BV-SR05
BV-SR05
    BENCENT(槟城)
    SOT-143
    瞬态电压抑制器VC=25V IPP=5A SOT143
BV-SR05 数据手册
BV-SR05 Order Code: BV-SR05 Version: A1 2017-02-17 Transient Voltage Suppressor Features Exterior IEC 61000-4-2(ESD)±15KV(air), ±10KV(contact) IEC61000-4-5(Lightning) 5A (8/20μs) 125Watts peak pulse power per line (tp=8/20μs) Low leakage current 1 uA (Max)at 5V Low capacitance: 0.85 pF (Typical) Moisture sensitivity level:Level 1 Small package: SOT-143 SOT-143 Application Information ` Package (top view) USB Power & Data Line Protection Ethernet 10BaseT Bus Protection Video Line Protection T1/E1 secondary IC Side Protection ISDN S/T interface WAN/LAN Equipment Agency Approvals Schematic Symbol Icon Description Compliance with 2011/65/EU Compliance withIEC61249-2-21:2003 Mean lead free Part Number and Electrical Parameter Part Number BV-SR05 VBR①@IR IDRM@VDRM μA V MAX 1.0 V mA MIN 5.0 6.0 Vc@Ipp② V A V MAX 1.0 15.0 CO③ Vc@Ipp② A MAX 1.0 25.0 5.0 pF TYP MAX 0.85 1.20 Absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted). ①VBR is measured at IR=1mA; ②Surge Waveform: 8/20μ S.Pin 2, 3 to Pin 1; ③Off-state capacitance is measured in VDC=0V, f=1MHz. 1/5 www.bencent.com.cn ; Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BV-SR05 Order Code: BV-SR05 Version: A1 2017-02-17 Transient Voltage Suppressor Part Numbering System Mark BV SR05 (1) (2) (1) Bencent Transient Voltage Suppressor (2) Series: SR05 etc. R05: Part Number V-I Curve I Parameters Definition VC Clamping Voltage Ipp Surge Waveform 8/20μ s VDRM Stand-off Voltage VBR Breakdown Voltage IDRM Reverse Leakage Current IR Test Current VF Forward On-state Voltage Ppp Peak Pulse Power Dissipation IF VC VBR VDRM VF IDRM IR V IPP Thermal Considerations symbol Parameter Value Unit TJ Operating Junction Temperature Range -55 to+150 ℃ TS Storage Temperature Range -55 to+150 ℃ Environmental Characteristics Testing items High Temperature Reverse Bias Test High Temperature Storage Test High-low Temperature Cycle test High Temperature &High Humidity Test Pressure cooker Test Resistance of soldering heat Technical standards Temperature: 150±5℃ Bias=80%VDRM . Time:168H Temperature: 150℃ Time:168H Temperature: From -40℃ to125℃ Dwell time :30min,100cycles Temperature: 85℃Humidity:85% Time:168H Temperature: 121℃,2atm. Humidity:100% Time:24H Temperature: 260±5℃ Time of dip soldering:10s,3times Note: The above testing items can be specified by customer’s special request 2/5 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BV-SR05 Order Code: BV-SR05 Version: A1 2017-02-17 Transient Voltage Suppressor Product Dimensions SOT-143 3/5 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BV-SR05 Order Code: BV-SR05 Version: A1 2017-02-17 Transient Voltage Suppressor Reflow Profile Pre Heat Pb-Free assembly Temperature Min 150°C Temperature Max 200°C Time (Min toMax) 60 – 180 secs TP TP Average ramp up rate(Liquid) Tamp(TL) to peal 3°C/s Max TS(max) to TL - Ramp-up Rate 3°C/s Reflow Max - Temperature (TL) (Liquid) 217°C - Temperature (TL) 60 – 150 secs Peak Temperature (TP) 260+0/-5 °C Time within 5°C of actual peak Temperature (TP) 30secs Ramp-down Rate 6°C/s Max Time 25°C to peak Temperature (TP) 8 mins Max. Do not exceed 260°C Critical Zone TL to TP Ramp-up TL Temperature Reflow Condition TL TS(max) Ramp-down Preheat TS(min) TS 25 Time time to peak temperature Package Reel Information 4/5 www.bencent.com.cn REF mm inch A0 3.20±0.20 0.126±0.008 B0 2.80±0.20 0.110±0.008 t 0.20±0.02 0.008±0.001 K0 1.30±0.10 0.051±0.004 d 1.55±0.10 0.061±0.004 D1 1.00±0.10 0.039±0.004 P 4.00±0.10 0.157±0.004 P0 4.00±0.10 0.157±0.004 P2 2.00±0.05 0.079±0.002 E 1.75±0.10 0.069±0.004 F 3.5±0.05 0.138±0.002 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BV-SR05 Order Code: BV-SR05 Version: A1 2017-02-17 Transient Voltage Suppressor REF mm inch W 8+0.30/-0.10 0.315+0.012/-0.004 A 178±1.0 7.008±0.039 B 54.5REF 2.146REF C 9.4±1.5 0.370±0.059 D 1.5±0.3 0.059±0.012 OUTLINE REEL (PCS) PER CARTON (PCS) REEL DIAMETERS (mm) L W H TAPING 3000 90,000 178 390 370 220 5/5 www.bencent.com.cn CARTON SIZE(mm) Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BV-SR05 价格&库存
很抱歉,暂时无法提供与“BV-SR05”相匹配的价格&库存,您可以联系我们找货
BV-SR05
  • 1+0.43800
  • 100+0.40880
  • 300+0.37960
  • 500+0.35040
  • 2000+0.33580
  • 5000+0.32704
BV-SR05
  • 1+1.29200
  • 10+0.99200
  • 30+0.86390
  • 100+0.70440
  • 500+0.63340
  • 1000+0.59030
库存:4320
BV-SR05
  • 1+1.31350
  • 10+1.01013
  • 30+0.87999
  • 100+0.71777
  • 500+0.64552
  • 1000+0.60210
库存:2054
BV-SR05
    • 1+0.49830
    • 200+0.32230
    • 1500+0.27940
    • 3000+0.24750
    库存:3000
