PD-151
PD-151
    PRO'SKIT(宝工)
    电子数显卡尺 工业级高精度游标卡尺 PD-151 品牌:Pro’skit/宝工型号:PD-151材质:不锈钢 产地:中国大陆
PD-151 数据手册
 1. PD-151 6” ELECTRONIC CALIPER OPERATING INSTRUCTIONS  TECHNICAL SPECIFICATIONS Measuring range:0~150mm/0~6". Resolution:0.01mm/0.0005". Accuracy:±0.02mm/0.001"(<100mm), ±0.03mm/0.001"(>100mm). Repeatability:0.01mm/0.0005". Max.measuring speed:1.5m/sec.,60"/sec. Measuring system:Linear capacitive measuring system. Display:LCD display. Power:1pc silver oxide battery LR44 (1.5V) Capacity:Appr. 165mAh Working temperatuer:5~40 ℃/41~104 ℉. Influence of humidity:Not important under 80% of relative humidity.  1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. PRODUCT DESCRIPTION Internal measuring jaws Metric/Inch change button(mm/inch) Locking screw LCD display External measuring jaws Power on /off button(ON/OFF) Zero setting(ZERO) Battery cover Depth measuring blade Step-measuring faces Data hold button(HOLD) 2. OPERATION Preparations: 1.1. Slider can be moved after the locking screw (No.3 item of the Nomenclature) is loosened. 1.2. Wipe clean all the measuring faces and caliper bar.No organic solutions are allowed. 1.3. Check to see if all the buttons, switches and LCD display respond well. C. 4. In order to save power, turn off the unit when caliper is going to stay idle for some time. Never apply any electric pressure on any part of the caliper and never use an electric pen for the fear of damaging its chip. For other notes please refer to the conventional calipers. Accidental wrong display may happen while replacing the battery Just take out the battery and then put it in again after more than 30 seconds until the display returns to normal. 5. 6. D. Basic measuring methods: 2.1. Loosen the locking screw. 2.2. Switch the unit on by pressing “ON/OFF” button, or move caliper slider for auto power on, then select the unit by pressing “mm/inch” button. (Each time the button is pressed, inch and metric digits will be displayed alternatively.) 2.3. Apply normal measuring pressure on slider to close the esternal. 2.4. Press Date hold(HOLD) button to keep measureing data in record. 2.5. Press “ON/OFF” button for power off. or the power will auto off when not in use for 5 minutes. A. Measurements of internal dimensions. B. Measurements of depth. Measurement of steps. 7.  E. Differential method of measurement. (Application of zero setting.) Measurements of external dimensions  1. 2. 3. MAINTENANCE Clean caliper bar with dry cotton fabrics before using in order to avoid mad display of caliper caused by humidity. Keep the caliper clean and dry. (Liquid can damage the slider.) Faces should be cleaned gently with cotton fabrics. Never use petrol, acetone and other organic solutions. BATTERY REPLACEMENT When the numbers on LCD display are not clear, take off the battery cover in the direction shown by the arrow and replace the battery. (positive side facing out.)  