B3
3D090M
M-C
O
Order Code: B3D0900M-C
Verrsion: A7 2015-08-31
Gass Dischargee Tube
Feaatures
Ex
xterior
Su
urface Mounting Design 7.8×5.0×6.0m
7
mm
H
High
Current Handling
H
Cap
pability 10,00
00A @ 8/20μs
Low Capacitan
nce and Inserrtion Loss
Q
Quick
Response and Long Service Life
M
Moisture
sensiitivity level:Level 1
Application innformation
SMD
Paackage (Topp View)
R
RS485/232/4
22
` E
Ethernet
Ageency Approovals
Scchematic Syymbol
Icon
1
3
2
Description
n
Compliaance with 2011/65/EU
1
3
Compliancee with IEC61
1249-2-21:200
03
Mean lead frree
2
UL Certificated
C
E
E232249
Electrical Paraameter
DC
C Breakdown
n Voltage 1)2) 4)4
100V/s
72-108
for 99
9 % of measu
ured values
At 100V/μs
Typiical values off distribution
Im
mpulse Spark-o
over Voltage4)4
for 99
9 % of measu
ured values
A 1kV/μs
At
Im
mpulse Dischaarge Current
5
5)
≤ 450
≤ 350
≤ 600
≤ 500
V
V
V
V
8/20μs ±5 timees
10,000
A
10/350μs 1 tim
me
1,000
A
10/1000
0 μs ±150 times
t
200
A
10A,1S
10
Timees
5)
A Dischargge Current
AC
4)
Arc Volltage
At 1A
~10
V
4)
DC=50V
≥1
GΩ
Ω
4)
V
VDC=0.5V
≤1.5
pF
F
~1.12
g
-40-90
Insulation Resistance
R
Capacitance at 1MHz
Weigght
O
Operating
An
nd Storage
Temperrature
Mark
king
1/4
V
www.b
bencent.ccom.cn
Benccent Logo YY
Y MM B3D09
90M-C(YY:year
of production,M
p
MM:month
h of productio
on)
S
Specifications
aare subject to ch
hange without notice.
n
Customers should verify actuaal device perforrmance in their specific applications
B3
3D090M
M-C
O
1)) At delivery AQL 0.65 levvel II GB/T 2828.1-2003
2
2)) In ionized mode
m
3)) Terms and waveforms
w
in
n accordance with ITU-T Rec.
R K. 12 an
nd IEC 61643
3-21
4)) Tip electrod
de “1”or “3”to
o center electtrode “2”
5)) Total Currents through center
c
electrode 2, half vallue through each Tip electtrode“1” “3”..
Paart Numberring System
m
Product Chharacteristics
B3D
D
090
M
-C
(1)
(2)
(3)
(4)
S
Gas Discharge
D
T
Tube
(1) Bencent 3--Electrode SMD
×5.0×6.0mm
7.8×
(2)
Lead Material
Copp
per
Body Materrial
Ceram
mics
Terminal Finnish
100% Matte--Tin Plated
0V
DC Breakdown Voltage, e.g., 090=90
A(Total Imp
pulse
(3) Surge Ratingg @8/20μs, M=10,000A
Disccharge Current 10,000A @ 8/20μs)
(4)
“ -C ” Means it is Su
uitable for High-Speed
H
S
SMT
Envvironmentall Reliabilityy Characteriistics
T
Testing
items
Technnical standardds
Temperaature: 90℃
Time:2H
H
Temperaature: -40℃
Time:2H
H
Frequenccy:10-500H
Hz
Amplitudde:0.15mm
m
Time:445min
Temperaature: 260±5℃
Time of dip soldering
g:10s,1tim
