Transient
Voltage
Suppressors
SMFJ Series
Circuit Protection
System
Revision:DEC-16
Transient Voltage Suppressors - SMFJ Series
Features
• Fast response time
• Built-in strain relief
• Low incremental surge resistance
• Matte tin lead–free Plated
• Halogen ree and RoHS compliant
• For surface mounted applications to optimize board space
• Compatible with industrial standard package SOD-123FL
• ESD protection of data lines in accordance with IEC 61000-4-2 (IEC801-2)
• EFT protection of data lines in accordance with IEC 61000-4-4 (IEC801-4)
• 200W peak pulsepower capability at 10/1000μs waveform,repetition rate
(duty cycle): 0.01%
Cathode
• High temperature soldering : 260°C/ 40 seconds at terminals
BI
Anode
UNI
Description
The SMFJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning
and other transient voltage events. SOD-123FL package is 50% smaller in footprint when compare to SMA package and
deliverying low height profile (1.1mm) in the industry.
Mechanical Characteristics
Rating
Symbol
Value
Units
Peak Pulse Power Dissipation at TA=25ºC by 10/1000µs (Note
1)
PPPM
200
W
Thermal Resistance Junction- to- Ambient
RθJA
220
°C/W
Thermal Resistance Junction- to- Lead
RθJL
100
°C/W
TJ,TSTG
-55°C to 150°C
°C
Operating junction and Storage Temperature Range.
Notes:
1. Non-repetitive current pulse, per Fig. 4 and derated above TA=25ºC per Fig. 3
Circuit Protection
System
Revision:DEC-16
Page:1
Electriacl Characteristics
Type Number
Marking
Reverse
Stand-Off
Voltage
Breakdown
Voltage
Test
Current
Max
Clamping
Voltage
10/1000µs
Peak Pulse
Current
10/1000µs
Reverse
Leakage
VRWM
VBR @IT
IT
VC@IPP
IPP
IR@VRWM
UNI
BI
UNI
BI
V
Min(V)
Max(V)
mA
V
A
µA
SMFJ5.0A
SMFJ5.0CA
5.0A
5.0CA
5.0
6.40
7.25
10
9.20
21.7
400
SMFJ6.0A
SMFJ6.0CA
6.0A
6.0CA
6.0
6.67
7.67
10
10.3
19.4
400
SMFJ6.5A
SMFJ6.5CA
6.5A
6.5CA
6.5
7.22
8.30
10
11.2
17.9
250
SMFJ7.0A
SMFJ7.0CA
7.0A
7.0CA
7.0
7.78
8.95
10
12.0
16.7
100
SMFJ7.5A
SMFJ7.5CA
7.5A
7.5CA
7.5
8.33
9.58
1
12.9
15.5
50
SMFJ8.0A
SMFJ8.0CA
8.0A
8.0CA
8.0
8.89
10.23
1
13.6
14.7
25
SMFJ8.5A
SMFJ8.5CA
8.5A
8.5CA
8.5
9.44
10.82
1
14.4
13.9
10
SMFJ9.0A
SMFJ9.0CA
9.0A
9.0CA
9.0
10.00
11.50
1
15.4
13.0
5.0
SMFJ10A
SMFJ10CA
10A
10CA
10.0
11.10
12.80
1
17.0
11.8
2.5
SMFJ11A
SMFJ11CA
11A
11CA
11.0
12.20
14.00
1
18.2
11.0
2.5
SMFJ12A
SMFJ12CA
12A
12CA
12.0
13.30
15.30
1
19.9
10.1
2.5
SMFJ13A
SMFJ13CA
13A
13CA
13.0
14.40
16.50
1
21.5
9.30
1
SMFJ14A
SMFJ14CA
14A
14CA
14.0
15.60
17.90
