WPM2019
WPM2019
Http://www.sh-willsemi.com
Single P-Channel, -20V, -0.73A, Power MOSFET
VDS (V)
Rds(on) (ȍ)
D
0.480@ VGS=̢4.5V
-20
0.620@ VGS=̢2.5V
S
0.780@ VGS=̢1.8V
G
SOT-523
Descriptions
The WPM2019 is P-Channel enhancement MOS
D
Field Effect Transistor. Uses advanced trench
3
technology and design to provide excellent RDS (ON)
with low gate charge. This device is suitable for use
in DC-DC conversion, power switch and charging
circuit. Standard Product WPM2019 is Pb-free and
Halogen-free.
1
2
G
S
Features
Pin configuration (Top view)
z
Trench Technology
z
Supper high density cell design
z
Excellent ON resistance for higher DC current
z
Extremely Low Threshold Voltage
z
Small package SOT-523
3
P9*
2
1
P9 =Device Code
= Month(A~Z)
Applications
Marking
z
Driver for Relay, Solenoid, Motor, LED etc.
z
DC-DC converter circuit
z
Power Switch
z
Load Switch
z
Charging
Will Semiconductor Ltd.
Order information
1
Device
Package
Shipping
WPM2019-3/TR
SOT-523
3000/Reel&Tape
2015/08/25 – Rev. 1.4
WPM2019
Absolute Maximum ratings
Parameter
Symbol
10 S
Steady State
Drain-Source Voltage
VDS
-20
Gate-Source Voltage
VGS
±5
Continuous Drain Current a
Maximum Power Dissipation a
Continuous Drain Current b
Maximum Power Dissipation b
TA=25°C
TA=70°C
TA=25°C
TA=70°C
TA=25°C
TA=70°C
TA=25°C
TA=70°C
ID
PD
ID
PD
Unit
V
-0.73
-0.62
-0.58
-0.50
0.38
0.28
0.24
0.18
-0.61
-0.55
-0.49
-0.44
0.27
0.22
0.17
0.14
A
W
A
W
Pulsed Drain Current c
IDM
-1.2
A
Operating Junction Temperature
TJ
150
°C
Lead Temperature
TL
260
°C
Storage Temperature Range
Tstg
-55 to 150
°C
Thermal resistance ratings
Parameter
Junction-to-Ambient Thermal Resistance a
Junction-to-Ambient Thermal Resistance b
Junction-to-Case Thermal Resistance
Symbol
t 10 s
Steady State
t 10 s
Steady State
Steady State
RșJA
RșJA
RșJC
Typical
Maximum
285
325
355
440
395
460
465
560
280
320
a
Surface mounted on FR4 Board using 1 square inch pad size, 1oz copper
b
Surface mounted on FR4 board using minimum pad size, 1oz copper
c
Repetitive rating, pulse width limited by junction temperature, tp=10μs, Duty Cycle=1%
d
Repetitive rating, pulse width limited by junction temperature TJ=150°C.
2
Unit
°C/W
WPM2019
Electronics Characteristics (Ta=25oC, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min
Typ
Max
Unit
OFF CHARACTERISTICS
Drain-to-Source Breakdown Voltage
BVDSS
VGS = 0 V, ID = -250uA
Zero Gate Voltage Drain Current
IDSS
VDS =-16 V, VGS = 0V
Gate-to-source Leakage Current
IGSS
VDS = 0 V, VGS = ±5V
VGS(TH)
VGS = VDS, ID = -250uA
-20
V
-1
uA
-5
uA
-0.65
-0.90
V
VGS = -4.5V, ID = -0.45A
480
810
VGS = -2.5V, ID = -0.35A
620
1050
VGS = -1.8V, ID = -0.25A
780
1300
VDS = -5 V, ID =-0.45A
1.25
ON CHARACTERISTICS
Gate Threshold Voltage
Drain-to-source On-resistance
Forward Transconductance
R DS(on)
gFS
-0.40
m
S
CHARGES, CAPACITANCES AND GATE RESISTANCE
Input Capacitance
