B8G1500M
B8G1500M
    BENCENT(槟城)
    插件,D8xL6mm
    电极数:2 直流击穿电压(最小值):1200V 直流击穿电压(典型值):1500V 直流击穿电压(最大值):1800V 精度:- 脉冲放电电流:10kA 极间电容:1.5pF
B8G1500M 数据手册
B8G1500 B 0M Ordder Code: B8G1500M M-01 Gass Discharge Tube Verrsion: A2 2014 4-04-23 Feaatures Ex xterior Siize Design Φ8×6mm H High Current Handling H Caapability 10,00 00A @ 8/20μs L Low Capacitan nce and Inserrtion Loss Fast Responsee and Long Seervice Life R Reliable to Pro otect Electrosstatic Surge M Moisture sensiitivity level:Level 1 Application innformation Paackage (Topp View) A Power AC ` 1 Ageency Approovals Icon 2 Scchematic Syymbol n Description C Compliance with h 2011/65/EU C Compliance with h IEC61249-2-21:2003 2 1 M Mean lead free C Compliance with h UL1449, Certifficated E337906 Elecctrical Param meter DC Breakdown Voltage1)2) 100V/s 1200-1800 V At 1kV/μ μs for 99 % of measured m vallues  2700 V At 1kV/μ μs Typical valu ues of distribu ution  2500 0 V 8/20μs ±5tiimes 10 KA A Arcc Voltage At 1A ~15 V Insulatio on Resistancee DC=100V V ≥1 GΩ Ω Capacitaance at 1 MHz VDC=0.5V V ≤1.5 pF F W Weight ~1.62 g Op perating and storage s Temp perature -40-90 ℃ M Marking Bencent Loggo, Voltage aand date codee Impulse Spaark-over Volttage 3) Impulse Disscharge Curreent 1) At A delivery AQ QL 0.65 level II GB/T 282 28.1-2003 2) In n ionized mod de 3) Terms Te and currrent waveform ms in accordance with ITU U-T Rec. K. 12; IEC 6164 43-21 1/3 www.beencent.com m.cn S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications B8G1500 B 0M Ordder Code: B8G1500M M-01 Gass Discharge Tube Verrsion: A2 2014 4-04-23 Prroduct Charracteristics Parrt Numberinng System B8G XXX M (2) (1) (3) (1)B Bencent 2-Electrode DIP Gas Dischaarge Tube wiith d dimension: Φ8.0×6 (D×L L) (mm) (2) DC Breakdown Voltage, e.g.,600=600 0V (3) Surge Ratingg @8/20μs, M=10KA Lead Materrial Copp per Body Materrial Ceram mics Iron-nickel electrode Terminal T Fin nish 1 100% Matte--Tin Plated Envvironmentall Reliabilityy Characteriistics T Testing itemss Hiigh Temperatu ure Storage Test T Lo ow Temperatu ure Storage Test T Vib bration Reesistance of so oldering heatt Techn nical standard ds Temperaature: 85℃ Time:2H H Temperaature: -40℃ Time:2H H Frequenccy:10-500H Hz Amplitu ude:0.15mm m Time:4 45mins Temperaature: 260±5℃ ℃ Time of dip solderingg:10s,1tim me Notte: Up-screen n program caan be specifieed by custom mer’s request via contactin ng Bencent sservice Sollderability test Soldderability S Solder Pot Tem mperature: 2455℃±5℃ Solder Dweell Time: 4-66 seconds D Prooduct Dimennsions 2/3 REF mm inch A 62±2 2.441±0.079 B 6±0.2 0.236±0.008 C Φ8±0.2 Φ0.315±0 0.008 D Φ1.0±0.06 Φ0.039±0..0024 www.beencent.com m.cn S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications B8G1500 B 0M Ordder Code: B8G1500M M-01 Gass Discharge Tube Verrsion: A2 2014 4-04-23 Waave Solderinng profile 300 280 80 60 40 20 240 230 220 210 200 190 180 170 160 150 140 130 110 120 0 90 2-5 seconds 100 100 Solder Dwell D Time 120 80 0℃ Max 280 140 70 Solder Po ot Temperaturre 160 60 60 – 180 secs 180 50 Timee (min to max) m 200 40 150 0°C 220 30 Temp perature Max x 240 20 100 0°C 10 Heeat Temp perature Min 260 p ( ) Temperature (℃)-Measured on bottom side of board Prre Pb b-Free assem mbly 0 Wave Soldeering Condittion Time(Seconds) Preheat Time Cooling C Time Dwell Time Package Reel Information I n W OUTLIN NE REEL (PCS) PER CART TON (PCS) 700 4200 TAPIN NG 3/3 www.beencent.com m.cn REF m mm inch W 65 5±3 2.559±0.118 P 10 0±1 0.394±0.039 A Φ34 40±2 Φ13.386±0.079 B Φ8 83±2 Φ3.268±0.0 079 C 73 3±3 2.874±0.118 CA ARTON SIZE E(mm) L W H 480 350 360 S Specifications aare subject to ch hange without notice. n Customers should verify actuaal device perforrmance in their specific applications
