ES2J-SMB
ES2J-SMB
    GOODWORK(固得沃克)
    SMB(DO-214AA)
    二极管配置:独立式 直流反向耐压(Vr):600V 平均整流电流(Io):2A 正向压降(Vf):1.7V@2A 反向电流(Ir):5μA@600V 反向恢复时间(trr):35ns 工作温度:-65...
ES2J-SMB 数据手册
ES2A ES2J THRU 2.0 AMP SURFACE MOUNT SUPER FAST RECTIFIERS VOLTAGE RANGE 50 to 600 Volts CURRENT 2.0 Amperes FEATURES * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * Low forward voltage drop DO-214AC(SMA) .110(2.79) .100(2.54) .058(1.47) .052(1.32) MECHANICAL DATA .177(4.50) .157(3.99) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 0.063 grams .012(0.31) .006(0.15) .087(2.20) .071(1.80) .005 MAX. (.127) .205(5.20) .189(4.80) .060(1.52) .030(0.76) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current ES2A 50 35 50 ES2B ES2C ES2D ES2E ES2G ES2J UNITS 100 70 100 150 105 150 .375"(9.5mm) Lead Length at Ta=55 C Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 2.0A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Ta=100 C Maximum Reverse Recovery Time (Note 1) Typical Junction Capacitance (Note 2) Operating and Storage Temperature Range TJ, TSTG 200 140 200 300 210 300 400 280 400 600 420 600 A 2.0 60 1.25 0.95 V V V 1.70 A V 5.0 500 35 nS 60 -65 +150 pF C NOTES: 1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (ES2A THRU ES2J) FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE FIG.1- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTIC trr 10W NONINDUCTIVE ( ) D.U.T. 25Vdc (approx.) | | | | | | | | +0.5A (+) PULSE GENERATOR (NOTE 2) ( ) AVERAGE FORWARD CURRENT,(A) 50W NONINDUCTIVE 0 -0.25A (+) 1W NONINDUCTIVE OSCILLISCOPE (NOTE 1) -1.0A NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF. 1cm 2. Rise Time= 10ns max., Source Impedance= 50 ohms. 2.4 2.0 1.6 Single Phase 1.2 Half Wave 60Hz Resistive Or Inductive Load 0.8 0.375"(9.5mm) Lead Length 0.4 0 SET TIME BASE FOR 0 25 50 FIG.3-TYPICAL FORWARD FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS D 2J ES 2E 1.0 2G ES 3.0 -ES 2A -E REVERSE LEAKAGE CURRENT, (mA) S2 10 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 .01 125 150 175 .4 .6 .8 1.0 1.2 1.4 1.6 10 3.0 1.0 Tj=100 C Tj=25 C 0.1 .01 1.8 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) FORWARD VOLTAGE,(V) FIG.6-TYPICAL JUNCTION CAPACITANCE FIG.5-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 175 100 JUNCTION CAPACITANCE,(pF) PEAK FORWARD SURGE CURRENT,(A) 100 50 ES INSTANTANEOUS FORWARD CURRENT,(A) 50 75 AMBIENT TEMPERATURE,( C) 50 / 10ns / cm 80 60 Tj=25 C 8.3ms Single Half Sine Wave 40 JEDEC method 20 150 125 100 75 50 25 0 0 1 5 10 NUMBER OF CYCLES AT 60Hz 50 100 .01 .05 .1 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) REV 1.0 2015 JAN PAGE:2/2
ES2J-SMB 价格&库存
很抱歉,暂时无法提供与“ES2J-SMB”相匹配的价格&库存,您可以联系我们找货