TROUBLE SHOOTING Failure Cause Solution The numbers on LCD display are not clear Display doesn't change when the slider is moved. Less accurate than specified but with –in ± 0.1mm. Battery voltage lower than 1.0V. Replace the battery. Accidental trouble in circuit. Take out battery and reset it after 30 sec. Dirt in the sensor. No display on LCD. 1. Battery in poor contact. Remove slider cover and it’s assembly, clean face of sensor with clean compressed air (5kg/cm2). 1. Remove battery cover and adjust the battery seat, keep good connection. 2. Replace battery. 2. Battery voltage under 1.0V. 1. PD-151 數位游標卡尺 操作說明書  技術規格 測量範圍:0~150mm/0~6". 解析度:0.01mm/0.0005". 精確度:±0.02mm/0.001"(<100mm), ±0.03mm/0.001"(>100mm). 反復精確度:0.01mm/0.0005". 最快測量速度:1.5米/每秒,60英吋/每秒. 測量系統:線性電容式測量系統. 顯示器:LCD液晶顯示器. 電源:1個水銀電池 LR44 (1.5V). 電池容量:大約 165mAh. 工作溫度:5~40 ℃/41~104 ℉. 溼度的影響:在相對濕度80%以下,並不重要.  1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 各部位名稱 內徑測量爪 公/英制(mm/inch)切換按鈕 鎖緊螺絲 LCD液晶顯示器 外徑測量爪 電源開/關(ON/OFF)按鈕 歸零(ZERO)按鈕 電池蓋 深度測量桿 台階測量面 資料保持(HOLD)按鈕 2. 操作前準備: 1.1. 旋鬆鎖緊螺絲(如.各部位名稱的 NO.3),才能開始滑動游標卡尺。 1.2. 清潔擦拭尺面、測量爪和滑桿。不 可使用具有腐蝕性的溶劑。 1.3. 檢查各按鈕開關和LCD液晶顯示 器,是否反應正常? C. 基本測量方法: 2.1. 旋鬆鎖緊螺絲。 2.2. 按壓” 電源開關(ON/OFF)”或滑動 游標卡尺,將啟動電源。然後選擇 單位,切換”公/英制(mm/inch)”按 鈕;每按一次”公/英制(mm/inch)”按 鈕,公制和英制數字將交替顯示。 2.3. 施以適當的壓力在滾輪上,使外徑 測量爪閉合;然後按”歸零按鈕 (ZERO)”,使數值顯示”零”。 2.4. 按壓”資料保持按鈕(HOLD)”,使測 量數值紀錄。 2.5. 按壓” 電源開關(ON/OFF)”,關閉 電源。或是未操作,超過5分鐘後,自動 關閉電源。 D. A. 尺的電子零件上,避免損壞芯片。 對於其他注意事項,請同時參閱一般的游 標卡尺注意原則。 更換電池時,可能會產生錯誤的顯示。請 取下電池後,稍待一會兒,超過30秒以後 再裝入電池,直到正常顯示為止。 深度測量 6. 7. 台階測量  電池更換 當LCD字體顏色變淡時,依箭頭指示方 向,取下電池蓋,更換電池。(正極面朝 上,放入電池)  E. 用差分法測量(歸零設定的應用) 內徑測量 故障排除 故障現象 當LCD字體 顏色變淡時 當滑動游標 卡尺時,顯示 數值不會改 變時 比技術規格 不準確,但在 ± 0.1mm內 時 LCD液晶顯 示器,不顯示 時 B. 可能原因 電池電力低 於1.0V。 可能是電路 故障。 排除方法 更換新電池。 取下電池,在 30秒後重新裝 入電池。 感測器上有 汙垢。 取下滑動蓋和 相關零件,用 5kg/cm2的氣 壓,清潔感測 器的表面。 1. 電池接觸 1. 取下電池蓋 不良。 和調整電池 2. 電池電壓 座,使電池 低於1.0V。 接觸良好。 2. 更換新電 池。 外徑測量  1. 2. 3. 4. 5. 寶工實業股份有限公司 產品維護說明 清潔游標卡尺應使用乾燥的棉織品擦 拭,避免溼氣所產生的錯誤顯示。 經常保持游標卡尺清潔和乾燥。(液體會導 致滑軌損壞) 尺面可以用棉織物輕輕的進行清潔,請勿 使用汽油、丙酮…等有機溶劑。 當不用時,請關閉電源,以節省電力。 不要使用任何的電壓和電筆,在這游標卡 PROKIT’S INDUSTRIES CO., LTD. http://www.prokits.com.tw E-mail:pk@mail.prokits.com.tw © 2017 Prokit’s Industries Co., LTD. All rights reserved 2017001(C)
PD-151
1. 物料型号:ProsKit PD-151 数位游标卡尺。 2. 器件简介:文档提供了数位游标卡尺的操作说明和技术指标。 3. 引脚分配:文档没有提及引脚分配,因为这是关于测量工具的文档。 4. 参数特性: - 测量范围:0~150mm/0~6"。 - 解析度:0.01mm/0.0005"。 - 精度:±0.02mm/0.001"(<100mm), ±0.03mm/0.001"(>100mm)。 - 重复精度:0.01mm/0.0005"。 - 最大测量速度:1.5米/秒,60英寸/秒。 - 测量系统:线性电容式测量系统。 - 显示:LCD显示屏。 - 电源:1节银氧化电池 LR44 (1.5V)。 - 电池容量:约165mAh。 - 工作温度:5~40℃/41~104℉。 - 湿度影响:在相对湿度80%以下不重要。 5. 功能详解:介绍了基本测量方法、电池更换、故障排除和维护说明。 6. 应用信息:适用于内部尺寸、外部尺寸、深度、台阶和差分法测量。 7. 封装信息:文档中没有提及封装信息,因为这是操作手册,不是电子元件数据手册。
PD-151 价格&库存
很抱歉,暂时无法提供与“PD-151”相匹配的价格&库存,您可以联系我们找货
