LMV358TP-SR
LMV358TP-SR
    3PEAK(思瑞浦)
    SOIC-8
    40μA,1.27MHz,微型电源轨对轨输入/输出运算放大器 SOIC8_150MIL
LMV358TP-SR 数据手册
LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Features Description  Upgrade to LMV321/LMV358/LMV324 Family  Stable 1.27MHz GBWP with Low IQ of Only 40μA Typical per Amplifier  0.9V/μs Slew Rate  Unity Gain Stable for ANY CAPACITIVE Load  Offset Voltage: 3.5mV Maximum  Offset Voltage Temperature Drift: 0.6uV/°C  Input Bias Current: 1pA Typical  THD+Noise: -105dB at 1kHz, -90dB at 10kHz  CMRR/PSRR: 110dB/102dB  Beyond the Rails Input Common-Mode Range  Outputs Swing to within 5mV Typical of each Rail  No Phase Reversal for Overdriven Inputs  No Crossover Distortion  Drives 2kΩ Resistive Loads  Single +2.1V to +6.0V Supply Voltage Range  –40°C to 125°C Operation Range  ESD Rating: Robust 8KV – HBM, 2KV – CDM and 500V – MM  Green, Popular Type Package LMV321TP/358TP/324TP are CMOS single, dual, and quad op-amps with low offset, stable high frequency response, low power, low supply voltage, and rail-to-rail inputs and outputs. They incorporate 3PEAK’s proprietary and patented design techniques to achieve best in-class performance among all micro-power CMOS amplifiers. The LMV321TP/358TP/324TP are unity gain stable with Any Capacitive Load with a Constant 1.27MHz gain-bandwidth product, 0.9V/μs slew rate while consuming only 40μA of supply current per amplifier. Analog trim and calibration routine reduces input offset voltage to below 3.5mV. Adaptive biasing and dynamic compensation enables the LMV321TP /358TP/324TP to achieve ‘THD+NOISE’ for 1kHz and 10kHz 2VPP signal at -105dB and -90dB, respectively. Beyond the rails input and rail-to-rail output characteristics allow the full power-supply voltage to be used for signal range. This combination of features makes the LMV321TP /358TP/324TP superior among rail-to-rail input /output CMOS op amps in its power class. The LMV321TP/358TP/324TP are ideal choices for battery-powered applications because they minimize errors due to power supply voltage variations over the lifetime of the battery and maintain high CMRR even for a rail-to-rail input op-amp. Applications  Active Filters, ASIC Input or Output Amplifier  Sensor Interface  Smoke/Gas/Environment Sensors  Portable Instruments and Mobile Device  Audio Output  PCMCIA Cards  Battery or Solar Powered Systems  Medical Equipment  Piezo Electrical Transducer Amplifier The LMV321TP/358TP/324TP can be used as cost-effective plug-in replacements for many commercially available op amps to reduce power and improve input/output range and performance. 3PEAK and the 3PEAK logo are registered trademarks of 3PEAK INCORPORATED. All other trademarks are the property of their respective owners. Pin Configuration (Top View) LMV321TP 5-Pin SOT23/SC70 (-T and -C Suffixes) +In 1 -VS 2 LMV358TP 8-Pin SOIC/MSOP (-S and -V Suffixes) 5 +VS Out A 1 -In A 2 A LMV324TP 14-Pin SOIC/TSSOP (-S and -T Suffixes) 8 +VS 7 Out B Out A 1 -In A 2 A -In 3 4 Out +In A 3 -VS 4 B Out D 13 -In D D 6 -In B +In A 3 12 +In D 5 +In B +VS 4 11 -VS +In B 5 10 +In C B www.3peakic.com.cn 14 C -In B 6 9 -In C Out B 7 8 Out C REV A 1 LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Absolute Maximum Ratings Note 1 + – Supply Voltage: V – V ....................................6.0V – + Operating Temperature Range.......–40°C to 125°C Input Voltage............................. V – 0.2 to V + 0.2 Maximum Junction Temperature................... 150°C Input Current: +IN, –IN, SHDN Note 2.............. ±10mA Storage Temperature Range.......... –65°C to 150°C Output Current: OUT.................................... ±45mA Lead Temperature (Soldering, 10 sec) ......... 