SENC3D3V1U
SENC3D3V1U
    ELECSUPER(静芯微)
    SOD-323
    反向关断电压(典型值):3.3V(Max) 击穿电压(最小值):4.5V 箝位电压:19V 峰值脉冲电流:24A (8/20us) 极性:Unidirectional
SENC3D3V1U 数据手册
SENC3Dxx1U Rev-2021-1 www.elecsuper.com SuperESD - SENC3Dxx1U 1. Description The SENC3Dxx1U is a Transient Voltage Suppressor that designed to protect components which are connected to data and transmission lines against electrostatic discharge (ESD), electrical fast Transients (EFT), and lightning. All pins are rated to withstand 30kV ESD pulses using the IEC610004-2 air discharge method. 2. Features   IEC 61000-4-2 Level 4 ESD Protection  RoHS compliance - ±30kV Contact Discharge  Unidirectional configuration - ±30kV Air Discharge  Low clamping voltage IEC 61000-4-4 EFT Protection  Working voltage:  40A (5/50ns) 3.3V/5V/7V/12V/15V/24V/36V 350W Peak pulse Power (8/20us) 3. Applications  Interfaces  End Equipment - USB 2.0/1.1 - Industrial and Serve Robots - GPIO - Laptops and Desktops - Ethernet 10/100/1000 Mbps - TV and Monitors - Audio - Wearables - Pushbuttons - Handheld-wireless Systems 4. Ordering Information Part Number Package Material Packing Quantity per reel Flammability Rating Reel Size SENC3Dxx1U SOD323 Halogen free Tape & Reel 3,000 PCS UL 94V-0 7 inches 24V |24W 36V |36W VRWM Marking 3.3V |03W Marking for the SENC3Dxx1U series 5V 7V 12V 15V |D05 |07W |12W |15W Table-1 Copyright© ElecSuper Incorporated Ordering information Contact Us 1 / 7 SENC3Dxx1U Rev-2021-1 www.elecsuper.com 5. Pin Configuration and Functions Pin Name Description 1 IO Connect to IO 2 GND Outline 1 Marking Circuit Diagram 2 1 2 Connect to GND Table-2 Pin configuration 6. Specification 6.1. Absolute Maximum rating Over operating free-air temperature range (unless otherwise noted) Parameters Symbol Min. Max. Unit Peak pulse power (tp=8/20us)@25℃ Ppk - 350 W Peak pulse current (tp=8/20us)@25℃ IPP Refer to Table-5 A ESD (IEC61000-4-2 air discharge) @25℃ VESD - ±30 kV ESD (IEC61000-4-2 contact discharge) @25℃ VESD - ±30 kV TJ - 125 ℃ Operating temperature TOP -40 85 ℃ Storage temperature TSTG -55 150 ℃ TL - 260 ℃ Junction temperature Lead temperature Table-3 Copyright© ElecSuper Incorporated Absolute Maximum rating Contact Us 2 / 7 SENC3Dxx1U Rev-2021-1 www.elecsuper.com 6.2. Electrical Characteristics Symbol Description VRWM Rated reverse stand-off voltage VBR Minimum breakdown voltage @IT = 1mA VCL Clamping voltage IPP Maximum peak pulse current IR Reverse leakage current @VRWM CO Typical line capacitance (VIO=0V, VP-P = 30mV, f = 1MHz) Table-4 Parameters Description At TA = 25℃ unless otherwise noted VRWM VBR VCL@I=1A IPP VCL@I=IPP IR CO (V) (V) (V) (A) (V) (uA) (pF) SENC3D3V1U 3.3 4.5 8.0 24.0 19.0 1.0 300 SENC3D5V1U 5.0 6.5 9.0 20.0 20.0 1.0 300 SENC3D7V1U 7.0 7.5 10.0 15.0 23.0 1.0 200 SENC3D12V1U 12.0 13.3 19.0 12.0 33 1.0 150 SENC3D15V1U 15.0 16.5 24 9.0 50 1.0 120 SENC3D24V1U 24.0 26.0 38 6.0 60 1.0 80 SENC3D36V1U 36.0 38.0 55 4.0 70 1.0 50 Part Number Table-5 Copyright© ElecSuper Incorporated Electrical Characteristics for All Series Contact Us 3 / 7 SENC3Dxx1U Rev-2021-1 www.elecsuper.com 7. Typical Characteristic Non-repetitive peak pulse power vs. pulse time 8. Typical Application Pic-3 Copyright© ElecSuper Incorporated Typical Internet 1G Interface Application Contact Us 4 / 7 SENC3Dxx1U Rev-2021-1 www.elecsuper.com 9. Dimension SOD323 Symbol A A1 A2 b C D E E1 L L1 θ Dimensions in Millimeters Min. Max. 1.000 0.000 0.100 0.800 0.900 0.250 0.350 0.080 0.150 1.200 1.400 1.600 1.800 2.550 2.750 0.475REF 0.250 0.400 0° 8° Table-6 Copyright© ElecSuper Incorporated Dimensions in Inches Min. Max. 0.039 0.000 0.004 0.031 0.035 0.010 0.014 0.003 0.006 0.047 0.055 0.063 0.071 0.100 0.108 0.019REF 0.010 0.016 0° 8° product dimensions Contact Us 5 / 7 SENC3Dxx1U Rev-2021-1 www.elecsuper.com 10. Recommended Land Pattern Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only 4. Unit: mm Copyright© ElecSuper Incorporated Contact Us 6 / 7 SENC3Dxx1U Rev-2021-1 www.elecsuper.com DISCLAIMER ELECSUPER SUPERESD PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper SuperESD products. You are solely responsible for (1) selecting the appropriate ElecSuper SuperESD products for your application, (2) designing, validating and testing your application (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper SuperESD grants you permission to use these resources only for development of an application that uses the ElecSuper SuperESD products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper SuperESD intellectual property right or to any third party intellectual property right. ElecSuper SuperESD disclaims responsibility for, and you will fully indemnify ElecSuper SuperESD and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper SuperESD’s products are provided subject to ElecSuper SuperESD’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper SuperESD products. ElecSuper SuperESD’s provision of these resources does not expand or otherwise alter ElecSuper SuperESD’s applicable warranties or warranty disclaimers for ElecSuper SuperESD products Copyright© ElecSuper Incorporated Contact Us 7 / 7
SENC3D3V1U 价格&库存
很抱歉,暂时无法提供与“SENC3D3V1U”相匹配的价格&库存,您可以联系我们找货
