DSK22 THRU DSK220
Reverse Voltage - 20 to 200 Volts
Forward Current - 2.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
PINNING
PIN
Features
DESCRIPTION
1
Cathode
2
Anode
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
SOD-123FL
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
2
1
250 °C/10 seconds at terminals
Mechanical Data
Case: JEDEC SOD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.0007 ounce, 0.02 grams
Unipolar
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
DSK22
DSK24
DSK25
DSK26
DSK28
DSK210
DSK215
DSK220
K22
K24
K25
K26
K28
K210
K215
K220
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
UNITS
V
V
V
Maximum average forward rectified current
at TL(see fig.1)
I(AV)
2.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
40
A
Maximum instantaneous forward voltage at 2.0A
VF
Maximum DCreverse current
at rated DCblocking voltage
IR
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
0.55
0.70
0.5
0.85
10.0
5.0
220
80
V
mA
pF
Typical thermal resistance (NOTE 2)
CJ
RJA
Operating junction temperature range
TJ
-55 to +125
TSTG
-55 to +150
Storage temperature range
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
www.tw-gmc.com
1
85.0
℃/W
DSK22 THRU DSK220
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10 4
DSK22/DSK24
DSK26-DSK220
10
1
T J =25°C
10 0
60
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
500
Junction Capacitance (pF)
1.0
DSK22/DSK24
DSK26/DSK28
DSK210/DSK212
DSK215/DSK220
0.1
0.2
0.6
0.8
1.0
1.2
1.4
1.6
100
50
DSK22/DSK24
DSK26-DSK220
10
0.1
10
1
100
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surge Current
Fig.6- Typical Transient Thermal Impedance
60
50
40
30
T J =25°C
200
1.8
Transient Thermal Impedance( °C / W)
Instaneous Forward Current (A)
T J =75°C
10 2
Case Temperature (°C)
Peak Forward Surge Current (A)
T J =100°C
10 3
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
www.tw-gmc.com
200
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2
100
DSK22 THRU DSK220
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123FL
∠ALL ROUND
C
A
∠ALL ROUND
HE
VM
g
g
pad
e
E
A
pad
D
E
A
Top View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
mil
Bottom View
7°
The recommended mounting pad size
1.2
(47)
2.0
(79)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.tw-gmc.com
3
很抱歉,暂时无法提供与“DSK26”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.15704
- 500+0.12788
- 3000+0.09288
- 6000+0.08316
- 24000+0.07474
- 51000+0.07020
- 国内价格
- 20+0.17999
- 200+0.16799
- 600+0.15599
- 3000+0.14399
- 国内价格
- 1+0.45760
- 200+0.15290
- 1500+0.09548
- 3000+0.07568
