1N5819W
1N5819W
    TWGMC(迪嘉)
    SOD-123
    二极管配置:独立式 直流反向耐压(Vr):40V 平均整流电流(Io):1A 正向压降(Vf):900mV@3A 反向电流(Ir):1mA@40V
1N5819W 数据手册
1N5817W THRU 1N5819W SCHOTTKY BARRIER RECTIFIERS PINNING PIN FEATURES DESCRIPTION M etal silicon junction, majority carrier conduction 1 Cathode G uarding for overvoltage protection 2 Anode L ow power loss, high efficiency H igh current capability 2 l ow forward voltage drop H igh surge capability 1 Top View F or use in low voltage, high frequency inverters, Marking Code: 1N5817W---SJ 1N5818W---SK 1N5819W---SJ free wheeling, and polarity protection applications Simplified outline SOD-123 and symbol MECHANICAL DATA Case: SOD-123 Terminals: Solderable per MIL-STD-750, Method 2026 Approx. Weight:16mg/0.00056oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Symbols 1N5817W 1N5818W 1N5819W Units Maximum Repetitive Peak Reverse Voltage V RRM 20 30 40 V Maximum RMS voltage V RMS 14 21 28 V Maximum DC Blocking Voltage V DC 20 30 40 V Maximum Average Forward Rectified Current I F(AV) 1 A Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed On Rated Load (JEDEC method) I FSM 25 A at 1 A at 3 A VF Parameter Maximum Instantaneous Forward Voltage 0.45 0.75 0.55 0.875 0.6 0.9 V Maximum Instantaneous Reverse Current at TA = 25°C Rated DC Reverse Voltage TA = 100°C IR 1 10 mA Typical Junction Capacitance Cj 110 pF T j , T stg -55 ~ +150 °C Storage and Operating Junction Temperature Range www.tw-gmc.com 1 1N5817W THRU 1N5819W Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 10 4 10 3 T J =125°C 10 2 T J =75°C 10 1 T J =25°C 10 0 0 Case Temperature (°C) Junction Capacitance ( pF) 5° C =2 TJ 12 5°C 0.5 TJ = Instaneous Forward Current (A) 80 100 500 1.0 0.2 0.1 0 0.1 0.2 0.4 0.3 0.5 0.6 0.7 8.3 ms Single Half Sine Wave (JEDEC Method) 25 20 15 10 05 00 1 10 100 50 20 10 1 10 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 30 200 0.1 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 60 Fig.4 Typical Junction Capacitance Fig.3 Typical Forward Characteristic 100 Number of Cycles at 50Hz www.tw-gmc.com 40 20 Percent of Rated Peak Reverse Voltage(%) 1 2 100 1N5817W THRU 1N5819W PACKAGE OUTLINE Plastic surface mounted package; 2 leads SOD-123 A D b E A1 C ∠ALL ROUND L1 E1 SOD-123 mechanical data A C D E E1 L1 b A1 max 1.3 0.22 1.8 2.8 3.9 0.45 0.7 0.2 min 0.9 0.09 1.5 2.5 3.6 0.25 0.5 max 51 8.7 71 110 154 18 28 min 35 3.5 59 98 142 10 20 UNIT ∠ mm 9° mil The recommended mounting pad size 2.0 (79) 1.2 (47) 1.2 (47) 1.2 (47) Unit: mm (mil) www.tw-gmc.com 1 3 8
1N5819W 价格&库存
很抱歉,暂时无法提供与“1N5819W”相匹配的价格&库存,您可以联系我们找货
1N5819W
  • 20+0.26750
  • 100+0.15960
  • 800+0.11170
  • 3000+0.07980
  • 6000+0.07580
  • 30000+0.07010
库存:7452
1N5819W
  • 1+0.36960
  • 200+0.12320
  • 1500+0.07689
  • 3000+0.06105
库存:7452
