max.
Unit
4.0
A
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=30V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.5mH , IAS=12A
30
Diode Characteristics
Symbol
IS
Parameter
Conditions
1,6
Continuous Source Current
2,6
ISM
Pulsed Source Current
VSD
Diode Forward Voltage2
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=4A , TJ=25℃
IF=6A , dI/dt=100A/µs , TJ=25℃
24
A
1.3
V
31
nS
50
nC
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WSP05N15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.88750
- 10+2.72250
- 30+2.39250
- 100+2.14500
- 500+1.98000
- 1000+1.86450
