BV-D505ZC
Order Code: BV-D505ZC
Transient Voltage Suppressor
Version: A0 2016-03-14
Features
Exterior
IEC61000-4-2(ESD)±15KV(air),±8KV(contact)
IEC61000-4-5(Lightning) 10A(8/20us)
200 Watts peak pulse power(tp=8/20us)
Low operating voltage and low clamping
Moisture sensitivity level: level 1
Small package: SOD523
SOD523
Application information
Package (Top View)
High Speed Line: USB 1.0/2.0,VGA,DVI,SDI
Serial and Parallel Ports
Cellular handsets and accessories
Agency Approvals
Schematic Symbol
ICoN
RoHS
HF
Description
Compliance with 2011/65/EU
Compliance with IEC 61249-2-21:2003
Mean lead free
Part Number and Electrical Parameter
IDRM@VDRM
Part Number
uA
V
MAX
BV-D505ZC
1.0
VBR@IBR
V
VC@IPP①
mA
MIN
5.0
5.6
V
VC@IPP①
A
MAX
1.0
11.6
V
A
MAX
5.0
18.6
CO②
pF
MAX
10
15
Absolute maximum rating measured at T=25 C RH=45%-75% (unless otherwise noted).
①Surge Waveform: 8/20us;
②Off-state capacitance is measured in VBR=0V, f=1MHz;
1/4
www.bencent.com.cn
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
BV-D505ZC
Part Number System
BV
Mark
D505ZC
(1)
(2)
(1) Bencent
TVS
(2) Series: D505ZC etc.
5C: Marking
V-I Curve
Parameters
Definition
VC
Clamping voltage
IPP
Peak pulse current
VDRM
Stand-off Voltage
VBR
Breakdown Voltage
IDRM
Reverse Leakage Current
IR
Test current
PPP
Peak Pulse Power Dissipation
Thermal Considerations
Symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature Range
-55 to+150
TS
Storage Temperature Range
-55 to+150
Environmental Characteristics
Testing Items
High Temperature Reverse Bias Test
High Temperature Life Test
High-low Temperature Cycle Test
High Temperature & High Humidity Test
Pressure Cooker Test
Resistance of Soldering Heat
Technical Standards
Temperature:150±3℃,Bias=80%VDRM
Time:168H
Temperature:150℃
Time:168H
Temperature:From-40℃ to 125℃
Dwell time:30min,100 cycles
Temperature:85℃ Humidity:85%
Test time:168H
Temperature:121℃, 2atm. Humidity:100%
Test time:24H
Temperature:260±5℃
Time of dip soldering:10s, 3 times
Note: The above testing items can be specified by customers by contacting Bencent service
2/4
www.bencent.com.cn
BV-D505ZC
Product Dimensions
SOD523
Reflow Profile
Reflow Condition
Pre Heat
Temperature Min
150℃
Temperature Max
200℃
Time (Min to Max)
20 – 80 secs
Average ramp up rate (Liquid)
Temperature (TL)to peal
TS (Max) to Tl-Ramp-up Rate
Reflow
Pb-Free Assembly
-Temperature (TL)(Liquid)
-Temperature (TL)
Peak Temperature (TP)
Time within 5℃ of actual Peak
Temperature (TP)
3℃/s Max.
3℃/s Max.
217℃
60 –150 secs
(260+0/-5)℃
30 secs
Ramp-down Rate
6℃/s Max.
Time 25℃ to peak Temperature(TP)
8 min Max
Do not exceed
3/4
www.bencent.com.cn
260℃
BV-D505ZC
Package Reel Information
Outline
Taping
4/4
Reel
Per Carton
Reel Diameters
(pcs)
(pcs)
(mm)
L
W
H
3,000
90,000
178
390
370
220
www.bencent.com.cn
Carton Size (mm)
很抱歉,暂时无法提供与“BV-D505ZC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.41800
- 500+0.27830
- 2500+0.24200
- 5000+0.22000
- 国内价格
- 20+0.54980
- 200+0.44610
- 600+0.34230
- 5000+0.26970
- 10000+0.21790
- 国内价格
- 1+0.41660
- 10+0.34270
- 30+0.28190
- 100+0.25380
- 300+0.23140
- 5000+0.21790
- 国内价格
- 1+0.15001
- 100+0.14001
- 300+0.13001
- 500+0.12001
- 2000+0.11501
- 5000+0.11201