260°C Output Short-Circuit Duration Note 3…......... Indefinite Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 500mV beyond the power supply, the input current should be limited to less than 10mA. Note 3: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD, Electrostatic Discharge Protection Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD MIL-STD-883H Method 3015.8 8 kV MM Machine Model ESD JEDEC-EIA/JESD22-A115 500 V CDM Charged Device Model ESD JEDEC-EIA/JESD22-C101E 2 kV Order and MSL Information Model Name LMV321TP LMV358TP LMV324TP Order Number Package Transport Media, Quantity LMV321TP-CR 5-Pin SC70 Tape and Reel, 3000 LMV321TP-TR Marking Information MSL Level AC4YW (1) MSL 3 (1) MSL 3 5-Pin SOT23 Tape and Reel, 3000 AT4YW LMV358TP-SR 8-Pin SOIC Tape and Reel, 4000 A42S MSL 3 LMV358TP-VR 8-Pin MSOP Tape and Reel, 3000 A42V MSL 3 LMV324TP-SR 14-Pin SOIC Tape and Reel, 2500 A44S MSL 3 LMV324TP-TR 14-Pin TSSOP Tape and Reel, 3000 A44T MSL 3 Note (1): ‘YW’ is date coding scheme. 'Y' stands for calendar year, and 'W' stands for single workweek coding scheme. 2 REV A www.3peakic.com.cn LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps 5V Electrical Characteristics The ● denotes the specifications which apply over the full operating temperature range, otherwise specifications are at T A = 27° C. VSUPPLY = 5V, VCM = VOUT = VSUPPLY/2, RL = 100KΩ, CL =100pF SYMBOL PARAMETER CONDITIONS VOS Input Offset Voltage VCM = VSUPPLY/2 VOS TC Input Offset Voltage Drift 0.6 μV/° C IB Input Bias Current 1.0 pA IOS Input Offset Current 1.0 pA Vn Input Voltage Noise μVP-P en Input Voltage Noise Density 5.6 39 23 RIN Input Resistance CIN Input Capacitance CMRR VCM Common Mode Rejection Ratio Common-mode Input Voltage Range Power Supply Rejection Ratio PSRR AVOL Open-Loop Large Signal Gain VOL ISC IQ PM GM GBWP Output Swing from Supply Rail Output Short-Circuit Current Quiescent Current per Amplifier Phase Margin Gain Margin Gain-Bandwidth Product Settling Time, 1.5V to 3.5V, Unity Gain Settling Time, 2.45V to 2.55V, Unity Gain tS SR Slew Rate FPBW Full Power Bandwidth Total Harmonic Distortion and Noise THD+N TYP MAX -3.5 ± 0.1 +3.5 f = 0.1Hz to 10Hz f = 1kHz f = 10kHz VOUT = 2.5V, RLOAD = 100kΩ VOUT = 0.1V to 4.9V, RLOAD = 100kΩ RLOAD = 100kΩ Sink or source current ● 80 ● -0.1 ● ● ● 80 80 72 ● RLOAD = 100kΩ, CLOAD = 100pF RLOAD = 100kΩ, CLOAD = 100pF f = 1kHz 0.1% 0.01% 0.1% 0.01% AV = 1, VOUT = 1.5V to 3.5V, CLOAD = 100pF, RLOAD = 100kΩ 2VP-P f=1kHz, AV=1, RL=100kΩ, VOUT = 2VPP f=10kHz, AV=1, RL=100kΩ, VOUT = 2VPP The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 500mV beyond the power supply, the input current should be limited to less than 10mA. UNITS mV nV/√Hz >100 Differential Common Mode VCM = 0.1V to 4.9V Note: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. www.3peakic.com.cn ● MIN GΩ 1.5 3.0 110 pF dB 5.1 102 102 102 5 45 40 66 -15 1.27 2.3 2.8 0.33 0.38 V dB dB 51 mV mA μA 0 dB MHz μs μs 0.9 V/μs 140 -105 -90 kHz dB A heat sink may be required to keep the junction temperature below the absolute maximum rating when the output is shorted indefinitely. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. Full power bandwidth is calculated from the slew rate FPBW = SR/π • VP-P. REV A 3 LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Typical Performance Characteristics 4 Small-Signal Step Response, 100mV Step Large-Signal Step Response, 2V Step Open-Loop Gain and Phase Phase Margin vs. CLOAD (Stable for Any CLOAD) Input Voltage Noise Spectral Density Common-Mode Rejection Ratio REV A www.3peakic.com.cn LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Typical Performance Characteristics Over-Shoot Voltage, CLOAD = 40nF, Gain = +1 Over-Shoot % vs. CLOAD, Gain = -1, RFB = 20kΩ Over-Shoot Voltage, CLOAD=40nF, Gain= -1, RFB=100kΩ Small-Signal