山东晶导微电子有限公司
Jingdao Microelectronics
SS32 THRU SS320
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V
Forward Current - 3.0A
PINNING
PIN
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS32~SS320
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 60mg / 0.0021oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS32
SS34
SS34A
SS36
SS38
SS310
SS312
SS315
SS320
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
45
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
31.5
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
45
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
3.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
80
A
Max Instantaneous Forward Voltage at 3 A
VF
0.55
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
0.85
0.95
V
IR
0.5
5
0.3
3
mA
Cj
450
400
pF
Maximum DC Reverse Current T a = 25°C
at Rated DC Reverse Voltage
0.70
RθJA
70
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.11
SMA-S-SS32~SS320-3A200V
Page 1 of 3
山东晶导微电子有限公司
SS32 THRU SS320
Fig.2 Typical Reverse Characteristics
3.5
3.0
2.4
1.8
1.2
0.6
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
10 4
SS32-SS36
SS38-SS320
10
1
T J =25°C
10 0
80
100
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1.0
SS32/SS34
SS34A/SS38
SS310/SS312
SS315/SS320
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
500
200
100
SS32~SS38
SS32F~SS36F
SS310~SS320
SS38F~SS320F
10
1.8
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.5- Typical Transient Thermal Impedance
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
1000
Instaneous Forward Voltage (V)
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =75°C
10 2
Case Temperature (°C)
100
Number of Cycles at 60Hz
2016.11
T J =100°C
10 3
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS32 THRU SS320
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
a
0.3
12
SS26F
The recommended mounting pad size
Marking
Type number
SS22F
SS24F
2.2
(86)
mm
Unit :
(mil)
2016.11
SS32
SS32
1.8
(71)
1.8
(71)
1.8
(71)
Marking code
611295A0
SS34
SS34
SS34A
SS34A
SS36
SS36
SS38
SS38
SS310
SS310
SS312
SS312
SS315
SS315
SS320
SS320
Page 3 of 3
很抱歉,暂时无法提供与“SS34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.38550
- 100+0.23000
- 500+0.16100
- 5000+0.11500
- 10000+0.10920
- 50000+0.10120
- 国内价格
- 1+0.56430
- 500+0.18810
- 2500+0.12540
- 5000+0.10285
- 国内价格
- 20+0.24992
- 200+0.19710
- 600+0.16773
- 5000+0.14721
- 10000+0.13198
- 20000+0.12377
- 国内价格
- 20+0.24410
- 200+0.19210
- 600+0.16290
- 5000+0.14290
- 10000+0.12810
- 20000+0.12010
- 国内价格
- 20+0.22909
- 500+0.15375
- 2000+0.15144
- 5000+0.13494
