10A10
10A10
    MDD(辰达半导体)
    R-6
    整流二极管 1KV 10A R-6
10A10 数据手册
10A05 THRU 10A10 Reverse Voltage - 50 to 1000 Volts Forward Current - 10.0 Ampere GENERAL PURPOSE SILICON RECTIFIER Features R-6  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Construction utilizes void-free molded plastic technique  Low reverse leakage 1.0 (25.4) MIN. 0.360 (9.1) 0.340(8.6)  High forward surge current capability  High temperature soldering guaranteed: DIA. 250°C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension 0.360(9.1) 0.340(8.6) Mechanical Data 1.0 (25.4) MIN. Case : JEDEC R-6 Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.072 ounce, 2.05 grams 0.052 (1.3) 0.048 (1.2) DIA. Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current 0.375”(9.5mm) lead length at TA=60°C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 10.0A Maximum DC reverse current TA=25°C at rated DC blocking voltage TA=100°C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction and storage temperature range VRRM VRMS VDC MDD MDD MDD MDD MDD MDD MDD 10A05 10A1 10A2 10A4 10A6 10A8 10A10 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 UNITS V V V I(AV) 10.0 A IFSM 400 A VF 1.0 10.0 100 V IR CJ RθJA TJ,TSTG 150 10.0 -55 to +150 μA pF °C/W °C Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted http://www.microdiode.com Rev:2024A3 Page :1 10A05 THRU 10A10 Reverse Voltage - 50 to 1000 Volts Forward Current - 10.0 Ampere FIG. 1- FORWARD CURRENT DERATING CURVE 10 8 6 Single Phase Half Wave 60Hz Resistive or inductive Load 4 2 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 400 320 240 160 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 80 175 0 1 AMBIENT TEMPERATURE, C NUMBER OF CYCLES AT 60 Hz 200 100 10 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.1 0.5 0.7 0.9 1.1 1.3 1.4 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 1 1,000 TJ=150 C 100 10 0.1 TJ=25 C 0.01 0 20 40 60 80 100 2000 TJ=25 C 100 TRANSIENT THERMAL IMPEDANCE, C/W PERCENT OF PEAK REVERSE VOLTAGE,% FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF TJ=100 C 1 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 1000 100 10 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 10 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 t,PULSE DURATION,sec. The curve above is for reference only. http://www.microdiode.com Rev:2024A3 Page :2
10A10
物料型号:10A05至10A10
器件简介:这些是通用的硅整流器,具有塑料封装,符合UL 94V-0的可燃性分类,采用无空洞的模塑塑料技术。
引脚分配:文档中没有明确提供引脚分配信息,但提到了引脚长度和可焊性。
参数特性: - 最高重复峰值反向电压(VRRM):50至1000伏特 - 最大有效值电压(VRMS):35至700伏特 - 最大直流阻断电压(Voc):与VRRM相同 - 最大平均正向整流电流(I(AV)):10.0安培 - 峰值正向浪涌电流(IFSM):600安培(10A2 MDD 10A2型号) - 最大瞬态正向电压(VF):1.0伏特(10A1型号) - 最大直流反向电流(IR):10.0安培(25°C时)和100安培(100°C时) - 典型结电容(CJ):150皮法拉 - 典型热阻(RJA):10.0°C/W
功能详解:这些整流器设计用于承受高反向电压和高正向浪涌电流,适用于多种应用,包括电阻性或感性负载。
应用信息:适用于一般整流应用,具有高温度焊接保证,可在250°C下焊接10秒,引脚长度为0.375英寸(9.5mm),承受2.3kg的张力。
封装信息:JEDEC R-6模塑塑料体,引脚为可焊性镀锡,符合MIL-STD-750标准。
10A10 价格&库存
很抱歉,暂时无法提供与“10A10”相匹配的价格&库存,您可以联系我们找货
10A10
  • 5+0.87420
  • 50+0.72420
  • 200+0.51310
  • 500+0.45180
  • 2500+0.43040
  • 5000+0.41590
库存:10538
10A10
    • 5+0.79331
    • 50+0.66081
    库存:100
    10A10
      • 1+0.60060
      • 50+0.40040
      • 500+0.36190
      库存:4291
      10A10
      • 1+0.38430
      库存:1357
      10A10
      • 100+0.36047
      • 500+0.35425
      库存:520
