SL5N65F
SL5N65F
    SLKOR(萨科微)
    TO-220F
    MOS管 N-Channel VDS=650V VGS=±30V ID=5A RDS(ON)=2.8Ω@10V TO220F
SL5N65F 数据手册
SL5N65F N-Channel Power MOSFET ●Features: ■ 5.0A, 650V, RDS(on)(Typ) =2.4Ω@VGS=10V ■ Low Gate Charge ■ Low Crss ■ 100% Avalanche Tested ■ Fast Switching ■ Improved dv/dt Capability ●Application: ■ High Frequency Switching Mode Power Supply ■ Active Power Factor Correction Schematic diagram TO-220F Absolute Maximum Ratings(Tc=25C unless otherwise noted) Symbol Parameter VDSS ID IDM Value Unit Drain-Source Voltage 650 V Drain Current - Continuous(Tc=25C) - Continuous(Tc=100C) 5.0* A 3.1* A -Pulsed 20* A ±30 V Drain Current (Note1) VGSS Gate-Source Voltage EAS Single Pulsed Avalanche Energy (Note2) 245 mJ IAR Avalanche Current (Note1) 5.0 A EAR Repetitive Avalanche Energy (Note1) 10.5 mJ Peak Diode Recovery dv/dt (Note3) 4.5 V/ns dv/dt PD Power Dissipation(TC =25C) -Derate above 25°C 35 W 0.27 W/C Tj Operating Junction Temperature 150 C -55 to+150 C Max Unit Tstg Storage Temperature Range * Drain Current Limited by Maximum Junction Temperature. Thermal Characteristics Symbol Parameter RθJC Thermal Resistance,Junction to Case 3.57 C /W RθJA Thermal Resistance,Junction to Ambient 62.5 C /W www.slkormicro.com 1 SL5N65F Electrical Characteristics(Tc=25C unless otherwise noted) Symbol Parameter Test Conditons Off Characteristics BVDSS Drain-source Breakdown Voltage VGS=0V ,ID=250μA △BVDSS /△TJ Breakdown Voltage Temperature Coefficient IDSS Zero Gate Voltage Drain Current Gate-Body Leakage Current,Forward IGSSF Gate-Body Leakage Current,Reverse IGSSR On Characteristics VGS(th) Gate Threshold Voltage RDS(on) Static Drain-Source On-Resistance gFS Forward Transconductance ID=250μA (Referenced to 25C) VDS=650V,VGS=0V VDS=520V,Tc=125C VGS=+30V, VDS=0V VGS=-30V, VDS=0V VDS= VGS, ID=250μA VGS=10 V, ID=2.5A VDS=40 V, ID=2.5A (Note4) Dynamic Characteristics Input Capacitance Ciss VDS=25V,VGS=0V, Output Capacitance Coss f=1.0MHz Reverse Transfer Capacitance Crss Switching Characteristics Turn-On Delay Time td(on) Turn-On Rise Time tr VDD = 325 V, ID = 5.0 A, RG = 25 Ω (Note4,5) Turn-Off Delay Time td(off) Turn-Off Fall Time tf Total Gate Charge Qg VDS = 520 V, ID =5.0 A, Gate-Source Charge Qgs VGS = 10 V (Note4,5) Gate-Drain Charge Qgd Drain-Source Diode Characteristics and Maximum Ratings Maximum Continuous Drain-Source Diode Forward Current IS Maximum Pulsed Drain-Source Diode Forward Current ISM Drain-Source Diode Forward Voltage VGS =0V,IS=5.0A VSD Reverse Recovery Time trr VGS =0V, IS=5.0A, d IF /dt=100A/μs (Note4) Reverse Recovery Charge Qrr Notes: 1、Repetitive Rating:Pulse Width Limited by Maximum Junction Temperature. 2、L = 25.0mH, IAS =5.0A, VDD = 50V, RG = 25 Ω, Starting TJ = 25C. 3、ISD≤5.0A, di/dt≤200A/μs, VDD≤BVDSS, Starting TJ = 25C. 4、Pulse Test : Pulse Width ≤300 µ s, Duty Cycle≤2%. 5、Essentially Independent of Operating Temperature. www.slkormicro.com 2 Min Typ Max Unit 650 -- -- V -- 0.65 -- V/C ----- ----- 1 10 100 -100 μA μA nA nA 2.0 -- -2.4 4.0 2.8 V Ω -- 3.6 -- S ---- 568 63 11 ---- pF pF pF -------- 29 73 58 53 13 4.1 4.9 -------- ns ns ns ns nC nC nC ------ ---325 2.65 5.0 20 1.4 --- A A V ns μC SL5N65F On-Regin Characteristics Transfer Characteristics On-Resistance Variation vs. Drain Current and Gate Voltage Body Diode Forward Voltage Variation vs. Source Current and Temperature Capacitance Characteristics www.slkormicro.com Gate Charge Characteristics 3 SL5N65F Breakdown Voltage Variation vs. Temperature On-Resistance Variation vs. Temperature Maximum Drain Current Vs. Case Temperature Maximum Safe Operating Area www.slkormicro.com 4 SL5N65F TO-220F Package Dimensions SYMBOL A A1 A2 A3 B1 B2 B3 C C1 C2 www.slkormicro.com min 9.80 2.90 9.10 15.40 4.35 6.00 3.00 15.00 8.80 nom 7.00 max 10.60 SYMBOL D D1 D2 D3 E E1 E2 E3 E4 α(度) 3.40 9.90 16.40 4.95 7.40 3.70 17.00 10.80 5 min 1.15 0.60 0.20 2.24 nom 2.54 0.70 UNIT:mm max 1.55 1.00 0.50 2.84 1.0×45° 0.35 2.30 30° 0.65 3.30
SL5N65F
物料型号: SL5N65F
器件简介: - 这是一款N-Channel Power MOSFET,具有5.0A的漏极电流和650V的漏极-源极电压。 - 特点包括低门极电荷、低Crss、100%雪崩测试、快速开关和改进的dv/dt能力。
引脚分配: 未在文档中明确说明,但通常TO-220F封装有3个引脚。
参数特性: - 绝对最大额定值包括650V的漏极-源极电压、5.0A的连续漏极电流、±30V的门极-源极电压等。 - 热特性包括3.57°C/W的结到外壳热阻和62.5°C/W的结到环境热阻。
功能详解: - 该器件适用于高频开关电源模式、有源功率因数校正等应用。 - 电气特性包括650V的漏源击穿电压、2.4mΩ的静态漏源导通电阻、3.6S的正向跨导等。
应用信息: - 适用于高频开关电源和有源功率因数校正等。
封装信息: - 采用TO-220F封装,文档提供了详细的封装尺寸数据。
SL5N65F 价格&库存
很抱歉,暂时无法提供与“SL5N65F”相匹配的价格&库存,您可以联系我们找货
SL5N65F
  • 1+1.08000
  • 10+1.04000
  • 100+0.94400
  • 500+0.89600