1
23.2
8.60
1
SMFJ15A
SMFJ15CA
15A
15CA
15.0
16.70
19.20
1
24.4
8.20
1
SMFJ16A
SMFJ16CA
16A
16CA
16.0
17.80
20.50
1
26.0
7.70
1
SMFJ17A
SMFJ17CA
17A
17CA
17.0
18.90
21.70
1
27.6
7.20
1
SMFJ18A
SMFJ18CA
18A
18CA
18.0
20.00
23.30
1
29.2
6.80
1
SMFJ20A
SMFJ20CA
20A
20CA
20.0
22.20
25.50
1
32.4
6.20
1
SMFJ22A
SMFJ22CA
22A
22CA
22.0
24.40
28.00
1
35.5
5.60
1
SMFJ24A
SMFJ24CA
24A
24CA
24.0
26.70
30.70
1
38.9
5.10
1
SMFJ26A
SMFJ26CA
26A
26CA
26.0
28.90
33.20
1
42.1
4.80
1
SMFJ28A
SMFJ28CA
28A
28CA
28.0
31.10
35.80
1
45.4
4.40
1
SMFJ30A
SMFJ30CA
30A
30CA
30.0
33.30
38.30
1
48.4
4.10
1
SMFJ33A
SMFJ33CA
33A
33CA
33.0
36.70
42.20
1
53.3
3.80
1
SMFJ36A
SMFJ36CA
36A
36CA
36.0
40.00
46.00
1
58.1
3.40
1
SMFJ40A
SMFJ40CA
40A
40CA
40.0
44.40
51.10
1
64.5
3.10
1
SMFJ43A
SMFJ43CA
43A
43CA
43.0
47.80
54.90
1
69.4
2.90
1
SMFJ45A
SMFJ45CA
45A
45CA
45.0
50.00
57.50
1
72.7
2.80
1
SMFJ48A
SMFJ48CA
48A
48CA
48.0
53.30
61.30
1
77.4
2.60
1
SMFJ51A
SMFJ51CA
51A
51CA
51.0
56.70
65.20
1
82.4
2.40
1
Circuit Protection
System
Revision:DEC-16
Page:2
Type Number
Marking
Reverse
Stand-Off
Voltage
Breakdown
Voltage
Test
Current
Max
Clamping
Voltage
10/1000µs
Peak Pulse
Current
10/1000µs
Reverse
Leakage
VRWM
VBR @IT
IT
VC@IPP
IPP
IR@VRWM
UNI
BI
UNI
BI
V
Min(V)
Max(V)
mA
V
A
µA
SMFJ54A
SMFJ54CA
54A
54CA
54.0
60.00
69.00
1
87.1
2.30
1
SMFJ58A
SMFJ58CA
58A
58CA
58.0
64.40
74.10
1
93.6
2.10
1
SMFJ60A
SMFJ60CA
60A
60CA
60.0
66.70
76.70
1
96.8
1.80
1
SMFJ64A
SMFJ64CA
64A
64CA
64.0
71.10
81.80
1
103.0
1.70
1
SMFJ70A
SMFJ70CA
70A
70CA
70.0
77.80
89.50
1
113.0
1.50
1
SMFJ75A
SMFJ75CA
75A
75CA
75.0
83.30
95.80
1
121.0
1.40
1
SMFJ78A
SMFJ78CA
78A
78CA
78.0
86.70
99.70
1
126.0
1.40
1
SMFJ85A
SMFJ85CA
85A
85CA
85.0
94.40
108.20
1
137.0
1.30
1
SMFJ90A
SMFJ90CA
90A
90CA
90.0
100.00
115.50
1
146.0
1.20
1
SMFJ100A
SMFJ100CA
100A
100CA
100.0
111.00
128.00
1
162.0
1.10
1
SMFJ110A
SMFJ110CA
110A
110CA
110.0
122.00
140.50
1
177.0
1.00
1
SMFJ120A
SMFJ120CA
120A
120CA
120.0
133.00
153.00
1
193.0
0.90
1
SMFJ130A
SMFJ130CA
130A
130CA
130.0
144.00
165.50
1
209.0
0.80
1
SMFJ150A
SMFJ150CA
150A
150CA
150.0
167.00
192.50
1
243.0
0.70
1
SMFJ160A
SMFJ160CA
160A
160CA
160.0
178.00
205.00
1
259.0
0.70
1
SMFJ170A
SMFJ170CA
170A
170CA
170.0
189.00
217.50
1
275.0
0.60
1
SMFJ180A
SMFJ180CA
180A
180CA
180.0
198.00
230.40
1
292.0
0.60
1
SMFJ190A
SMFJ190CA
190A
190CA
190.0
209.00
243.20
1
308.0
0.50
1
Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double.
