WST3400A
N-Ch MOSFET
Product Summery
General Description
The WST3400A is the highest performance
trench N-Ch MOSFET with extreme high cell
density , which provide excellent RDSON and
gate charge for most of the small power
switching and load switch applications.
BVDSS
RDSON
30V
20mΩ
ID
6.4A
Applications
The WST3400A meet the RoHS and Green
Product requirement with full function
reliability approved.
z High Frequency Point-of-Load Synchronous s
Small power switching for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
SOT-23-3L Pin Configuration
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Rating
Symbol
Parameter
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
±12
V
ID@Tc=25℃
ID@Tc=70℃
IDM
PD@TA=25℃
10s
Units
1
7.7
6.4
A
1
6.2
5.4
A
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
Steady State
2
A
23
3
1.32
1
W
3
0.84
0.64
W
Total Power Dissipation
PD@TA=70℃
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
RθJA
RθJA
RθJC
www.winsok.tw
Parameter
Thermal Resistance Junction-ambient
1
1
Thermal Resistance Junction-Ambient (t ≤10s)
1
Thermal Resistance Junction-Case
Page 1
Typ.
Max.
Unit
125
℃/W
95
℃/W
80
℃/W
Rev:1.0 May.2019
WST3400A
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
△VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
VGS(th) Temperature Coefficient
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
Reference to 25℃ , ID=1mA
0.025
V/℃
VGS=4.5V , ID=5A
VGS=2.5V , ID=4A
28
46
0.5
0.8
1.2
V
-4.8
mV/℃
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
VGS=VDS , ID =250uA
mΩ
uA
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=5A
7
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.5
5
Ω
Qg
Total Gate Charge (4.5V)
5.8
8.4
Qgs
Gate-Source Charge
2.4
3.5
Qgd
Gate-Drain Charge
2.0
2.9
Td(on)
VDS=15V , VGS=4.5V , ID=5A
2.3
4.8
Rise Time
VDD=15V , VGS=10V , RG=3.3Ω
7.6
14
Turn-Off Delay Time
ID=5A
21
44
Fall Time
3.8
8
Ciss
Input Capacitance
520
880
Coss
Output Capacitance
72
112
Crss
Reverse Transfer Capacitance
56
91
Min.
Typ.
Max.
Unit
1.8
A
22
A
1.2
V
18
nS
3
nC
Tr
Td(off)
Tf
Turn-On Delay Time
nC
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
Parameter
Conditions
1,4
IS
Continuous Source Current
ISM
Pulsed Source Current2,4
2
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=5A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST3400A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.28930
- 200+0.18700
- 1500+0.16280
- 3000+0.14410
- 国内价格
- 10+0.34787
- 100+0.28307
- 300+0.25067
- 3000+0.20747
- 6000+0.18803
- 9000+0.17820
- 国内价格
- 10+0.17663
- 50+0.16312
- 200+0.15188
- 600+0.14062
- 1500+0.13162
- 3000+0.12600
