SDT23C24L02
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
Brightking’s SDT23C24L02 component is designed to protect sensitive
electronics from damage or latch-up due to ESD and other voltage
induced transient events. It is designed for use in applications where
board space is at a premium. The device will protect up to two lines.
It is bidirectional devices and may be used on lines where the signal
polarities are above ground. TVS diodes are solid state device designed
specifically for transient suppression. It feature large cross-sectional
area junctions for conduction high transient currents. It offer desirable
characteristics for board level protection including fast response time,
low and clamping voltage, and no device degradation.The device may
be used to meet the immunity requirements of IEC61000-4-2, level 4.
The size SOT-23 package makes them ideal for use in portable electronics
such as RS-422 I/Os, RS-232 I/Os, notebook computers, and servers.
Features
IEC61000-4-2 ESD 15KV Air, 8KV contact compliance
SOT-23 surface mount package
Protects bidirectional two I/O lines
Peak power dissipation of 350W under 8/20μs waveform
Working voltage: 24V
Low leakage current
Low operating and clamping voltages
Solid-state silicon avalanche technology
Lead Free/RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
Marking: C24
Pin Configuration
Applications
RS-232 and RS-422 data lines
Microprocessor based equipment
LAN/WAN equipment
Desktops PC and serves
Notebook, Laptop and Palmtop computers
Set Top Box
Peripherals
Serial and Parallel ports
Maximum Ratings
Rating
Peak pulse power (tp=8/20μs waveform)
ESD voltage (Contact discharge)
ESD voltage (Air discharge)
Storage & operating temperature range
Revision:10-Jun-15
Symbol
Value
Unit
PPP
350
W
VESD
TSTG ,TJ
±8
±15
-55~+150
kV
www.brightking.com
SDT23C24L02
Electrical Characteristics (TJ=25℃)
Parameter
Symbol
Reverse stand-off voltage
Condition
Min.
Typ.
VRWM
Reverse breakdown voltage
Max.
Unit
24
V
VBR
IBR=1mA
26.7
V
Reverse leakage current
IR
VR=24V
Each I/O pin
1
μA
Clamping voltage (tp=8/20μs)
VC
IPP=1A
43
V
VC
IPP=5A
52
V
Off state junction capacitance
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
40
pF
Typical Characteristics Curves
Figure 1. Power Derating Curve
Figure 2. Pulse Waveforms
110
100
Peak Power Dissipation (%)
100
90
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
80
70
70
60
60
50
50
40
40
30
30
10
tr
50
75
100
125
150
TA-Ambient Temperature (℃)
10
15
30
t-Time (μs)
Figure 4. Normalized Capacitance vs. Reverse Voltage
Junction Capacitance (pF)
Figure 3. Non-Repetitive Peak Pulse vs. Pulse Time
td=t|IPP/2
Revision:10-Jun-15
www.brightking.com
SDT23C24L02
Recommended Soldering Conditions
Reflow Soldering
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Revision:10-Jun-15
20-40 seconds
6℃/second max.
8 minutes max.
www.brightking.com
SDT23C24L02
Dimensions (SOT-23)
Dimension
Symbol
Millimeters
Inches
Min.
Max.
Min.
Max.
A
0.08
0.18
0.003
0.007
B
0.15
0.006
C
0.13
0.005
D
0.89
1.09
0.035
0.043
E
2.80
3.05
0.110
0.120
F
1.90
0.075
G
0.95
0.037
H
1.19
1.40
0.047
0.055
I
2.10
2.49
0.083
0.098
J
0.35
0.50
0.014
0.020
Packaging
Tape
Reel
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.00±0.05
E
1.75±0.10
F
3.50±0.10
A
3.10±0.10
A0
2.10±0.10
B
2.75±0.10
B0
0.65±0.10
K
1.10±0.10
t
0.20±0.05
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
Quantity: 3000PCS
Revision:10-Jun-15
www.brightking.com
很抱歉,暂时无法提供与“SDT23C24L02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.62920
- 200+0.40480
- 1500+0.35310
- 3000+0.31240
- 国内价格
- 20+1.04080
- 100+0.77840
- 800+0.60350
- 3000+0.43730
- 6000+0.41540
- 30000+0.38480
- 国内价格
- 5+0.72490
- 50+0.58385
- 150+0.51322
- 500+0.46030
- 3000+0.40922
- 6000+0.38805
- 国内价格
- 1+0.65778
- 10+0.64791
- 100+0.52979
- 国内价格
- 5+0.71930
- 50+0.57360
- 150+0.50410
- 500+0.45130
- 3000+0.40100
- 6000+0.38030
