山东晶导微电子有限公司
SS22 THRU SS220
Jingdao Microelectronics
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V
Forward Current - 2.0A
PINNING
PIN
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS22~SS220
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 60mg / 0.0021oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS22
SS24
SS26
SS28
SS210
SS212
SS215
SS220
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
2.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
50
A
Max Instantaneous Forward Voltage at 2 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
VF
0.55
0.70
0.85
0.3
3
0.5
5
IR
Cj
0.95
220
80
V
mA
pF
RθJA
80
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.11
SMA-S-SS22~SS220-2A200V
Page 1 of 3
山东晶导微电子有限公司
SS22 THRU SS220
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
T J =75°C
10 2
SS22/SS24
SS26-SS220
10
1
T J =25°C
10 0
Case Temperature (°C)
80
100
500
Junction Capacitance ( pF)
1.0
SS22/SS24
SS26/SS28
SS210/SS212
SS215/SS220
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
T J =25°C
200
100
50
SS22/SS24
SS26-SS220
10
1.8
0.1
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Transient Thermal Impedance( °C /W)
60
10
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
60
Fig.4 Typical Junction Capacitance
Instaneous Forward Voltage (V)
Fig.6- Typical Transient Thermal Impedance
100
Number of Cycles at 60Hz
2016.11
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
T J =100°C
10 3
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS22 THRU SS220
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
a
0.3
12
Marking
Type number
2.2
(86)
1.8
(71)
1.8
(71)
1.8
(71)
mm
Unit :
(mil)
2016.11
611294A0
Marking code
SS22
SS22
SS24
SS24
SS26
SS26
SS28
SS28
SS210
SS210
SS212
SS212
SS215
SS215
SS220
SS220
Page 3 of 3
很抱歉,暂时无法提供与“SS220”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25683
- 200+0.20499
- 600+0.17907
- 5000+0.15963
- 10000+0.14408
- 20000+0.13630
- 国内价格
- 20+0.23860
- 200+0.18590
- 600+0.16150
- 5000+0.14380
- 10000+0.12970
- 20000+0.12270
- 国内价格
- 5+0.22545
- 20+0.20520
- 100+0.18495
- 500+0.16470
- 1000+0.15525
- 2000+0.14850
- 国内价格
- 20+0.44850
- 100+0.26750
- 500+0.18720
- 5000+0.13370
- 10000+0.12710
- 50000+0.11760
- 国内价格
- 1+0.23650
- 500+0.15840
- 2500+0.13640
- 5000+0.12430