CISS
74.5
Output Capacitance
COSS
Reverse Transfer Capacitance
CRSS
10.2
Total Gate Charge
QG(TOT)
1.8
Threshold Gate Charge
QG(TH)
VGS = -4.5 V, VDS = -10 V,
0.12
Gate-to-Source Charge
QGS
ID = -0.45A
0.18
Gate-to-Drain Charge
QGD
VGS = 0 V, f = 100KHz, VDS =
pF
10.8
-10 V
nC
0.74
SWITCHING CHARACTERISTICS
Turn-On Delay Time
td(ON)
45
Rise Time
tr
140
Turn-Off Delay Time
td(OFF)
ID=-0.45A, RG=6
1500
Fall Time
tf
ns
2100
BODY DIODE CHARACTERISTICS
Forward Voltage
VSD
VGS = 0 V, IS = -0.15A
3
-0.50
-0.65
-1.50
V
WPM2019
Typical Characteristics (Ta=25oC, unless otherwise noted)
1500
VGS= -2.5 ~ -5V
VGS= -2.0V
VDS= -5V
-IDS - Drain Current (A)
-IDS_Drain to Source Current (A)
2.0
1.5
VGS= -1.5V
1.0
0.5
1200
1
2
3
4
T=25 C
600
300
T=125 C
0.0
T=-50 C
900
5
0.3
-VDS_Drain to Source Voltage (V)
RDS(on)- On-Resistance (m:)
800
VGS=-2.5V
600
VGS=-4.5V
400
0.6
1.2
1.5
1.8
Transfer characteristics
1000
0.4
0.9
-VGS - Gate to Drain Voltage (V)
Output characteristics
200
0.2
0.6
0.8
1400
IDS=-0.45A
1200
1000
800
600
400
200
1.0
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
-VGS-Gate to Source Voltage(V)
IDS-Drain to Source Current (A)
On-Resistance vs. Gate-to-Source voltage
On-Resistance vs. Drain current
-VGS(TH) - Threshold Voltage (V)
700
VGS=-4.5V IDS=-0.45A
600
500
400
300
-50
100
150
IDS= -250uA
0.5
0.4
0.3
-25
Temperature ( C)
50
75
100
125
150
Temperature ( C)
On-Resistance vs. Junction temperature
0.6
Threshold voltage vs. Temperature
4
WPM2019
250
-ISD - Source to Drain Current (A)
120
90
60
Cin
Cout
Crss
30
4
6
8
200
T=125 C
150
T=25 C
100
50
0.4
10
0.5
0.6
0.7
0.8
0.9
-VSD - Source to Drain Voltage(V)
-VDS - Drain to Source Voltage (V)
Capacitance
Body diode forward voltage
10.00
14
TJ(Max)=150°C, TA=25°C
TJ(Max)=150°C
TA=25°C
12
-ID (Amps)
10
Power (W)
8
6
4
1.00
100μs
1ms
RDS(ON)
limited
0.10
10ms
2
0.1s
DC
0.001
0.01
0.1
1
10
1s
10s
0.01
100
0.1
Pulse Width (s)
1
10
10
100
-VDS (Volts)
Safe operating power
Single pulse power
Zθ JA Normalized Transient
Thermal Resistance
C-Capacitance (pF)
VGS=0
f=100KHZ
D=Ton/T
TJ,PK=TA+PDM.ZθJA.RθJA
RθJA=440°C/W
In descending order
D=0.5, 0.3, 0.1, 0.05, 0.02, 0.01, single pulse
1
PD
0.1
Ton
T
Single Pulse
0.01
0.00001
0.0001
0.001
0.01
0.1
1
10
100
1000
Transient thermal response (Junction-to-Ambient)
5
WPM2019
Package outline dimensions
SOT-523
Symbol
Dimensions in millimeter
Min.
Typ.
Max.
A
0.700
0.800
0.900
A1
0.000
0.050
0.100
A2
0.700
0.750
0.800
b1
0.150
0.200
0.250
b2
0.250
0.300
0.350
c
0.100
0.150
0.200
D
1.500
1.600
1.700
E
0.700
0.800
0.900
E1
1.450
1.600
1.750
e
e1
0.500TYP
0.900
1.000
L
1.100
0.400REF
L1
0.260
0.460
0e
8e
6
很抱歉,暂时无法提供与“WPM2019-3/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48341
- 100+0.40047
- 300+0.35910
- 国内价格
- 10+0.43865
- 100+0.36338
- 国内价格
- 1+0.48400
- 200+0.31240
- 1500+0.27060
- 3000+0.23980