me
Hiigh Temperatuure Storage Test
T
Loow Temperatuure Storage Test
T
Vibbration
Reesistance of sooldering heatt
Notte: Up-screenn program cann be specifiedd by customerr’s request viia contacting Bencent servvice
Sollderability Test
T
Soldderability
S
Solder
Pot Tem
mperature:
2455℃±5℃
Solder Dweell Time:
4-66 seconds
Prooduct Dimennsions
A
B
C
D
H
Coplanariity≤0.15mm
m
2/4
www.b
bencent.ccom.cn
E
F
G
REF
mm
inch
A
7.8±0.3
3
0.307±0.012
B
0.5±0.2
2
0.020±0.008
C
1.6±0.2
2
0.063±0.008
D
0.5±0.2
2
0.020±0.008
E
5.0±0.2
2
0.197±0.008
F
5.0±0.2
2
0.197±0.008
G
6.0±0.3
3
0.236±0.012
H
4.7±0.2
2
0.185±0.008
S
Specifications
aare subject to ch
n
B3
3D090M
M-C
O
Reccommendedd Soldering Pad
A
B
C
REF
mm
inch
A
9.6
0.378
B
1.5
0.059
C
1.5
0.059
D
5.0
0.197
D
Refflow Profilee
Reflow
w Condition
Heaat
Temperrature Min
150°C
C
Temperrature Max
200°C
C
Time (min to max)
60 – 180 secs
Aveerage ramp up rate(Liquids)
r
Tamp
(T
TL) to peal
TS(max)
to TL - Raamp-up Rate
- Teemperature (TL)
Refflow
(Liquids)
- Teemperature (TL)
Peaak Temperature (TP)
Tim
me within 5°C of
o actual peak
Tem
mperature (tp)
tP
TP
3°C/ssecond max
3°C/ssecond max
C
217°C
60 – 150 seconds
TL
TS(max)
Ramp-down
Preheat
TS(min)
tS
260+
+0/-5 °C
~10 seconds
s
Ram
mp-down Rate
6°C/ssecond max
Tim
me 25°C to peakk Temperature (T
( P)
8 minnutes Max.
Do not exceed
260°C
C
Criticaal Zone
TL to TP
Raamp-up
TL
p
Temperature
Pree
Pb--Free assembly
25
t
time
to peak temper ature
Time
Rem
marking:it’ss only suitab
ble for SMT manufacture
m
e, not for ma
anual welding.
3/4
www.b
bencent.ccom.cn
S
Specifications
aare subject to ch
n
B3
3D090M
M-C
O
Paackage
4/4
Reeel
Inform
mation
REF
F
m
mm
inch
A0
4±0.2
0.331±0.0
008
B0
5.4
4±0.2
0.216±0.0
008
P0
4.0
0±0.2
0.157±0.00
08
P1
8.0
0±0.2
0.315±0.00
08
P2
2.0
0±0.2
0.079±0.00
08
E
1.75
5±0.2
0.069±0.00
08
F
7.5
5±0.2
0.295±0.00
08
K0
3±0.2
0.248±0.00
08
T
0.5
5±0.2
0.020±0.00
08
G
2
0.079
D0
Φ1..5±0.2
Φ0.059±0.0
008
W
16.0
0±0.3
0.630± 0.0
012
D
Φ3
330.0
Φ13.0
D1
Φ50Min
Φ1.97Min
n
D2
2
Φ13±0.5
Φ0.512±0.0
020
W1
1
16.8
8±0.5
0.661±0.02
Outline
Reel
(PCS)
Per Carrton
(PCS
S)
Reel Diameter (mm)
TAPING
G
1,000
16,00
00
330
www.b
bencent.ccom.cn
Carton Size(mm)
S
L
W
H
36
60
36
60
38
85
S
Specifications
aare subject to ch
n
很抱歉,暂时无法提供与“B3D090M-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.25960
- 10+4.15800
- 30+3.59640
- 100+3.05640
- 500+2.73240
- 国内价格
- 1+4.82130
- 10+3.81150
- 200+3.77338
- 400+3.69791
- 1000+3.58697
