ES1A THRU ES1J
Reverse Voltage - 50 to 600 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER
Features
PINNING
PIN
The plastic package carries Underwriters Laboratory
DESCRIPTION
1
Cathode
2
Anode
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated
placement High forward surge current capability
High temperature soldering guaranteed:
DO-214AC/SMA
250°C/10 seconds at terminals
2
1
Glass passivated chip junction
Mechanical Data
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002 ounce, 0.055 grams
Unipolar
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=55℃
VRRM
VRMS
VDC
I(AV)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
Maximum instantaneous forward voltage at 1.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
IR
TA=25℃
TA=125℃
ES1A
ES1B
ES1C
ES1D
ES1E
ES1G
ES1J
UNITS
50
35
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
600
420
600
V
V
V
1.0
A
30
A
0.95
1.25
5
50
1.7
V
uA
trr
35
ns
CJ
15.0
pF
Typical thermal resistance (NOTE 3)
RJA
60.0
℃/W
Operating junction and storage temperature range
TJ,TSTG
-55 to +150
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
www.tw-gmc.com
1
ES1A THRU ES1J
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
10 ohm
Noninductive
t rr
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
OSCILLOSCOPE
Note 1
NonInductive
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
300
1.2
1.0
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
0.8
0.6
0.4
0.2
Single phase half wave resistive or inductive
100
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
175
Case Temperature (°C)
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.5 Typical Junction Capacitance
1.0
ES1A~ES1D
ES1E/ES1G
0.1
ES1J
0.01
0.001
0.5
1.5
1.0
2.0
Peak Forward Surage Current (A)
35
30
25
10
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
10
100
Number of Cycles
www.tw-gmc.com
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
05
1
10
Reverse Voltage (V)
Fig.6 Maximum Non-Repetitive Peak
00
25
0.1
2.5
Instaneous Forward Voltage (V)
05
100
30
T J =25°C
60
% of PIV.VOLTS
Fig.4 Typical Forward Characteristics
10
40
100
ES1A THRU ES1J
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
2.4
(94)
1.8
(71)
1.8
(71)
1.8
(71)
mm
Unit :
(mil)
www.tw-gmc.com
3
a
0.3
12
很抱歉,暂时无法提供与“ES1J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07474
- 500+0.06048
- 2000+0.04536
- 4000+0.04061
- 24000+0.03651
- 50000+0.03435
- 国内价格
- 1+0.07337
- 50+0.03663
- 2000+0.02783
