DSK12 THRU DSK120
Reverse Voltage - 20 to 200 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
PINNING
PIN
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
DESCRIPTION
1
Cathode
2
Anode
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
SOD-123FL
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
2
1
250 °C/10 seconds at terminals
Mechanical Data
Case: JEDEC SOD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,Method
2026 Polarity: Color band denotes cathode end
Mounting Position: Any
Weight : 0.0007 ounce, 0.02 grams
Unipolar
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
DSK12
DSK14
DSK15
DSK16
DSK18
DSK110
DSK115
DSK120
K12
K14
K15
K16
K18
K110
K115
K120
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
UNITS
V
V
V
Maximum average forward rectified current
at TL(see fig.1)
I(AV)
1.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
25
A
Maximum instantaneous forward voltage at 1.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
0.55
0.70
IR
CJ
RJA
10.0
5.0
80
110
0.95
0.1
2.0
V
mA
pF
100.0
℃/W
TJ
-55 to +125
TSTG
-55 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
www.tw-gmc.com
0.85
0.5
1
DSK12 THRU DSK120
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10 4
10 3
T J =100°C
10 2
T J =25°C
10 1
10 0
Fig.3 Typical Forward Characteristic
60
80
100
Fig.4 Typical Junction Capacitance
500
Junction Capacitance (pF)
1.0
DSK12/DSK14
DSK16/DSK18
DSK110/DSK112
DSK115/DSK120
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
200
100
50
DSK12/DSK14
DSK16-DSK120
10
1
0.1
100
10
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surge Current
Fig.6- Typical Transient Thermal Impedance
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
T J =25°C
1.8
Transient Thermal Impedance( °C / W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Case Temperature (°C)
Peak Forward Surge Current (A)
10
100
Number of Cycles at 60Hz
www.tw-gmc.com
1000
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2
100
DSK12 THRU DSK120
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123FL
∠ALL ROUND
C
A
∠ALL ROUND
HE
VM
g
g
pad
e
E
A
pad
D
E
A
Top View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
mil
Bottom View
7°
The recommended mounting pad size
1.2
(47)
2.0
(79)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.tw-gmc.com
3
很抱歉,暂时无法提供与“DSK14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10768
- 500+0.08819
- 3000+0.06228
- 6000+0.05575
- 24000+0.05013
- 51000+0.04701
- 国内价格
- 20+0.09870
- 300+0.08083
- 1200+0.07962