Over-Shoot % vs. CLOAD, Gain = +1 Power-Supply Rejection Ratio VIN = -0.2V to 5.7V, No Phase Reversal www.3peakic.com.cn REV A 5 LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Typical Performance Characteristics 6 Quiescent Supply Current vs. Temperature Open-Loop Gain vs. Temperature Quiescent Supply Current vs. Supply Voltage Short-Circuit Current vs. Supply Voltage Input Offset Voltage Distribution Closed-Loop Output Impedance vs. Frequency REV A www.3peakic.com.cn LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Typical Performance Characteristics THD+Noise, Gain = +1, VIN = 1kHz, VPP = 2V THD+Noise, Gain = +1, VIN = 20kHz, VPP = 2V Pin Functions – IN: Inverting Input of the Amplifier. Voltage range – + of this pin can go from V – 0.1V to V + 0.1V. +IN: Non-Inverting Input of Amplifier. This pin has the same voltage range as –IN. +VS: Positive Power Supply. Typically the voltage is from 2.1V to 5.25V. Split supplies are possible as long as the voltage between V+ and V– is between 2.1V and 5.25V. A bypass capacitor of 0.1μF as close to the part as possible should be used between power supply pins or between supply pins and ground. – VS: Negative Power Supply. It is normally tied to ground. It can also be tied to a voltage other than + – ground as long as the voltage between V and V is from 2.1V to 5.25V. If it is not connected to ground, bypass it with a capacitor of 0.1μF as close to the part as possible. OUT: Amplifier Output. The voltage range extends to within millivolts of each supply rail. Operation The LMV321TP/358TP/324TP input signal range extends beyond the negative and positive power supplies. The output can even extend all the way to the negative supply. The input stage is comprised of two CMOS differential amplifiers, a PMOS stage and NMOS stage that are active over different ranges of common mode input voltage. The Class-AB control buffer and output bias stage uses a proprietary compensation technique to take full advantage of the process technology to drive very high capacitive loads. This is evident from the transient over shoot measurement plots in the Typical Performance Characteristics. Applications Information Low Supply Voltage and Low Power Consumption The LMV321TP/358TP/324TP of operational amplifiers can operate with power supply voltages from 2.1V to 6.0V. Each amplifier draws only 40μA quiescent current. The low supply voltage capability and low supply current are ideal for portable applications demanding HIGH CAPACITIVE LOAD DRIVING CAPABILITY and WIDE BANDWIDTH. The LMV321TP/358TP/324TP is optimized for wide bandwidth low power applications. They have an industry leading high GBWP to power ratio and are unity gain stable for ANY CAPACITIVE load. When the www.3peakic.com.cn REV A 7 LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps load capacitance increases, the increased capacitance at the output pushed the non-dominant pole to lower frequency in the open loop frequency response, lowering the phase and gain margin. Higher gain configurations tend to have better capacitive drive capability than lower gain configurations due to lower closed loop bandwidth and hence higher phase margin. Low Input Referred Noise The LMV321TP/358TP/324TP provides a low input referred noise density of 39nV/√Hz at 1kHz. The voltage noise will grow slowly with the frequency in wideband range, and the input voltage noise is typically 5.6μVP-P at the frequency of 0.1Hz to 10Hz. Low Input Offset Voltage The LMV321TP/358TP/324TP has a low offset voltage of 3.5mV maximum which is essential for precision applications. The offset voltage is trimmed with a proprietary trim algorithm to ensure low offset voltage for precision signal processing requirement. Low Input Bias Current The