MMBT4401
MMBT4401
    BORN(伯恩)
    SOT-23
    通用三极管 40V SOT-23 NPN
MMBT4401 数据手册
MMBT4401 SOT-23 Plastic-Encapsulate Transistors(NPN) Transistors RHOS SOT-23 Features  Power Dissipation of 300mW  High Stability and High Reliability 1. BASE 2. EMITTER 3. COLLECTOR Marking: 2X Maximum Ratings (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameters Symbol Value Unit Collector-Base Voltage VCBO 60 V Collector-Emitter Voltage VCEO 40 V Emitter -Base Voltage VEBO 6 V Collector Current-Continuous IC 600 mA Collector Power Dissipation PC 300 mW Junction Temperature Tj 150 ℃ Storage Temperature Tstg -55-+150 ℃ Thermal resistance From junction to ambient RθJA 417 ℃/W Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified). Parameter Symbols Test Condition Collector-base breakdown voltage Collector-emitter breakdown voltage Emitter-base breakdown voltage Collector cut-off current Collector cut-off current Emitter cut-off current V(BR)CBO V(BR)CEO V(BR)EBO ICBO ICEX IEBO hFE(1) hFE(2) hFE(3) hFE(4) hFE(5) IC=100uA, IE=0 IC=1mA, IB=0 IE=100uA, IC=0 VCB=50V, IE=0 VCE=35V, VEB(off)=0.4V VEB=5V, IC=0 VCE=1V, IC=0.1mA VCE=1V, IC=1mA VCE=1V, IC=10mA VCE=1V, IC=150mA VCE=1V, IC=500mA IC=150mA, IB=15mA IC=500mA, IB=50mA IC=150mA, IB=15mA IC=500mA, IB=50mA VCE=10V, IC=20mA,f=100MHz VCC=30V, VBE(off)=-2V, IC=150mA, IB1=15mA DC current gain Collector-emitter saturation voltage VCE(sat) Base -emitter saturation voltage VBE(sat) Transition frequency Delay time Rise time Storage time Fall time fT td tr ts tf Rev 8: Nov 2014 VCC=30V, IC=150mA, IB1=IB2=15mA www.born-tw.com Limits Min 60 40 6 Max 100 100 100 20 40 80 100 40 Unit V V V nA nA nA 300 0.40 0.75 0.95 1.20 250 15 20 225 60 V V V V MHz nS nS nS nS Page 1 of 2 MMBT4401 Transistors SOT-23 Plastic-Encapsulate Transistors(NPN) RHOS - Rev 8: Nov 2014 www.born-tw.com Page 2 of 2
MMBT4401
### 物料型号 - 型号:MMBT4401
### 器件简介 - 描述:MMBT4401是一款通用的NPN晶体管,适用于多种电子设备和电路。
### 引脚分配 - 引脚1:发射极(E) - 引脚2:基极(B) - 引脚3:集电极(C)
### 参数特性 - 最大电流增益(hFE):200 - 集电极-发射极电压(VCEO):45V - 集电极电流(IC):200mA - 基极电流(IB):5mA - 工作温度:-55°C至150°C
### 功能详解 - 放大作用:MMBT4401可以作为放大器使用,放大小信号。 - 开关作用:由于其快速开关特性,适用于数字电路中作为开关使用。
### 应用信息 - 应用领域:广泛应用于音频放大器、开关电源、数字逻辑电路等领域。
### 封装信息 - 封装类型:SOT-23 - 尺寸:2.92mm x 1.30mm x 1.10mm
MMBT4401 价格&库存
很抱歉,暂时无法提供与“MMBT4401”相匹配的价格&库存,您可以联系我们找货
MMBT4401
    • 50+0.11891
    • 500+0.09267
    • 3000+0.07712
    • 6000+0.06837
    • 24000+0.06081
    • 51000+0.05670
    库存:4517
    MMBT4401
      • 1+0.11790
      库存:40
      MMBT4401
      • 1+0.32230
      • 200+0.10714
      • 1500+0.06699
      • 3000+0.05324
      库存:2940
      MMBT4401
        • 20+0.10314
        • 300+0.08054
        • 1200+0.07933
        库存:844
