SS310F
SS32F
THRU
3.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
20 to 100 Volts
CURRENT
3.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
SMAF
.146(3.7)
.130(3.3)
.063(1.6)
.051(1.3)
MECHANICAL DATA
.193(4.9)
.173(4.4)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
.008(0.20)
.005(0.12)
.047(1.20)
.035(0.90)
.106(2.7)
.094(2.4)
.047(1.2)
.031(0.8)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
SS32F
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SS33F
SS34F
SS35F SS36F
30
21
30
40
28
40
50
35
50
At TL=100 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
SS39F
80
56
80
90
63
90
80
0.55
0.85
0.70
0.2
Ta=100 C
10
-65
+125
-65
-65
+150
SS310F UNITS
100
70
100
V
V
V
A
3.0
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 3.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJL (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
SS38F
60
42
60
+150
A
V
mA
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (SS32F THRU SS310F)
FIG.2-TYPICAL FORWARD
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
80
100
120
140
160
180
200
LEAD TEMPERATURE ( C)
PEAK FORWAARD SURGE CURRENT,(A)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
36
F
~S
S3
4
F
32
31
0F
~S
S
S
~S
F
60
38
F
10
40
F
S3
4F
-S
S3
SS
F
-S
0.5
SS
35
F
1.0
10
SS
SS
32
1.5
INSTANTANEOUS FORWARD CURRENT,(A)
2.0
F
50
2.5
SS
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
100
.01
80
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
60
8.3ms Single Half
Tj=25 C
Sine Wave
40
JEDEC method
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
1
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
700
600
500
400
300
200
10
1.0
Tj=75 C
.1
Tj=25 C
100
.05
.1
.5
1
REVERSE VOLTAGE,(V)
5
10
50
100
.01
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SS34F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.21714
- 300+0.17597
- 1200+0.15307
- 国内价格
- 1+0.41690
- 200+0.13970
- 1500+0.08679
- 3000+0.06886
- 国内价格
- 20+0.23688
- 200+0.19197
- 600+0.16699
- 3000+0.13589
- 9000+0.12296
- 24000+0.11596