LMV321TP/358TP/324TP is a CMOS OPA family and features very low input bias current in pA range. The low input bias current allows the amplifiers to be used in applications with high resistance sources. Care must be taken to minimize PCB Surface Leakage. See below section on “PCB Surface Leakage” for more details. PCB Surface Leakage In applications where low input bias current is critical, Printed Circuit Board (PCB) surface leakage effects need to be considered. Surface leakage is caused by humidity, dust or other contamination on the board. Under low 12 humidity conditions, a typical resistance between nearby traces is 10 Ω. A 5V difference would cause 5pA of current to flow, which is greater than the LMV321TP/358TP/324TP OPA’s input bias current at +27°C (±1pA, typical). It is recommended to use multi-layer PCB layout and route the OPA’s -IN and +IN signal under the PCB surface. The effective way to reduce surface leakage is to use a guard ring around sensitive pins (or traces). The guard ring is biased at the same voltage as the sensitive pin. An example of this type of layout is shown in Figure 1 for Inverting Gain application. 1. For Non-Inverting Gain and Unity-Gain Buffer: a) Connect the non-inverting pin (VIN+) to the input with a wire that does not touch the PCB surface. b) Connect the guard ring to the inverting input pin (VIN–). This biases the guard ring to the Common Mode input voltage. 2. For Inverting Gain and Trans-impedance Gain Amplifiers (convert current to voltage, such as photo detectors): a) Connect the guard ring to the non-inverting input pin (VIN+). This biases the guard ring to the same reference voltage as the op-amp (e.g., VDD/2 or ground). b) Connect the inverting pin (VIN–) to the input with a wire that does not touch the PCB surface. Guard Ring VIN+ VIN- +VS Figure 1 Ground Sensing and Rail to Rail Output The LMV321TP/358TP/324TP has excellent output drive capability, delivering over 10mA of output drive current. The output stage is a rail-to-rail topology that is capable of swinging to within 5mV of either rail. Since the inputs can go 100mV beyond either rail, the op-amp can easily perform ‘True Ground Sensing’. 8 REV A www.3peakic.com.cn LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps The maximum output current is a function of total supply voltage. As the supply voltage to the amplifier increases, the output current capability also increases. Attention must be paid to keep the junction temperature of the IC below 150°C when the output is in continuous short-circuit. The output of the amplifier has reverse-biased ESD diodes connected to each supply. The output should not be forced more than 0.5V beyond either supply, otherwise current will flow through these diodes. ESD The LMV321TP/358TP/324TP has reverse-biased ESD protection diodes on all inputs and output. Input and out pins cannot be biased more than 200mV beyond either supply rail. Feedback Components and Suppression of Ringing Care should be taken to ensure that the pole formed by the feedback resistors and the parasitic capacitance at the inverting input does not degrade stability. For example, in a gain of +2 configuration with gain and feedback resistors of 10k, a poorly designed circuit board layout with parasitic capacitance of 5pF (part +PC board) at the amplifier’s inverting input will cause the amplifier to ring due to a pole formed at 3.2MHz. An additional capacitor of 5pF across the feedback resistor as shown in Figure 2 will eliminate any ringing. Careful layout is extremely important because low power signal conditioning applications demand high-impedance circuits. The layout should also minimize stray capacitance at the OPA’s inputs. However some stray capacitance may be unavoidable and it may be necessary to add a 2pF to 10pF capacitor across the feedback resistor. Select the smallest capacitor value that ensures stability. 