RS1A-RS1M SERIES
RECTIFIERS
SMA FAST SURFACE MOUNT RECTIFIERS
ROHS
FEATURES
Low cost
Diffused junction
Low Leakage
Low forward voltage drop
High current capability
Easily cleaned with Freon. Alcohol. Lsopropanol and similar
solvents
The plastic material carries U/L recognition 94V-O
MECHANICAL DATA
molded plastic
Case: JEDEC DO-214AC
Terminals: Axial leads. Solderable per MIL - STD - 750.
Method 2026
Polarity: Color band denotes cathode
Weight: 0.041 ounce. 1.15 grams
Mounting position: Any
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 ℃ ambient temperature unless otherwise specified.
Single phase. half wave. 60HZ. resistive or inductive load. For capacitive load. derate current by 20%
SYMBOL
RS1A
RS1B
RS1D
RS1G
RS1J
RS1K
RS1M
UNITS
Maximum Recurrent Peak Reverse Voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS Voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
VDC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified
Current at TL = 110℃
I(AV)
1.0
A
IFSM
30
A
VF
1.3
V
Peak Forward Surge Current
8.3ms Single half-sine-wave superimposed
on rated Tj = 125℃
Maximum Forward Voltage at 1.0A DC
Maximum Reverse Current
TA = 25℃
at Rated DC Blocking Voltage T A = 100℃
10
IR
μA
50
Maximum reverse recovery time(Note 1)
trr
Typical Junction Capacitance ( Note 2 )
Cj
15
pF
Typical Thermal Resistance ( Note 3 )
RQJA
55
℃/W
Tj
55 to 150
TSTG
55 to 150
Operating Junction Temperature Range
Storage Temperature Range
NOTE:
150
250
500
ns
1. Reverse revovery condition IF=0.5A IR=1.0A Irr=0.25A.
2. Measured at 1.0MHZ and applied reverse voltage of 4.0V DC.
3. Thermal Resistance Junction to Ambient.
Rev 8: Nov 2014
www.born-tw.com
112
Page 1 of 2
RS1A-RS1M SERIES
RECTIFIERS
ROHS
TYPICAL FORWARD CHARACTERISTIC
FORWARD CURRENT DERATING CURVE
MAXIMUM NON REPETITIVE PEAK FORWARD SURGE CURRENT
TYPICAL REVERSE CHARACTERISTICS
TYPICAL JUNCTION CAPACITANCE
Rev 8: Nov 2014
www.born-tw.com
112
Page 2 of 2
很抱歉,暂时无法提供与“RS1M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10444
- 1000+0.08197
- 2000+0.06950
- 5000+0.06197
- 国内价格
- 50+0.11394
- 500+0.08943
- 1500+0.07582
- 5000+0.06761
- 25000+0.06059
- 50000+0.05670
- 国内价格
- 1+0.31740
- 500+0.10580
- 2500+0.07038
- 5000+0.05785
- 国内价格
- 50+0.11180
- 500+0.08710
- 1500+0.07380
- 5000+0.06570
- 25000+0.05880
- 50000+0.05500
