BS0300N-C
BS0300N-C
    BENCENT(槟城)
    SMB(DO-214AA)
    晶闸管浪涌抑制器VT=4V SMB
BS0300N-C 数据手册
BS0300N-C Order Code: BS0300N-C Version: A0 2018-1-25 Thyristor Surge Suppresser Features Exterior Excellent capability of absorbing transient surge Quick response to surge voltage (nS Level) Eliminates overvoltage caused by fast rising transients Moisture sensitivity level: Level 1 Non degenerative SMB Application Information rmation Package (Top View) RS485/232/422 ` B03NC 1801 1 Agency Approvals 2 Schematic Symbol Icon Description Compliance with 2011/65/EU 2 1 Compliance with IEC61249-2-21:2003 Compliance with UL497B, Certificated E232249 Part Number and Electrical Parameter ① VS @ IS IDRM@ VDRM Part Number µA V MAX BS0300N-C 5 V VT@ IT mA MAX 25 40 V IH A MAX 800 4 2.2 CO ② mA pF MIN MAX 50 100 Absolute maximum ratings measured at TA= 25ºC RH = 45%-75% (unless otherwise noted). ① Vs is measured at 100KV/S ② Off-state capacitance is measured at VDC=2V, VRMS=1V, f=1MHz 1/4 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BS0300N-C Order Code: BS0300N-C Version: A0 2018-1-25 Thyristor Surge Suppresser Part Numbering System Mark BS 0300 N C (1) (2) (3) (4) B03NC B006U2G B42LC 1801 0909 0909 (1) Bencent Semiconductor Surge Arrester (2) Off-state Voltage, e.g.0300=30×100=30V (3) Package: SMB (4) Rating Surge Voltage: 6KV (10/700μs) B03NC: Part Number 1801: January, 2018 V-I Curve Parameters Definition VDRM Peak off-state voltage IDRM Off-state Current VS Switching Voltage IS Switching Current IH Holding Current VT On-state voltage IT On-state current CO Off-state capacitance +I IT IS IH IDRM -V +V VT VDRM VS -I Surge Ratings Current Waveform 5/320μs Voltage Waveform 10/700μs Ipp 150 -Peak pulse current rating (IPP) is repetitive and guaranteed for the life of the product; Thermal Considerations Symbol TJ TS 2/4 Parameter Operating Junction Temperature Range Storage Temperature Range www.bencent.com.cn Product Characteristics Characteristics Value Unit -40 to +125 ℃ Body Material -40 to +125 ℃ Terminal Finish Lead Material Copper Alloy UL recognized epoxy meeting flammability classification 94V-0 100% Matte-Tin Plated Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BS0300N-C Order Code: BS0300N-C Version: A0 2018-1-25 Thyristor Surge Suppresser Environmental Characteristics Testing items Technical standards High temperature Reverse Bias Test Temperature: 125±3℃, Bias=80%VDRM Time: 168H High Temperature Life Test Temperature: 125℃ Time: 168H High-low Temperature Cycle test Temperature: From -40℃ to125℃ Dwell time: 30min, 10cycles High Temperature &High Humidity Test Temperature: 85℃, Humidity: 85% Test time: 168H Pressure cooker Test Temperature: 121℃, 2atm, Humidity: 100% Test time: 24H Resistance of soldering heat Temperature: 260±5℃ Time of dip soldering: 10s, 3times Note: The above testing items can be specified by customer’s special request Product Dimensions REF mm inch A 1.85--2.15 0.073--0.085 B 3.4--3.8 0.134--0.15 C 4.3--4.9 0.169--0.193 D 2--2.6 0.079--0.102 E 0.15--0.3 0.006--0.012 F 0.80—1.50 0.031--0.059 G 0--0.4 0--0.016 H 5--5.6 0.197--0.220 Recommended Soldering Pad A B C 3/4 www.bencent.com.cn REF mm inch A 5.45 0.215 B 2.45 0.097 C 2.15 0.085 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BS0300N-C Order Code: BS0300N-C Version: A0 2018-1-25 Thyristor Surge Suppresser Reflow Profile Pre Heat Pb-Free assembly Temperature Min 150°C Temperature Max 200°C Time (min to max) 60 – 180 secs Average ramp up rate (Liquid) Tamp (TL) to peal TS(max) to TL - Ramp-up Rate - Temperature (TL) Reflow (Liquid) - Temperature (TL) Peak Temperature (TP) TP TP 3°C/second max 3°C/second max 217°C 60 – 150 seconds TL TS(max) Ramp-down Preheat TS(min) TS 260+0/-5 °C Time within 5°C of actual peak Temperature (TP) Critical Zone TL to TP Ramp-up TL Temperature Reflow Condition TL 25 secs 25 Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max. Do not exceed 260°C Time time to peak temperature Package Reel Information 4/4 REF mm inch A 3.75+/-0.3 0.148+/-0.012 B 5.65+/-0.3 0.222+/0-.012 d 1.5+/-0.15 0.059+/-0.006 D type330.0 type13.0 D1 100+/-3 3.937+/-0.118 D2 13+/-2 0.512+/-0.079 E 1.75+/-0.2 0.069+/-0.008 F 5.5+/-0.5 0.217+/-0.020 P 8.0+/-0.2 0.315+/-0.008 P0 4.0+/-0.2 0.157+/-0.008 P1 2.0+/-0.2 0.079+/-0.008 W 12.0+/-0.3 0.472+/-0.012 W1 18+/-4 0.709+/-0.157 OUTLINE REEL (PCS) PER CARTON (PCS) REEL DIAMETERS (mm) L W H TAPING 3,000 48,000 330 360 360 385 www.bencent.com.cn CARTON SIZE(mm) Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BS0300N-C 价格&库存
很抱歉,暂时无法提供与“BS0300N-C”相匹配的价格&库存,您可以联系我们找货
BS0300N-C
  • 1+0.84480
  • 200+0.58300
  • 1500+0.52910
  • 3000+0.49500
库存:8265
BS0300N-C
  • 20+0.67510
  • 200+0.63210
  • 500+0.58910
  • 1000+0.54610
  • 3000+0.52460
  • 6000+0.49450
库存:3044
