DSS34
DSS34
    BORN(伯恩半导体)
    SOD-123FL
    肖特基二极管 Single VR=40V IF=3A IR=500μA SOD123FL
DSS34 数据手册
DSS32 - DSS310 Series SCHOTTKY SOD123FL Plastic-Encapsulate Schottky Barrier Rectifiers SOD-123FL ROHS Features  The plastic package carries Underwriters Laboratory     Flammability Classification 94V-0 Metal silicon junction,majority carrier conduction Low power loss,high efficiency High forward surge current capability High temperature soldering guaranteed: 250 C/10 seconds,0.375(9.5mm) lead length, 5 lbs. (2.3kg) tension Mechanical Data     SOD 123FL small outline plastic package Polarity: Color band denotes cathode end Epoxy UL: 94V-0 Mounting Position: Any Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. MDD Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Operating junction temperature range Storage temperature range Rev 8: Nov 2014 SYMBOLS DSS32 DSS33 DSS34 DSS35 DSS36 DSS37 DSS38 DSS39 DSS310 K32 K33 K34 K35 K36 K37 K38 K39 K310 20 14 20 30 21 30 40 28 40 50 35 50 60 42 60 70 49 70 80 56 80 90 63 90 100 70 100 UNITS I(AV) 3.0 VOLTS VOLTS VOLTS Amp IFSM 80.0 Amps VRRM VRMS VDC VF 0.52 0.55 IR TJ TSTG www.born-tw.com 0.70 0.85 0.5 10.0 20.0 -50 to +125 -50 to +150 -50 to +150 Volts mA C C Page 1 of 2 DSS32 - DSS310 Series SOD123FL Plastic-Encapsulate Schottky Barrier Rectifiers AVERAGE FORWARD RECTIFIED CURRENT, AMPERES SCHOTTKY PEAK FORWARD SURGE CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE 3 2.4 Single Phase Half Wave 60Hz Resistive or inductive Load 1.8 1.2 DSS32-DSS36 DSS37-DSS310 0.6 0 0 25 50 75 100 125 150 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 80 64 48 32 16 175 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 AMBIENT TEMPERATURE, C 20 10 1 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE DSS32-DSS34 DSS35-DSS36 DSS37-DSS310 0.1 0.01 0.2 0.4 0.6 0.8 1.0 1.1 10 100 NUMBER OF CYCLES AT 60 Hz FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS ROHS 100 10 TJ=100 C 1 TJ=75 C 0.1 0.001 INSTANTANEOUS FORWARD VOLTAGE, VOLTS TJ=25 C 0.01 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% SOD-123FL PACKAGE OUTLINE Plastic surface mounted package Rev 8: Nov 2014 www.born-tw.com Page 2 of 2
DSS34 价格&库存
很抱歉,暂时无法提供与“DSS34”相匹配的价格&库存,您可以联系我们找货
DSS34
  • 10+0.33310
  • 100+0.27980
  • 300+0.25230
  • 3000+0.17830
  • 6000+0.17060
  • 9000+0.16520
库存:500
DSS34
  • 10+0.31155
  • 100+0.26166
  • 600+0.23602
  • 1200+0.23248
  • 3000+0.16682
库存:13358
DSS34
    • 1+0.14510
    • 100+0.14130
    库存:1634
    DSS34
    • 10+0.33988
    • 100+0.28545
    • 300+0.25748
    • 3000+0.18198
    • 6000+0.17399
    • 9000+0.16848
    库存:217538
    DSS34
    • 1+0.31280
    • 200+0.20125
    • 1500+0.17595
    • 3000+0.15410
    库存:78082
