WNM2024
WNM2024
Http://www.sh-willsemi.com
Single N-Channel, 20V, 3.9A, Power MOSFET
VDS (V)
Rds(on) (Ω)
0.027@ VGS=4.5V
0.031@ VGS=2.5V
0.036@ VGS=1.8V
SOT-23
Descriptions
D
3
The WNM2024 is N-Channel enhancement MOS
Field Effect Transistor. Uses advanced trench
technology and design to provide excellent RDS (ON)
with low gate charge. This device is suitable for use
in DC-DC conversion, power switch and charging
1
2
circuit. Standard Product WNM2024 is Pb-free and
G
S
Halogen-free.
Pin configuration (Top view)
Features
z
Trench Technology
z
Supper high density cell design
z
Excellent ON resistance for higher DC current
z
Extremely Low Threshold Voltage
z
Small package SOT-23
3
W24*
2
1
W24 = Device Code
= Month (A~Z)
Marking
Applications
z
Driver for Relay, Solenoid, Motor, LED etc.
z
DC-DC converter circuit
z
Power Switch
z
Load Switch
z
Charging
Will Semiconductor Ltd.
Order information
1
Device
Package
Shipping
WNM2024-3/TR
SOT-23
3000/Reel&Tape
2015/08/25 – Rev. 1.2
WNM2024
Absolute Maximum ratings
Parameter
Symbol
10 S
Steady State
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
±8
Continuous Drain Current a
Maximum Power Dissipation a
Continuous Drain Current b
Maximum Power Dissipation b
TA=25°C
TA=70°C
TA=25°C
TA=70°C
TA=25°C
TA=70°C
TA=25°C
TA=70°C
ID
PD
ID
PD
Unit
V
3.9
3.6
3.1
2.9
0.8
0.7
0.5
0.4
3.6
3.3
2.8
2.6
0.7
0.6
0.4
0.3
A
W
A
W
Pulsed Drain Current c
IDM
15
A
Operating Junction Temperature
TJ
150
°C
Lead Temperature
TL
260
°C
Storage Temperature Range
Tstg
-55 to 150
°C
Thermal resistance ratings
Parameter
Junction-to-Ambient Thermal Resistance a
Junction-to-Ambient Thermal Resistance b
Junction-to-Case Thermal Resistance
Symbol
t ≤ 10 s
Steady State
t ≤ 10 s
Steady State
Steady State
RθJA
RθJA
Typical
Maximum
120
145
132
168
145
174
158
202
60
75
RθJC
a
Surface mounted on FR4 Board using 1 square inch pad size, 1oz copper
b
Surface mounted on FR4 board using minimum pad size, 1oz copper
c
Repetitive rating, pulse width limited by junction temperature, tp=10µs, Duty Cycle=1%
d
Repetitive rating, pulse width limited by junction temperature TJ=150°C.
2
Unit
°C/W
WNM2024
Electronics Characteristics (Ta=25 C, unless otherwise noted)
o
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
OFF CHARACTERISTICS
Drain-to-Source Breakdown Voltage
BVDSS
VGS = 0 V, ID = 250uA
Zero Gate Voltage Drain Current
IDSS
VDS =16 V, VGS = 0V
Gate-to-source Leakage Current
IGSS
VDS = 0 V, VGS =±8V
VGS(TH)
VGS = VDS, ID = 250uA
V
1
uA
±100
nA
0.62
1.0
V
VGS = 4.5V, ID = 3.6A
27
36
VGS =-2.5V, ID =2.8A
31
41
VGS = 1.8V, ID = 2.0A
36
47
VDS = 5 V, ID =3.6A
10
ON CHARACTERISTICS
Gate Threshold Voltage
Drain-to-source On-resistance
Forward Transconductance
RDS(on)
gFS
0.4
mΩ
S
CHARGES, CAPACITANCES AND GATE RESISTANCE
Input Capacitance
CISS
1025
Output Capacitance
COSS
Reverse Transfer Capacitance