5pF 10kΩ VOUT 10kΩ CPAR VIN Figure 2 Driving Large Capacitive Load The LMV321TP/358TP/324TP of OPA is designed to drive large capacitive loads. Refer to Typical Performance Characteristics for “Phase Margin vs. Load Capacitance”. As always, larger load capacitance decreases overall phase margin in a feedback system where internal frequency compensation is utilized. As the load capacitance increases, the feedback loop’s phase margin decreases, and the closed-loop bandwidth is reduced. This produces gain peaking in the frequency response, with overshoot and ringing in output step response. The unity-gain buffer (G = +1V/V) is the most sensitive to large capacitive loads. When driving large capacitive loads with the LMV321TP/358TP/324TP (e.g., > 200 pF when G = +1V/V), a small series resistor at the output (RISO in Figure 3) improves the feedback loop’s phase margin and stability by making the output load resistive at higher frequencies. RISO VOUT VIN CLOAD Figure 3 www.3peakic.com.cn REV A 9 LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Power Supply Layout and Bypass The LMV321TP/358TP/324TP OPA’s power supply pin (VDD for single-supply) should have a local bypass capacitor (i.e., 0.01μF to 0.1μF) within 2mm for good high frequency performance. It can also use a bulk capacitor (i.e., 1μF or larger) within 100mm to provide large, slow currents. This bulk capacitor can be shared with other analog parts. Ground layout improves performance by decreasing the amount of stray capacitance and noise at the OPA’s inputs and outputs. To decrease stray capacitance, minimize PC board lengths and resistor leads, and place external components as close to the op amps’ pins as possible. Proper Board Layout To ensure optimum performance at the PCB level, care must be taken in the design of the board layout. To avoid leakage currents, the surface of the board should be kept clean and free of moisture. Coating the surface creates a barrier to moisture accumulation and helps reduce parasitic resistance on the board. Keeping supply traces short and properly bypassing the power supplies minimizes power supply disturbances due to output current variation, such as when driving an ac signal into a heavy load. Bypass capacitors should be connected as closely as possible to the device supply pins. Stray capacitances are a concern at the outputs and the inputs of the amplifier. It is recommended that signal traces be kept at least 5mm from supply lines to minimize coupling. A variation in temperature across the PCB can cause a mismatch in the Seebeck voltages at solder joints and other points where dissimilar metals are in contact, resulting in thermal voltage errors. To minimize these thermocouple effects, orient resistors so heat sources warm both ends equally. Input signal paths should contain matching numbers and types of components, where possible to match the number and type of thermocouple junctions. For example, dummy components such as zero value resistors can be used to match real resistors in the opposite input path. Matching components should be located in close proximity and should be oriented in the same manner. Ensure leads are of equal length so that thermal conduction is in equilibrium. Keep heat sources on the PCB as far away from amplifier input circuitry as is practical. The use of a ground plane is highly recommended. A ground plane reduces EMI noise and also helps to maintain a constant temperature across the circuit board. Instrumentation Amplifier The LMV321TP/358TP/324TP OPA is well suited for conditioning sensor signals in battery-powered applications. Figure 