2R-4 SERIES
Gas Discharge Tube (GDT) Data Sheet
Features
■ Provide ultra-fast response to surge voltage from slow-rising
surge of 100V/s to rapid-rising surge of 1KV/μs.
■ Stable breakdown voltage.
■ High insulation resistance.
■ Low capacitance (≤1pF)
■ High holdover voltage
■ Large absorbing transient current capability.
■ Micro-Gap Design
■ Size: 4.2mm*4.0mm
■ Storage and operational temperature: -40℃ ~ +85℃
■ Meets MSL level 1, per J-STD-020
■ Safety certification: UL: E244458
Applications
Repeaters, Modems.
Telephone Interface, Line cards.
Data communication equipment.
Line test equipment
Part Number Code
Marking
Revision:15-Aug-14
www.brightking.com
2R-4 SERIES
Dimensions
Dimension (mm)
Symbol
Spec.
Tolerance
D
4.2
±0.5
T
4.0
±0.4
B
0.4
±0.1
d
3.9
±0.1
Electrical Characteristics
Part
Number
DC
Spark-over
Voltage
Maximum
Impulse
Spark-over
Voltage
Nominal
Impulse
Discharge
Current
Alternating
Discharge
Current
Impulse
Life
100V/s
1000V/μs
8/20μs
10times
50Hz,1sec
10/1000μs
100A
Test
Voltage
Minimum
Insulation
Resistance
Maximum
Capacitance
1MHz
Device
Marking
Code
(GΩ)
(V)
(V)
(KA)
(A)
(times)
DC(V)
2RK075M-4
75±20%
800
3
3
300
25
1
1.0
075
2RK090M-4
90±20%
800
3
3
300
50
1
1.0
090
2RK145M-4
145±20%
800
3
3
300
100
1
1.0
145
2RK230M-4
230±20%
700
3
3
300
100
1
1.0
230
2RK250M-4
250±20%
700
3
3
300
100
1
1.0
250
2RK300M-4
300±20%
800
3
3
300
100
1
1.0
300
2RK350M-4
350±20%
850
3
3
300
100
1
1.0
350
2RK400M-4
400±20%
900
3
3
300
100
1
1.0
400
2RK470M-4
470±20%
800
3
3
300
250
1
1.0
470
2RK600M-4
600±20%
1100
3
3
300
250
1
1.0
600
2RK800M-4
800±20%
1200
3
3
300
250
1
1.0
800
2RK1000M-4
1000±20%
1500
3
3
300
500
1
1.0
1000
2RK1200M-4
1200±20%
1900
3
3
300
500
1
1.0
1200
Revision:15-Aug-14
(pF)
www.brightking.com
2R-4 SERIES
Electrical Ratings
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Test Condition/Description
Requirement
The voltage is measured with voltage ramp dv/dt=100V/s.
The maximum impulse spark-over voltage is measured with voltage
ramp dv/dt=1000V/μs.
Maximum 8/20μs surge current that can be applied between two
electrodes, 5 positive and 5 negative surges, with 3 minutes interval
time, without causing the DC spark-over voltage to change more than
25% from its initial value.
Impulse
Discharge Current
To meet
the specified
value
Alternating
Discharge Current
Insulation
Resistance
Capacitance
Revision:15-Aug-14
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval
time 3 min. DC spark-over voltage shall not change more than ±25%
IR>108 ohms (-20%, +30% for 70~90V).
The resistance of gas tube shall be measured between two electrodes.
The capacitance of gas tube shall be measured between two electrodes.
Test frequency: 1MHz
www.brightking.com
2R-4 SERIES
Recommended Soldering Conditions
Reflow Soldering
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Revision:15-Aug-14
20-40 seconds
6℃/second max.
8 minutes max.
www.brightking.com
2R-4 SERIES
Packaging
Tape
Symbol
P2
P0
D0
P1
Spec.
Tolerance
W
16.00
±0.20
P0
4.00
±0.10
P1
12.00
±0.20
P2
2.00
±0.10
D0
1.55
±0.05
E
1.75
±0.10
F
7.50
±0.10
A0
4.27
±0.10
K0
5.20
±0.10
B0
4.45
±0.10
t
0.50
±0.10
D
330.00
±1.00
d
13.00
±0.50
L
20.00
±0.50
t
2.00
±0.20
E
t
F
W
B0
K0
A0
Reel
Dimension (mm)
Quantity: 900pcs
Revision:15-Aug-14
www.brightking.com
很抱歉,暂时无法提供与“2RK090M-4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.83823
- 100+0.77263
- 900+0.72889
- 国内价格
- 1+0.85800
- 10+0.79200
- 30+0.77880
- 100+0.73920
- 国内价格
- 1+0.78730
- 100+0.75620
- 500+0.72530
