山东晶导微电子有限公司
SS12F THRU SS120F
Jingdao Microelectronics
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V
Forward Current - 1.0 A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS12 — SS120
Simplified outline SMAF and symbol
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 27mg / 0 . 00095oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS12F
SS14F
SS16F
SS18F
SS110F
SS112F
SS115F
SS120F
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
1.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
30
A
Max Instantaneous Forward Voltage at 1 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance (2)
Operating Junction Temperature Range
Storage Temperature Range
VF
0.55
0.3
10
IR
Cj
0.70
110
0.85
0.90
V
0.2
5
0.1
2
mA
80
pF
°C/W
RθJA
95
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMAF-S-SS12F~SS120F-1A200V
Page 1 of 3
山东晶导微电子有限公司
SS12F THRU SS120F
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
10 3
T J =100°C
10 2
T J =75°C
10 1
T J =25°C
10
Case Temperature (°C)
80
100
Fig.4 Typical Junction Capacitance
500
Junction Capacitance ( pF)
1.0
SS12F/SS14F
SS16F/SS18F
SS110F/SS112F
SS115F/SS120F
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
100
50
SS12F/SS14F
SS16F-SS120F
10
1.8
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
T J =25°C
200
Instaneous Forward Voltage (V)
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Peak Forward Surage Current (A)
60
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
1000
100
10
Number of Cycles at 60Hz
2017.01
40
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS12F THRU SS120F
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
HE
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.2
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
47
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
e
E
A
pad
D
E
A
V M
7°
The recommended mounting pad size
Marking
Type number
2.2
(86)
1.6
(63)
1.8
(71)
1.6
(63)
mm
Unit :
(mil)
2017.01
612122A8
Marking code
SS12F
SS12
SS14F
SS14
SS16F
SS16
SS18F
SS18
SS110F
SS110
SS112F
SS112
SS115F
SS115
SS120F
SS120
Page 3 of 3
很抱歉,暂时无法提供与“SS110F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.09744
- 30+0.09396
- 100+0.09048
- 500+0.08352
- 1000+0.08004
- 2000+0.07795
- 国内价格
- 20+0.14926
- 200+0.11772
- 600+0.10023
- 3000+0.08975
- 9000+0.08068
- 21000+0.07582
- 国内价格
- 20+0.21210
- 100+0.12650
- 800+0.08850
- 3000+0.06330
- 6000+0.06010
- 30000+0.05570
