MT-2017
MT-2017
    PRO'SKIT(宝工)
    Tool
    保护功能模拟万用表
MT-2017 数据手册
MT-2017 Protective Function Analog Multimeter User’s Manual st , 1 Edition 2015 ©2015 Copyright by Prokit’s Industries Co., Ltd. INTRODUCTION This Multi-meter is an accurate, safe handheld meter that comes with robust protective holster alongside, built-in stand and hook-up design. MT-2017 is powered by batteries, offers accurate, reliable measurement of DC/AC Voltage, +/-DCV, DC Current, Resistance and Diode, LED, Transistor, Decibels, Continuity test and Capacitance with very high sensitivity quality movement. This meter is designed with double-sided glass-epoxy PCB, full overload & misused protection via two Fuses, Oxide Varactor & Diodes, as well as mirrored Aluminum dial plate. Ideal for indoor use in the laboratory, school, workshop, hobby and home applications. SPECIFICATION Safety Category: IEC61010-1, CAT II 1000V, CAT III 500V and Pollution Degree 2. Common Environment: 23C5C, less than 75% RH. Operating temperature: 0C to 40C, 32 F to 104 F Storage temperature: -10 C to 50C, 14 F to 122F Operating Humidity Scope: less than 90% RH. Storage Humidity Scope: less than 80% RH. Dimensione: 171(W) x 108(D) x 37(H) MM Weight: 390g approx. (including batteries 3pcs) Accessories: One pair of test leads; Two Spare Fuses: 0.5A/250V & 10A/250V, Φ5x20mm Test Functions DC V Range Accuracy Remarks 0-0.1-2.5-10-50250 V-1000V  3% FSD.  4% FSD. For 1000V Null DCV ±-5V, ±25V  5% FSD. AC V 0-10-50-250V -1000V  4% FSD.  5% FSD. Input Impedance: 20KΩ /V Overload Protection: Max. 1000V AC/DC BUT 0.1V/2.5V/10V 250V Max. Input Impedance: 40KΩ /V Overload 1000V Max. Input Impedance: 9KΩ /V Overload 1 For 1000V DC mA 0-0.05-2.5-25-25 0 mA, 10A  3% FSD.  4% FSD. For 10A Ω X 1: 0.2 ~ 2KΩ Midscale at 20Ω X 10: 2 ~ 20KΩ Midscale at 200Ω X 100: 20 ~ 200KΩ Midscale at 2000Ω X1K: 200~ 2MΩ Midscale at 0KΩ X10K: 2K ~20MΩ Midscale at 200KΩ C: 2,000uF Max. .  4% of ARC of Scale Length Protection: Max. 1000V AC/DC But 10V/50V only 250V Max. Band width: 40 ~10K Hz Drop Voltage: 250 mV Overload protected by Fuses 0.5A/250V & 10A / 250V at 10A range, and Oxide Varactor.
MT-2017 价格&库存
很抱歉,暂时无法提供与“MT-2017”相匹配的价格&库存,您可以联系我们找货
MT-2017
    • 1+116.60000
    库存:5