Circuit Protection
System
Revision:DEC-16
Page:3
I-VI-VCurve
Characteristics
Curve Characteristics
BR V
VBR
Vc V
VRR
Vc
Bi-directional
II
pp
IIpp
BR V
VBR
Vc V
VRR
Vc
V
V
IIRR V
VFF
IITT
IITT
IIRR
IIRR
IITT
VRRV
BR Vc
VBR
Vc
V
V
V
pp
IIpp
pp
IIpp
PP
PPM Peak Pulse Power Dissipation -- Max power dissipation
PPM
VV
Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation
RR
R Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation
Breakdown Voltage -- Maximum voltage that flows thoughthe TVS at a specified test current (ITT)
VV
BR
BR
test current (IT)
BR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified
VV
Clamping
Voltage
-- Peak--voltage
across the suppressor
a specified
Ippm (peakIppm
impulse
current)
CC C
Clamping
Voltage
Peak measured
voltage measured
across theat TVS
at a specified
(peak
impulse current)
IRIRR Reverse
Leakage
Current
-- Current
at VRR
Reverse
Leakage
Current
-- measured
Current measured
at VR
VV
Forward
Voltage
Drop Drop
for Uni-directional
Forward
Voltage
for Uni-directional
FF F
Ratings and Characteristic Curves
(TAA=25°C
=25°C unless
unless otherwise
otherwise noted)
noted)
(T
Figure 1 - TVS Transients Clamping Waveform
Figure 2 - Peak Pulse Power Rating
1000
1000
PPPM
-Peak Pulse Power (kW)
PPM
Voltage Transients
Transients
Voltage
Voltage Across
Across TVS
TVS
Voltage
Voltage or Current
P6KESeries
Series
P6KE
Uni-directional
Current Through
Through TVS
TVS
Current
100
100
10
10
11
0.1
0.1
0.000001
0.000001
Time
Time
Circuit Protection
System
0.00001
0.00001
0.0001
0.0001
0.001
0.001
-Pulse Width
Width (Sec.)
(Sec.)
ttdd-Pulse
Revision:DEC-16
Page:4
Ratings and Characteristic Curves (TA=25°C unless otherwise noted) (Continued)
Figure 3 - Pulse Derating Curve
Figure 4 - Pulse Waveform - 10/1000 µ S
150
IPPM - Peak Pulse Cur rent, % IRSM
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
100
80
60
40
50
75
100
125
150
tr=10µsec
Half Value
IPPM IPPM
2
50
10/1000µsec. Waveform
as defined by R.E.A
TA-Ambient temperature (ºC)
td
2.0
3.0
4.0
t-Time (ms)
Figure 5 - Steady State Power Dissipation
Derating Curve
Figure 6 - Forward Voltage
0.9
Vf - Typical forward dropped voltage
1.50
PM(AV), Steady State Power Dissipation (W)
Peak Value
IPPM
100
T J =25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
1.25
1.00
0.75
0.50
0.25
50
75
100 125
TL - Tab temperature (ºC)
150
175
0.8
0.7
0.6
0.5
0.4
10
75
140
Temperature (ºC)
Figure 7 - C j vs. Working Peak Reverse Voltage
10000
1000
Cj (pf)
Measured@Vr=0v
100
10
1
Measured@50%Vr
10
100
Vbr - Reverse breakdown voltage
Circuit Protection
System
Revision:DEC-16
Page:5
Soldering Parameters
Pre Heat
- Temperature Min (Ts(min))
150°C
- Temperature Max (Ts(min))
200°C
- Time (min to max) (t s)
60-180 secs
3°C/second max
TS(max) to TA - Ramp-up Rate
3°C/second max
- Temperature (TA) (Liquidus)
Ramp-down
Ts(min)
ts
Preheat
Time (t)
260+0/-5 °C
Time within 5°C of actual peak Temperature (tp)
Environmental Specifications
20-40 seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max.
Do not exceed
280°C
Physical Specifications
JEDEC SOD-123FL molded plastic body over passivated junction.
Polarity
Color band denotes the cathode except Bipolar.
Termina
Matte Tin axial leads, solderable per JESD22-B102D.
