SDD32C18L01
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
Brightking’s SDD32C18L01 is designed to protect voltage sensitive
components from ESD and transient voltage events. Excellent clamping
capability, low leakage, and fast response time, make these parts
ideal for ESD protection on designs where board space is at a premium.
Because of its small size, it is suited for use in cellular phones, portable
devices, digital cameras, power supplies and many other portable
applications.
It is designed to protect sensitive semiconductor components from
damage or upset due to electrostatic discharge(ESD), electrical fast
transients(EFT), and cable discharge events(CDE).
Features
IEC61000-4-2 ESD 15KV Air, 8KV contact compliance
SOD-323 surface mount package
Protects bi-directional line
Peak power dissipation of 320W under 8/20μs waveform
Working voltage: 18V
Low leakage current
Low clamping voltage
Solid-state silicon avalanche technology
Lead Free/RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
Marking: 2K
Pin Configuration
Applications
Cellular handsets & Accessories
Cordless phones
Personal digital assistants (PDAs)
Notebooks & Handhelds
Portable instrumentation
Digital cameras
Peripherals
MP3 players
Maximum Ratings
Rating
Peak pulse power (tp=8/20μs waveform)
ESD voltage (Contact discharge)
ESD voltage (Air discharge)
Storage & operating temperature range
Revision:16-Jul-15
Symbol
Value
Unit
PPP
320
W
VESD
TSTG ,TJ
±8
±15
-55~+150
kV
www.brightking.com
SDD32C18L01
Electrical Characteristics (TJ=25℃)
Parameter
Reverse stand-off voltage
Reverse breakdown voltage
Symbol
Condition
Min.
Typ.
VRWM
Max.
Unit
18
V
VBR
IBR=1mA
V
Reverse leakage current
IR
VR=18V
1
μA
Clamping voltage (tp=8/20μs)
VC
IPP=1A
29
V
VC
IPP=5A
40
V
Off state junction capacitance
CJ
0Vdc,f=1MHz
40
pF
Typical Characteristics Curves
Figure 1. Power Derating Curve
Figure 2. Pulse Waveform
110
100
tr
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
70
60
50
40
td=t|PP/2
30
10
15
30
t-Time (μs)
Junction Capacitance (pF)
Figure 3. Capacitance vs. Reverse Voltage
Revision:16-Jul-15
www.brightking.com
SDD32C18L01
Recommended Soldering Conditions
Reflow Soldering
Recommended Condition
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Revision:16-Jul-15
20-40 seconds
6℃/second max.
8 minutes max.
www.brightking.com
SDD32C18L01
Dimensions (SOD-323)
G
E
Dimension
Symbol
X
H
1
2
F
A
D
B
C
detail X
Millimeters
Inches
Min.
Max.
Min.
Max.
A
0.80
1.10
0.031
0.043
B
0.10
0.004
C
0.20
0.008
D
0.11
0.20
0.004
0.008
E
1.15
1.35
0.045
0.053
F
0.35
0.014
G
1.60
1.80
0.063
0.071
H
2.40
2.60
0.094
0.102
Packaging
F
B0
B
Reel
W
E
Tape
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.00±0.05
E
1.75±0.10
F
3.50±0.10
A
1.48±0.10
A0
0.80±0.10
B
3.00±0.10
B0
1.80±0.10
K
1.05±0.10
t
0.25±0.05
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
Quantity: 3000PCS
Revision:16-Jul-15
www.brightking.com
很抱歉,暂时无法提供与“SDD32C18L01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.40810
- 200+0.26400
- 1500+0.22880
- 3000+0.20240
- 国内价格
- 20+0.97850
- 100+0.58370
- 800+0.40860
- 3000+0.29190
- 6000+0.27730
- 30000+0.25680
- 国内价格
- 10+0.41829
- 100+0.33210
- 300+0.28901
- 3000+0.24171
- 国内价格
- 10+0.38343
- 100+0.30442
- 600+0.26492
- 1200+0.26095
- 3000+0.22156
