山东晶导微电子有限公司
SS52B THRU SS520B
Jingdao Microelectronics
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200V
Forward Current - 5.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS52 ~ SS520
Simplified outline SMB and symbol
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS52B
SS54B
SS56B
SS58B
SS510B
SS512B
SS515B
SS520B
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
5.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
150
A
Max Instantaneous Forward Voltage at 5 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance (2)
Operating Junction Temperature Range
Storage Temperature Range
VF
0.55
IR
1.0
50
0.3
25
mA
Cj
500
300
pF
0.70
0.85
V
RθJA
50
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
(1)Measured at 1MHz and applied reverse voltage of 4 V D.C.
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMB -S-SS52B ~SS520B -5A200V
Page 1 of 3
山东晶导微电子有限公司
SS52B THRU SS520B
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
6.0
5.0
4.0
3.0
2.0
1.0
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
SS52B /SS56B
SS510B -SS520B
10 1
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1
SS52B /SS54B
SS56B /SS58B
SS510B /SS520B
0.1
1.0
1.5
100
SS52B /SS54B
SS54F/SS520F
SS56B -SS520B
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
150
125
100
75
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
500
Instaneous Forward Voltage (V)
175
25
1000
2.0
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
T J =25°C
10 0
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =75°C
10 2
Case Temperature (°C)
100
10
Number of Cycles at 60Hz
2017.01
T J =100°C
10 3
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS52B THRU SS520B
PACKAGE OUTLINE
SMB
A
A
Plastic surface mounted package; 2 leads
c
a
HE
VM
e
A
g
mil
e
e
E
A
D
E
HE
a
c
e
g
max
2.44
4.83
3.94
5.59
0.21
0.305
2.2
1.5
min
2.13
4.32
3.3
5.08
0.05
0.152
1.8
0.9
max
96
190
155
220
8.3
12
87
59
min
83
170
130
200
2.0
6
71
35
UNIT
mm
g
A
D
The recommended mounting pad size
Marking
Type number
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
2017.01
702227B0
Marking code
SS52B
SS52
SS54B
SS54
SS56B
SS56
SS58B
SS58
SS510B
SS510
SS512B
SS512
SS515B
SS515
SS520B
SS520
Page 3 of 3
很抱歉,暂时无法提供与“SS510B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.45144
- 100+0.36180
- 300+0.31698
- 3000+0.28329
- 6000+0.25640
- 9000+0.24300
- 国内价格
- 1+0.40920
- 200+0.26400
- 1500+0.22990
- 3000+0.20240
- 国内价格
- 10+0.39790
- 100+0.30766
- 600+0.26254
- 1200+0.25860
- 3000+0.22870
- 国内价格
- 10+0.43180
- 100+0.32990
- 300+0.28790
- 3000+0.25650
- 6000+0.23130
- 9000+0.21870