E
Case
High Temp. Storage
JESD22-A103
HTRB
JESD22-A108
Temperature Cycling
JESD22-A104
MSL
JEDEC-J-STD-020, Level 1
H3TRB
JESD22-A101
RSH
JESD22-A111
Flow/Wave Soldering
Peak Temperature :
265°C
Dipping Time :
Dimensions
10
seconds
Soldering :
1 time
D
C
Mounting P ad L ayout
E
G
H
A
B
A
E
E
B
F
A
E
1.3 (0.051)
1.4 (0.055)
D
E
E
C
F
G
H
G
H
1.6 (0.062)
Max3.9
2.50
2.90
3.40Inches
3.90
A
Min
Min
2.50
0.70
Millimeters
1.50
D
C
Max
MaxE D Min
2.90
0.1222
2.5
B
0.1339
0.1535
C
0.0275
G
0.0472
3.40
D
0.051
0.0787
H
E
0.0138
0.0354
F
0.0020
0.0039
B
F
G
G
1.3 (0.051)
H
H
3.40
0.70
1.50
0.35
0.05
E
F 3.90
F
1.20
G 0.7
2.00
H
0.90
0.26
1.5
0.35
0.05
0.70
Min
Max
0.35
1.50
0.0984
3.1
0.35
0.1339
0.05
3.90
0.05
0.0275
0.00
1.2
0.00
0.0591
2.0
0.95
0.95
0.0138
0.90
0.0020
0.26
0.00 0.0039 0.10 0.00 0.0000
0.10
0.95
1.10
0.0374
0.0374
0.0433
0.95
1.35
0.0000
1.4 (0.055)
1.6 (0.062)
Min
3.40
0.0984
E
1.3 (0.051)
B
A
D
F
1.6 (0.062)
A
C
E
G
H
D
C
Inches
DIM
1.4 (0.055)
1.3 (0.051)
Dimensions
A
B
C
E
D
F
G
H
1.4 (0.055)
Circuit Protection
System
Ma
2.50
Millimeters 2.9
Millimeters B
Dimensions
F
Min
A
C
B
C
Millimeters
Dimensions
B
1.6 (0.062)
Dimensions SOD-123FL
A
Ts(max)
60-150 seconds
Peak Temperature (TP)
D
tL
217°C
Critical Z one
TL to TP
Ramp-up
TL
Average ramp up rate (Liquidus Temp (TA) to
peak
Reflow
tp
TP
Lead-free assembly
Temperature (T)
Reflow Condition
Revision:DEC-16
Page:6
1.2
2.0
1.20
Max
2.000.9
0.1142
0.900.2
0.1535
0.26
0.0472
0.1
0.10
0.0787
1.101.1
0.0354
0.0102
0.0039
0.0433
M
2.
3.
0.
1.
0.
0.
0.
0.
Product Name
S
M
F
Series code
Part Marking System
J
x
x
DC Spark-over
Voltage
x
C
Cathode band
A
(for Uni-directional products only)
Blank:UniDirectional
XXX
C:Bi-Directional
5% Voltage
Tolerance
Marking code
Packaging
Part Number
Component
Package
Quantity
Packaging
Option
Packaging Specification
SMFJxxxXX
SOD-123FL
3000
Tape & Ree
EIA STD RS-481
Tape and Reel Specification
0.157
(4.0)
Cathode
0.31
(8.0)
0.157
(4.0)
13.0 (330)
0.80 (20.2)
Arbor Hole Dia.
0.059 DIA
(1.5)
Cover tape
Dimensions are in inches
(and millimeters).
Direction of Feed
0.33
(8.5)
0.157
(4.0)
Cathode
0.47
(12.0)
0.157
(4.0)
13.0 (330)
Circuit Protection
0.80 (20.2)
Arbor Hole
Dia.
System
0.49
(12.5
0.059 DIA
(1.5)
Cover tape
(and millimeters).
Direction of Feed
Revision:DEC-16
Page:7
很抱歉,暂时无法提供与“SMFJ5.0A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.42826
- 100+0.34176
- 300+0.29857
- 3000+0.26625
- 6000+0.24029
- 9000+0.22727
- 国内价格
- 1+0.30160
- 200+0.19552
- 1500+0.16952
- 3000+0.15080
- 国内价格
- 10+0.39256
- 100+0.31328
- 600+0.27369
- 1200+0.26958
- 3000+0.24405
