BV-SRV05-4
Order Code: BV-SRV05-4
Version: A2 2016-08-27
Transient Voltage Suppressor
Features
Exterior
IEC 61000-4-2(ESD)±15KV(air), ±10KV(contact)
Low leakage current 0.5Ua (Max) at 5V
Moisture sensitivity level:Level 1
Small package: SOT23-6
SOT23-6
SOT23-6
Application Information
Package (top view)
USB 2.0
` Video Graphics Cards
DVI
IEEE 1394
Monitors and Flat Panel Displays
Notebooks
10/100 Ethernet
V05
Agency Approvals
Schematic Symbol
Icon
Description
Compliance with 2011/65/EU
Compliance withIEC61249-2-21:2003
Part Number and Electrical Parameter
Part
Number
BV-SRV05-4
VBR@IR
IDRM@VDRM
μA
V
MAX
0.5
V
Vc@Ipp①
mA
MIN
5.0
6.0
V
A
MAX
1
15
5
CO②
CO③
pF
pF
MAX
MAX
1.8
1.0
Absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted).
①Surge Waveform: 8/20μ S.Pin 1,3,4,6 to Pin 2.
②Off-state capacitance is measured in VDC=0V, f=1MHz.Pin 1,3,4,6 to Pin 2.
③Off-state capacitance is measured in VDC=0V ,f=1MHz,any I/O to I/O.
1/4
www.bencent.com.cn
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
BV-SRV05-4
Part Numbering System
BV
Mark
SRV05-4
(1)
(2)
V05
(1) Bencent Transient Voltage Suppressor
(2) Series: SRV05-4 etc.
V05: Part Number
V-I Curve
I
Parameters
Definition
VC
Clamping Voltage
Ipp
Surge Waveform 8/20μ s
VDRM
Stand-off Voltage
VBR
Breakdown Voltage
IDRM
Reverse Leakage Current
IR
Test Current
Ppp
Peak Pulse Power Dissipation
IF
VC VBR
VDRM
VF
IDRM
IR
V
IPP
Thermal Considerations
symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature Range
-55 to+150
TS
Storage Temperature Range
-55 to+150
Environmental Characteristics
Testing items
High Temperature Reverse Bias Test
High Temperature Storage Test
High-low Temperature Cycle test
High Temperature &High Humidity Test
Pressure cooker Test
Resistance of soldering heat
Technical standards
Temperature: 150±5℃ Bias=80%VDRM .
Time:168H
Temperature: 150℃
Time:168H
Temperature: From -55℃ to125℃
Dwell time :30min,100cycles
Temperature: 85℃Humidity:85%
Time:168H
Temperature: 121℃,2atm. Humidity:100%
Time:24H
Temperature: 260±5℃
Time of dip soldering:10s,3times
Note: The above testing items can be specified by customer’s special request
2/4
www.bencent.com.cn
BV-SRV05-4
Product Dimensions
REF
mm
inch
A
1.25(max)
0.0492(max)
A1
0.000-0.150
0.0000-0.0059
A2
1.000-1.200
0.0394-0.0472
D
2.820-3.026
0.1110-0.1191
E
2.600-3.000
0.1024-0.1181
E1
1.500-1.750
0.0591-0.0689
e
0.900-1.000
0.0354-0.0394
e1
1.800-2.000
0.0709-0.0787
b
0.300-0.500
0.0118-0.0197
c
0.100(min)
0.0039(min)
Reflow Profile
Pre Heat
Pb-Free assembly
Temperature Min
150°C
Temperature Max
200°C
Time (Min to Max)
60 – 180 secs
TP
TP
Average ramp up rate(Liquid)
Tamp(TL) to peal
3°C/s Max
TS(max) to TL - Ramp-up Rate
3°C/s
Reflow
Max
- Temperature (TL) (Liquid)
217°C
- Temperature (TL)
60 – 150 secs
Peak Temperature (TP)
260+0/-5 °C
Time within 5°C of actual peak Temperature
(TP)
30secs
Ramp-down Rate
6°C/s
Time 25°C to peak Temperature (TP)
8 mins Max.
Do not exceed
260°C
3/4
www.bencent.com.cn
Max
Critical Zone
TL to TP
Ramp-up
TL
Temperature
Reflow Condition
TL
TS(max)
Ramp-down
Preheat
TS(min)
TS
25
time to peak temperature
Time
BV-SRV05-4
Package Reel Information
REF
mm
inch
A0
3.26±0.20
0.128±0.008
B0
3.30±0.20
0.130±0.008
t
0.20±0.02
0.008±0.001
K0
1.05±0.05
0.041±0.002
d
1.55±0.10
0.061±0.004
P
4.00±0.10
0.157±0.004
P0
4.00±0.10
0.157±0.004
P2
2.00±0.05
0.079±0.002
E
1.75±0.10
0.069±0.004
F
3.5±0.05
0.138±0.002
W
8+0.30/-0.10
0.315+0.012/-0.004
A
178±1.0
7.008±0.039
B
54.5REF
2.146REF
C
9.4±1.5
0.370±0.059
D
1.5±0.3
0.059±0.012
OUTLINE
REEL
(PCS)
PER CARTON
(PCS)
REEL
DIAMETERS
(mm)
L
W
H
TAPING
3000
90,000
178
390
370
220
4/4
www.bencent.com.cn
CARTON SIZE(mm)
很抱歉,暂时无法提供与“BV-SRV05-4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.64350
- 200+0.41470
- 1500+0.36190
- 3000+0.31900
- 国内价格
- 5+0.66960
- 50+0.57240
- 150+0.52920
- 500+0.47520
- 1500+0.43200
- 3000+0.41040
- 国内价格
- 10+0.28980
- 50+0.26820
- 200+0.25020
- 600+0.23220
- 1500+0.21780
- 3000+0.20880