4 shows a two op-amp instrumentation amplifier, using the LMV321TP/358TP/324TP OPA. The circuit works well for applications requiring rejection of Common Mode noise at higher gains. The reference voltage (VREF) is supplied by a low-impedance source. In single voltage supply applications, VREF is typically VDD/2. RG VREF R1 R2 R2 R1 VOUT V2 V1 VOUT =(V1  V2 )(1  R1 2 R1  )  VREF R2 RG Figure 4 Gain-of-100 Amplifier Circuit Figure 5 shows a Gain-of-100 amplifier circuit using two LMV321TP/358TP/324TP OPAs. It draws 74uA total current from supply rail, and has a -3dB frequency at 100kHz. Figure 6 shows the small signal frequency response of the circuit. 10 REV A www.3peakic.com.cn LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps +0.9V VIN VOUT -0.9V 90.9k 10k 90.9k 10k Figure 5: 100kHz, 74μA Gain-of-100 Amplifier Figure 6: Frequency response of 100kHz, 74uA Gain-of-100 Amplifier Buffered Chemical Sensor (pH) Probe The LMV321TP/358TP/324TP OPA has input bias current in the pA range. This is ideal in buffering high impedance chemical sensors such as pH probe. As an example, the circuit in Figure 7 eliminates expansive low-leakage cables that that is required to connect pH probe to metering ICs such as ADC, AFE and/or MCU. A LMV321TP/358TP/324TP OPA and a lithium battery are housed in the probe assembly. A conventional low-cost coaxial cable can be used to carry OPA’s output signal to subsequent ICs for pH reading. BATTERY 3V (DURACELL DL1620) R1 10M GENERAL PURPOSE COMBINATION pH PROBE (CORNING 476540) pH PROBE COAX To ADC/AFE/MCU R2 10M ALL COMPONENTS CONTAJNED WITHIN THE pH PROBE Figure 7: Buffer pH Probe Two-Pole Micro-power Sallen-Key Low-Pass Filter Figure 8 shows a micro-power two-pole Sallen-Key Low-Pass Filter with 400Hz cut-off frequency. For best results, the filter’s cut-off frequency should be 8 to 10 times lower than the OPA’s crossover frequency. Additional www.3peakic.com.cn REV A 11 LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps OPA’s phase margin shift can be avoided if the OPA’s bandwidth-to-signal ratio is greater than 8. The design equations for the 2-pole Sallen-Key low-pass filter are given below with component values selected to set a 400Hz low-pass filter cutoff frequency: C1 400pF VIN VOUT R1 1MΩ C2 400pF R2 1MΩ R1 = R 2 = R = 1M C1 = C2 = C = 400pF Q = Filter Peaking Factor = 1 R4 2MΩ R3 2MΩ f -3dB = 1/(2  RC ) = 400Hz R 3 = R 4 /(2-1/Q) ; with Q = 1, R 3 =R 4 Figure 8 Portable Gas Sensor Amplifier Gas sensors are used in many different industrial and medical applications. Gas sensors generate a current that is proportional to the percentage of a particular gas concentration sensed in an air sample. This output current flows through a load resistor and the resultant voltage drop is amplified. Depending on the sensed gas and sensitivity of the sensor, the output current can be in the range of tens of microamperes to a few milli-amperes. Gas sensor datasheets often specify a recommended load resistor value or a range of load resistors from which to choose. There are two main applications for oxygen sensors – applications which sense oxygen when it is abundantly present (that is, in air or near an oxygen tank) and those which detect traces of oxygen in parts-per-million concentration. In medical applications, oxygen sensors are used when air quality or oxygen delivered to a patient needs to be monitored. In fresh air, the concentration of oxygen is 20.9% and air samples containing less than 18% oxygen are considered dangerous. In industrial applications, oxygen sensors are used to detect the absence of oxygen; for example, vacuum-packaging of food products. The circuit in Figure 9 illustrates a typical implementation used to amplify the output of an oxygen detector. With the components shown in the figure, the circuit consumes less than 37μA of supply current ensuring that small form-factor single- or button-cell batteries (exhibiting low mAh charge ratings) could last beyond the operating life of the oxygen sensor. The precision specifications of these amplifiers, such as their low offset voltage, low TC-VOS, low input bias current, high CMRR, and high PSRR are other factors which make these amplifiers excellent choices for this application. 