CRSS
Total Gate Charge
QG(TOT)
Threshold Gate Charge
QG(TH)
VGS =4.5 V, VDS =10 V,
0.66
Gate-to-Source Charge
QGS
ID = 3.6A
1.0
Gate-to-Drain Charge
QGD
3.3
Turn-On Delay Time
td(ON)
6.5
Rise Time
tr
VGS = 4.5 V, VDS = 6 V,
Turn-Off Delay Time
td(OFF)
I D=2.0A , RG=6 Ω
Fall Time
tf
VGS = 0 V, f = 1.0 MHz, VDS =
pF
125
10 V
120
12.0
nC
SWITCHING CHARACTERISTICS
11.5
ns
48
BODY DIODE CHARACTERISTICS
Forward Voltage
VSD
VGS = 0 V, IS = 1.5A
3
0.5
0.6
1.5
V
WNM2024
Typical Characteristics (Ta=25 C, unless otherwise noted)
o
IDS-Drain to Source Current(A)
IDS-Drain-to-Source Current (A)
VGS=2.5V ~5V
16
VGS=2.0V
12
8
VGS=1.5V
4
0.4
0.8
1.2
1.6
o
T=-50 C
16
o
T=125 C
12
o
T=25 C
8
4
2.0
0.5
VDS-Drain-to-Source Voltage(V)
2.0
2.5
3.0
Transfer characteristics
60
RDS(on)- On-Resistance (mΩ)
60
RDS(on)- On-Resistance(mΩ)
1.5
VGS-Gate-to-Source Voltage(V)
Output characteristics
50
40
VGS=2.5V
30
VGS=4.5V
10
50
ID=3.6A
40
30
4
6
8
10
12
14
1.5
16
2.0
2.5
3.0
3.5
4.0
4.5
IDS-Drain-to-Source Current(A)
On-Resistance vs. Drain current
On-Resistance vs. Gate-to-Source voltage
50
ID=3.6A, VGS=4.5V
40
30
-50
-25
75
50
o
Temperature( C)
VGS(TH) Gate Threshold Voltage (V)
60
100 125 150
On-Resistance vs. Junction temperature
0.8
ID=250uA
0.7
0.6
0.5
0.4
0.3
0.2
-50
-25
50
75 100 125 150
o
Temperature ( C)
Threshold voltage vs. Temperature
4
WNM2024
2000
1.5
ISD-Source to Drain Current(A)
F=1MHz
1600
1200
800
Ciss
Coss
Crss
400
4
6
8
VDS Drain-to-Source Voltage (V)
1.2
0.9
o
T=150 C
0.6
o
T=25 C
0.3
0.3
0.2
10
0.5
0.6
Body diode forward voltage
12
100
Limited by R DS(on)
I D - Drain Current (A)
10
Power (W)
0.4
VSD-Source-to-Drain Voltage(V)
Capacitance
8
TA = 25_C
6
4
10
100 μs
1 ms
1
10 ms
100 ms
0.1
1 s, 10 s
DC
2
TA = 25 °C
Single Pulse
0.1
1
10
100
0.01
0.1
600
Time (sec)
BVDSS Limited
1
10
V DS - Drain-to-Source Voltage (V)
100
Safe operating area
Single pulse power
2
Normalized Effective Transient
Thermal Impedance
C - Capacitance(pF)
VGS=0V
1
Duty Cycle = 0.5
0.2
Notes:
0.1
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
0.02
t1
t2
2. Per Unit Base = RthJA = 168_C/W
3. TJM − TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
10−4
10−3
10−2
10−1
1
Square Wave Pulse Duration (sec)
10
100
600
Transient thermal response (Junction-to-Ambient)
5
WNM2024
Package outline dimensions
SOT-23
Symbol
Dimensions in millimeter
Min.
Typ.
Max.
A
0.900
1.025
1.150
A1
0.000
0.050
0.100
A2
0.900
0.975
1.050
b
0.300
0.400
0.500
c
0.080
0.115
0.150
D
2.800
2.900
3.000
E
1.200
1.300
1.400
E1
2.250
2.400
2.550
e
e1
0.950TYP
1.800
1.900
L
2.000
0.550REF
L1
0.300
0.500
θ
0°
8°
6
很抱歉,暂时无法提供与“WNM2024-3/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.44095
- 100+0.43382
- 600+0.42948
- 1200+0.42089
- 3000+0.40826
- 国内价格
- 5+0.48104
- 50+0.47326
- 150+0.46808
- 国内价格
- 1+0.60610
- 200+0.39160
- 1500+0.34100
- 3000+0.30030
