WST2314
N-Channel MOSFET
General Description
Product Summery
The WST2314 is the highest performance trench
N-ch MOSFET with extreme high cell density ,
which provide excellent RDSON and gate charge
for most of the small power switching and load
switch applications.
BVDSS
RDSON
ID
20V
26mΩ
5.5A
Applications
The WST2314 meet the RoHS and Green
Product requirement with full function reliability
approved.
z High Frequency Point-of-Load Synchronous
Small power switching for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
SOT-23-3L Pin Configuration
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
V
VGS
Gate-Source Voltage
±12
V
1
5.5
A
1
4.5
A
A
Total Power Dissipation
1.2
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
ID@TC=25℃
ID@TC=70℃
IDM
PD@TA=25℃
Continuous Drain Current, VGS @ 4.5V
Pulsed Drain Current
2
3
Thermal Data
Symbol
Parameter
Typ.
RθJA
Thermal Resistance Junction-ambient
RθJC
1
www.winsok.tw
1
Thermal Resistance Junction-Case
Page 1
Max.
Unit
125
℃/W
85
℃/W
Rev:1.0 May.2019
WST2314
N-Channel MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
Gate Threshold Voltage
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
V
Reference to 25℃ , ID=1mA
0.022
V/℃
VGS=4.5V , ID=4A
26
32
VGS=2.5V , ID=3A
40
48
0.5
0.7
1.4
V
-2.33
mV/℃
VDS=16V , VGS=0V , TJ=25℃
1
VDS=16V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=5A
18
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.5
3
Ω
9.5
13
1.6
2.0
Qg
Total Gate Charge (4.5V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
3.0
3.8
Turn-On Delay Time
3.3
8.2
Td(on)
VDS=15V , VGS=4.5V , ID=5A
uA
nC
Rise Time
VDD=10V , VGS=4.5V ,
4.6
10
Turn-Off Delay Time
RG=6.0Ω ID=5A
25
42
Fall Time
4.0
7.2
Ciss
Input Capacitance
854
1045
Coss
Output Capacitance
95
102
Crss
Reverse Transfer Capacitance
69
78
Min.
Typ.
Max.
Unit
5.5
A
A
1.2
V
14.5
25
nS
8.4
14
nC
Tr
Td(off)
Tf
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
ISM
Parameter
Continuous Source Current1,4
2,4
Pulsed Source Current
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=5A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST2314”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32000
- 50+0.29600
- 200+0.27600
- 600+0.25600
- 1500+0.24000
- 3000+0.23000
- 国内价格
- 10+0.49238
- 100+0.39388
- 300+0.34474
- 3000+0.30780
- 6000+0.27821
- 9000+0.26342