10 MΩ 1% 100 kΩ 1% VOUT Oxygen Sensor City Technology 4OX2 100 kΩ 1% I O2 100 Ω 1% VOUT  1Vin Air ( 21% O 2 ) I DD  0.7uA Figure 9 12 REV A www.3peakic.com.cn LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Package Outline Dimensions SC70-5 /SOT-353 Dimensions Dimensions In Millimeters In Inches Min Max Min Max A 0.900 1.100 0.035 0.043 A1 0.000 0.100 0.000 0.004 A2 0.900 1.000 0.035 0.039 b 0.150 0.350 0.006 0.014 C 0.080 0.150 0.003 0.006 D 2.000 2.200 0.079 0.087 E 1.150 1.350 0.045 0.053 E1 2.150 2.450 0.085 0.096 e 0.650TYP 0.026TYP e1 1.200 0.047 L 0.525REF 0.021REF L1 0.260 0.460 0.010 0.018 θ 0° 8° 0° 8° Symbol 1.400 0.055 SOT23-5 Dimensions Dimensions In Millimeters In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.400 0.012 0.016 C 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950TYP 0.037TYP e1 1.800 0.071 L 0.700REF 0.028REF L1 0.300 0.460 0.012 0.024 θ 0° 8° 0° 8° Symbol www.3peakic.com.cn 2.000 REV A 0.079 13 LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Package Outline Dimensions SOIC-8 Dimensions Dimensions In In Millimeters Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 B 0.330 0.510 0.013 0.020 C 0.190 0.250 0.007 0.010 D 4.780 5.000 0.188 0.197 E 3.800 4.000 0.150 0.157 E1 5.800 6.300 0.228 0.248 e 1.270TYP L1 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° Symbol 0.050TYP MSOP-8 14 REV A Symbol Dimensions In Millimeters Min Max Dimensions In Inches Min Max A 0.800 1.200 0.031 0.047 A1 0.000 0.200 0.000 0.008 A2 0.760 0.970 0.030 0.038 b 0.30 TYP 0.012 TYP C 0.15 TYP 0.006 TYP D 2.900 e 0.65 TYP E 2.900 3.100 0.114 0.122 E1 4.700 5.100 0.185 0.201 L1 0.410 0.650 0.016 0.026 θ 0° 6° 0° 6° 3.100 0.114 0.122 0.026 www.3peakic.com.cn LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Package Outline Dimensions SOIC-14 Dimensions In Millimeters Symbol MIN MAX A 1.35 1.60 1.75 A1 0.10 0.15 0.25 A2 1.25 1.45 1.65 A3 0.55 0.65 0.75 b 0.36 b1 0.35 c 0.16 c1 0.15 0.20 0.25 D 8.53 8.63 8.73 E 5.80 6.00 6.20 E1 3.80 3.90 4.00 e L www.3peakic.com.cn NOM 0.49 0.40 0.45 0.25 1.27 BSC 0.45 0.60 L1 1.04 REF L2 0.25 BSC 0.80 R 0.07 R1 0.07 h 0.30 θ 0° θ1 6° 8° 10° θ2 6° 8° 10° θ3 5° 7° 9° θ4 5° 7° 9° REV A 0.40 0.50 8° 15 LMV321TP/LMV358TP/LMV324TP 40μA, 1.27MHz, Micro-Power Rail-to-Rail I/O Op Amps Package Outline Dimensions TSSOP-14 Dimensions In Millimeters Symbol MIN REV A MAX A - - 1.20 A1 0.05 - 0.15 A2 0.90 1.00 1.05 A3 0.34 0.44 0.54 b 0.20 - 0.28 b1 0.20 0.22 0.24 c 0.10 - 0.19 c1 0.10 0.13 0.15 D 4.86 4.96 5.06 E 6.20 6.40 6.60 E1 4.30 4.40 4.50 e 16 NOM 0.65 BSC L 0.45 0.60 0.75 L1 1.00 REF L2 0.25 BSC R 0.09 - - R1 0.09 - - s 0.20 - θ1 0° - 8° θ2 10° 12° 14° θ3 10° 12° 14° www.3peakic.com.cn
LMV358TP-SR 价格&库存
很抱歉,暂时无法提供与“LMV358TP-SR”相匹配的价格&库存,您可以联系我们找货
LMV358TP-SR
  • 5+0.64680
  • 50+0.57820
  • 800+0.40180
  • 1600+0.34300
库存:995
LMV358TP-SR
  • 1+0.60129
  • 200+0.38776
  • 2000+0.33798
  • 4000+0.29868
库存:85153
LMV358TP-SR
    • 4000+0.26070
    库存:4000
    LMV358TP-SR
      • 5+0.81310
      • 50+0.72690
      • 150+0.64060
      • 500+0.50510
      • 1500+0.43120
      • 3000+0.38190
      库存:1320
      LMV358TP-SR
      • 5+0.71280
      • 50+0.63720
      • 150+0.56160
      • 500+0.44280
      • 1500+0.37800
      • 3000+0.33480
      库存:1320
