1N5817WS THRU 1N5819WS
SCHOTTKY BARRIER RECTIFIERS
FEATURES
PINNING
DESCRIPTION
M etal silicon junction, majority carrier conduction
1
Cathode
G uarding for overvoltage protection
2
Anode
L ow power loss, high efficiency
PIN
H igh current capability
2
l ow forward voltage drop
H igh surge capability
1
F or use in low voltage, high frequency inverters,
Top View
Marking Code: 1N5817WS---SJ
1N5818WS---SK
1N5819WS---SL
free wheeling, and polarity protection applications
Simplified outline SOD-323 and symbol
MECHANICAL DATA
Case: SOD-323
Terminals: Solderable per MIL-STD-750, Method 2026
A pprox. Weight: 5.48mg / 0.00019oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Symbols
Parameter
1N5817WS 1N5818WS 1N5819WS
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
14
21
28
V
Maximum DC Blocking Voltage
V DC
40
V
Maximum Average Forward Rectified Current
I F(AV)
1
A
Peak Forward Surge Current, 8.3ms Single Half Sine-wave
Superimposed On Rated Load (JEDEC method)
I FSM
9
A
at 1 A
at 3 A
VF
Maximum Instantaneous Forward Voltage
0.45
0.75
0.55
0.875
0.6
0.9
V
Maximum Instantaneous Reverse Current at TA = 25°C
Rated DC Reverse Voltage
TA = 100°C
IR
1
10
mA
Typical Junction Capacitance
Cj
110
pF
T j , T stg
-55 ~ +150
°C
Storage and Operating Junction Temperature Range
www.tw-gmc.com
1
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
resistive or inductive load
0.0
25
75
50
100
125
150
10 4
10 3
T J =125°C
10 2
T J =75°C
10 1
T J =25°C
10 0
Case Temperature (°C)
80
100
5°
C
=2
TJ
12
5°C
0.5
Junction Capacitance ( pF)
500
0.2
0.1
0.2
0.4
0.3
0.5
0.6
0.7
8.3 ms Single Half Sine Wave
(JEDEC Method)
25
10
05
00
1
10
100
50
1
10
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
30
200
0.1
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
60
Fig.4 Typical Junction Capacitance
1.0
TJ =
Instaneous Forward Current (A)
Fig.3 Typical Forward Characteristic
100
Number of Cycles at 50Hz
www.tw-gmc.com
40
Percent of Rated Peak Reverse Voltage(%)
1
2
100
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323 mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.tw-gmc.com
1
3
8
很抱歉,暂时无法提供与“1N5819WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.15704
- 500+0.12906
- 3000+0.09180
- 6000+0.08252
- 24000+0.07442
- 51000+0.07010
- 国内价格
- 1+0.37620
- 200+0.12540
- 1500+0.07854
- 3000+0.06237
- 国内价格
- 20+0.27360
- 100+0.16310
- 800+0.11410
- 3000+0.08150
- 6000+0.07740
- 30000+0.07190
- 国内价格
- 20+0.14395
- 300+0.11830
- 1200+0.11653
- 3000+0.08415
