WST6066A
N-Ch MOSFET
Product Summery
General Description
The WST6066A is the highest performance trench
N-ch MOSFETs with extreme high cell density ,
which provide excellent RDSON and gate charge
for most of the synchronous buck converter
applications .
BVDSS
RDSON
60V
110mΩ
ID
2.1A
Applications
The WST6066A meet the RoHS and Green
Product requirement , 100% EAS guaranteed
with full function reliability approved.
z High Frequency Point-of-Load Synchronous
Buck Converter for MB/NB/UMPC/VGA
z Networking DC-DC Power System
Features
z Load Switch
z Advanced high cell density Trench technology
SOT-23-3L Pin Configuration
z Super Low Gate Charge
z Excellent CdV/dt effect decline
z 100% EAS Guaranteed
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
VDS
VGS
ID@TC=25℃
ID@TC=70℃
IDM
Rating
Units
Drain-Source Voltage
60
V
Gate-Source Voltage
±20
V
1
2.1
A
1
1.5
A
10
A
Continuous Drain Current, VGS @ 10V
Pulsed Drain Current
2
3
EAS
Single Pulse Avalanche Energy
15
mJ
IAS
Avalanche Current
21
A
Total Power Dissipation
1.25
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
PD@TA=25℃
4
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient
RθJC
1
www.winsok.tw
Thermal Resistance Junction-Case
Page 1
1
Typ.
Max.
Unit
125
℃/W
25
℃/W
Rev:1.0 May.2019
WST6066A
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Conditions
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
VGS(th)
Static Drain-Source On-Resistance2
Gate Threshold Voltage
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
55
V
Reference to 25℃ , ID=1mA
0.041
V/℃
VGS=4.5V , ID=2.1A
85
110
VGS=2.5V , ID=1.5A
95
120
1.0
1.5
2.5
V
-4.7
mV/℃
VDS=44V , VGS=0V , TJ=25℃
1
VDS=44V , VGS=0V , TJ=85℃
5
VGS=VDS , ID =250uA
mΩ
△VGS(th)
VGS(th) Temperature Coefficient
IDSS
Drain-Source Leakage Current
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=4A
10
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2.5
5
Ω
Qg
Total Gate Charge (10V)
2.1
3.9
Qgs
Gate-Source Charge
0.6
Qgd
Gate-Drain Charge
0.8
VDS=27V , VGS=4.5V , ID=2.1A
uA
nC
3.6
Rise Time
VDD=27V , VGS=10V , RG=6Ω
3.5
Turn-Off Delay Time
ID=1A
32
Fall Time
3
Ciss
Input Capacitance
295
Coss
Output Capacitance
40
Crss
Reverse Transfer Capacitance
15
Min.
Typ.
Max.
Unit
15.2
mJ
Min.
Typ.
Max.
Unit
1
A
4
A
1.2
V
10.1
nS
6.4
nC
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=15V , VGS=0V , f=1MHz
ns
pF
Guaranteed Avalanche Characteristics
Symbol
EAS
Parameter
Conditions
5
VDD=25V , L=0.1mH , IAS=15A
Diode Characteristics
Parameter
Symbol
Conditions
1,6
IS
Continuous Source Current
ISM
Pulsed Source Current2,6
VSD
Diode Forward Voltage2
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
VG=VD=0V , Force Current
VGS=0V , IS=1A , TJ=25℃
IF=4A , dI/dt=100A/µs , TJ=25℃
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper,t
很抱歉,暂时无法提供与“WST6066A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.62000
- 50+0.57200
- 200+0.53200
- 600+0.49200
- 1500+0.46000
- 3000+0.44000
- 国内价格
- 1+0.78980
- 200+0.54450
- 1500+0.49500
- 3000+0.46200
- 国内价格
- 5+1.04267
- 50+0.84671
- 150+0.76273
- 500+0.65795
- 3000+0.53353
- 6000+0.50544
