MH254V-11-40-1196
MH254V-11-40-1196
    XFCN(台湾兴飞)
    插件,P=2.54mm
    排针 1x40P 间距:2.54mm 圆针 直插
MH254V-11-40-1196 数据手册
Technical Data Materlal: Pin(outer sleeve):Brass,machined CuZn38Pb2 Plating(outer sleeve): Tin Plated:2 μm/80μm"NI,5μm/200μ"Sn Gold Plated:2 μm"/80μm"Ni,0.8μ" gold Insuiator:PPS UL94V-0 Electrical: Current rating:3Amps/contact max. Contact resistance:≤4m Ω/contact Insuiation resistance:≥1000M Ω at V=100V Dleiectric Withstanding Voltage:1000V AV Min Operaling voitage:60VAC/DC Mechanical: Operaling temperature:-40°C to+105°C Soldering temperature:+255°C Critical Dimensions: * P.C.B LAYOUT 2.54mm Machined Pin Header MH254V-11-XX-1196
MH254V-11-40-1196 价格&库存
很抱歉,暂时无法提供与“MH254V-11-40-1196”相匹配的价格&库存,您可以联系我们找货
MH254V-11-40-1196
    • 1+6.22782
    • 10+5.07870
    • 30+4.50414
    • 100+3.92958
    • 500+3.59100
    • 1000+3.41658
    库存:1384
    MH254V-11-40-1196
    • 1+4.47810
    • 50+3.88100
    • 100+3.73170
    • 500+3.58250
    • 1000+3.52280
    库存:100
    MH254V-11-40-1196
    • 1+2.83550
    库存:570
