山东晶导微电子有限公司
B5817WS THRU B5819WS
Jingdao Microelectronics
SCHOTTKY BARRIER RECTIFIERS
FEATURES
PINNING
• Metal silicon junction, majority carrier conduction
PIN
DESCRIPTION
• Guarding for overvoltage protection
1
Cathode
• Low power loss, high efficiency
2
Anode
• High current capability
2
• low forward voltage drop
• High surge capability
1
• For use in low voltage, high frequency inverters,
Top View
Marking Code: B5817WS---SJ
B5818WS---SK
B5819WS---SL
free wheeling, and polarity protection applications
Simplified outline SOD-323 and symbol
MECHANICAL DATA
▪Case: SOD-323
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪A pprox. Weight: 5.48mg / 0.00019oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Symbols
B5817WS
B5818WS
B5819WS
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
14
21
28
V
Maximum DC Blocking Voltage
V DC
40
V
Maximum Average Forward Rectified Current
I F(AV)
1
A
Peak Forward Surge Current, 8.3ms Single Half Sine-wave
Superimposed On Rated Load (JEDEC method)
I FSM
9
A
at 1 A
at 3 A
VF
Parameter
Maximum Instantaneous Forward Voltage
0.45
0.75
0.55
0.875
0.6
0.9
V
Maximum Instantaneous Reverse Current at TA = 25°C
Rated DC Reverse Voltage
TA = 100°C
IR
1
10
mA
Typical Junction Capacitance
Cj
110
pF
T j , T stg
-55 ~ +150
°C
Storage and Operating Junction Temperature Range
2016.10
SOD323-S-B5817WS~B5819WS-1A40V
Page 1 of 3
山东晶导微电子有限公司
1N5817W THRU 1N5819W
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
resistive or inductive load
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
10 3
T J =125°C
10 2
T J =75°C
10 1
T J =25°C
10 0
Case Temperature (°C)
Fig.3 Typical Forward Characteristic
60
80
100
Fig.4 Typical Junction Capacitance
500
5°
C
=2
TJ
12
5°C
0.5
Junction Capacitance ( pF)
1.0
TJ =
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
0.2
0.1
0.2
0.3
0.4
0.5
0.6
200
100
50
0.7
0.1
1
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
25
10
05
00
1
10
100
Number of Cycles at 50Hz
2016.10
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323 mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
8
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
Type number
Marking code
B5817WS
SJ
B5818WS
SK
B5819WS
SL
1.2
(47)
1.2
(47)
Marking
Unit: mm
(mil)
2016.10
610272B8
Page 3 of 3
很抱歉,暂时无法提供与“B5819WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11167
- 600+0.08821
- 1200+0.08689
- 3000+0.07474
- 国内价格
- 50+0.12183
- 500+0.09623
- 3000+0.08154
- 6000+0.07301
- 24000+0.06567
- 51000+0.06167
- 国内价格
- 1+0.32890
- 200+0.10989
- 1500+0.06875
- 3000+0.05456
- 国内价格
- 3000+0.04485
- 6000+0.04368
- 国内价格
- 50+0.11410
- 500+0.08870
- 3000+0.07490
- 6000+0.06690
- 24000+0.05940
- 51000+0.05560
