山东晶导微电子有限公司
US1AW THRU US1MW
Jingdao Microelectronics
SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 1 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• High efficiency
• Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
• Case: SOD-123FL
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight:15mg 0.00053oz
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: US1AW~US1DW: USL
US1GW: USM
US1JW~US1MW: USH
Simplified outline SOD-123FL and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
Parameter
US1AW US1BW
US1DW
US1GW
US1JW
US1KW US1MW
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Maximum Reverse Recovery Time (1)
Typical Thermal Resistance
Operating and Storage Temperature Range
1.3
1.65
5
100
IR
t rr
(2)
1.0
μA
75
50
V
ns
RθJA
85
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.01
SOD123FL-U-US1AW~US1MW-1A1KV
Page 1 of 3
山东晶导微电子有限公司
US1AW THRU US1MW
Fig.2 Typical Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
10
T J =25°C
1.0
US1AW~US1DW
US1GW
US1JW~US1MW
0.01
0.001
1.0
1.5
2.0
60
80
100
120
140
35
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
2.5
Instaneous Forward Voltage (V)
2016.01
40
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Typical Forward Characteristics
0.1
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
1
10
100
Number of Cycles
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
US1AW THRU US1MW
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123FL
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
g
pad
e
E
A
pad
HE
7°
The recommended mounting pad size
Marking
Type number
1.2
(47)
2.0
(79)
Marking code
US1AW
1.2
(47)
US1BW
USL
1.2
(47)
US1DW
US1GW
USM
US1JW
US1KW
Unit: mm
(mil)
2016.01
JD512264B6
USH
US1MW
Page 3 of 3
很抱歉,暂时无法提供与“US1DW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05476
- 500+0.04817
- 3000+0.04450
- 6000+0.04234
- 24000+0.04040
- 国内价格
- 50+0.06979
- 600+0.05534
- 1200+0.05451
- 3000+0.04732
- 15000+0.04257
- 30000+0.04214
