BZT52CxxxS Series
200mW Surface Mount Zener
Diodes - 2.4V-51V
Package outline
Features
• Silicon epitaxial planar chip structure.
• Wide zener reverse voltage range 2.4V to 51V.
• Small package size for high density applications.
• Ideally suited for automated assembly processes.
• Pb-free package is available
• We declare that the material of product compliance
with RoHS requirements.
0.071(1.80)
0.063(1.60)
• Compliant to Halogen-free
0.016(0.40)
0.010(0.25)
0.055(1.40)
0.047(1.20)
SOD-323
0.008(0.20)
Mechanical data
• Epoxy:UL94-V0 rated flame retardant
• Case : Molded plastic, SOD-323
• Terminals : Solder plated, solderable per
0.003(0.08)
0.039(1.00)
0.031(0.80)
0.108(2.75)
0.096(2.45)
MIL-STD-750, Method 2026
• Polarity : Indicated by cathode band
• Mounting Position : Any
Dimensions in inches and (millimeters)
Maximum ratings (at T =25 C unless otherwise noted)
o
A
PARAMETER
CONDITIONS
Symbol
Forward voltage
I F = 10 mA
Power dissipation
T A=25 ° C ( note 1)
PD
Thermal resistance
Junction to ambient (note 1)
Junction to case (note 1)
R θJA
R θJC
MIN.
TYP.
VF
Operating junction temperature range
Storage temperature range
MAX.
UNIT
0.9
V
200
mW
o
625
350
o
C/W
C/W
TJ
-55
+150
o
C
T STG
-55
+150
o
C
Note 1: Mounted on FR-4 minimum pad
www.fuxinsemi.com
Page 1
Ver2.1
BZT52CxxxS Series
Diodes - 2.4V-51V
Electrical characteristics (at T =25 C unless otherwise noted)
o
A
Zener
voltage
Part No.
Marking
code
Test
current
Zener
impedance
Leakage
current
Typical Temperature
Typical Coefficent
V Z @ I ZT
I ZT
Z ZT @ I ZT
Z ZK @ I ZK
I ZK
IR
VR
Min.(V) Nom.(V) Max.(V)
mA
(Ω)Max
(Ω)Max
mA
(uA)Max
Volts
@ I ZT
O
(mV/ C)
BZT52C2V4S
WX
2.2
2.4
2.6
5
100
600
1.0
50.0
1.0
-3.5
BZT52C2V7S
W1
2.5
2.7
2.9
5
100
600
1.0
20.0
1.0
-3.5
BZT52C3V0S
W2
2.8
3.0
3.2
5
95
600
1.0
10.0
1.0
-3.5
BZT52C3V3S
W3
3.1
3.3
3.5
5
95
600
1.0
5.0
1.0
-3.5
BZT52C3V6S
W4
3.4
3.6
3.8
5
90
600
1.0
5.0
1.0
-3.5
BZT52C3V9S
W5
3.7
3.9
4.1
5
90
600
1.0
3.0
1.0
-3.5
BZT52C4V3S
W6
4.0
4.3
4.6
5
90
600
1.0
3.0
1.0
-3.5
BZT52C4V7S
W7
4.4
4.7
5.0
5
80
500
1.0
3.0
2.0
-3.5
0.2
BZT52C5V1S
W8
4.8
5.1
5.4
5
60
480
1.0
2.0
2.0
-2.7
1.2
BZT52C5V6S
W9
5.2
5.6
6.0
5
40
400
1.0
1.0
2.0
-2.0
2.5
BZT52C6V2S
WA
5.8
6.2
6.6
5
10
150
1.0
3.0
4.0
0.4
3.7
BZT52C6V8S
WB
6.4
6.8
7.2
5
15
80
1.0
2.0
4.0
1.2
4.5
BZT52C7V5S
WC
7.0
7.5
7.9
5
15
80
1.0
1.0
5.0
2.5
5.3
BZT52C8V2S
WD
7.7
8.2
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
BZT52C9V1S
WE
8.5
9.1
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
BZT52C10S
WF
9.4
10
10.6
5
1.0
0.2
7.0
4.5
8.0
BZT52C11S
WG
10.4
11
11.6
5
1.0
0.1
8.0
5.4
9.0
BZT52C12S
WH
11.4
12
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
BZT52C13S
WI
12.4
13
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
BZT52C15S
WJ
13.8
15
15.8
5
30
200
1.0
0.1
10.5
9.2
13.0
BZT52C16S
WK
15.3
16
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
BZT52C18S
WL
16.8
18
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
BZT52C20S
WM
18.8
5
55
225
1.0
0.1
14.0
14.4
18.0
BZT52C22S
WN
20.8
22
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
BZT52C24S
WO
22.8
24
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
BZT52C27S
WP
25.1
27
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
BZT52C30S
WQ
28.0
30
32.0
2
80
300
0.5
0.1
21.0
24.4
29.4
BZT52C33S
WR
31.0
33
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
BZT52C36S
WS
34.0
36
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
BZT52C39S
WT
37.0
39
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
BZT52C43S
WU
40.0
43
46.0
2
100
700
1.0
0.1
32.0
10.0
12.0
BZT52C47S
WV
44.0
47
50.0
2
100
750
1.0
0.1
35.0
10.0
12.0
BZT52C51S
WW
48.0
51
54.0
2
100
750
1.0
0.1
38.0
10.0
12.0
Note:
1. Tested with pulses, period = 5ms, pulse width = 300us.
2. When provided, otherwise, parts are provided with date code only, and type number identifications appears on reel only.
3. f=1KHz.
www.fuxinsemi.com
Page 2
Ver2.1
BZT52CxxxS Series
Diodes - 2.4V-51V
Rating and characteristic curves
FIG.1-EFFECT OF ZENER VOLTAGE ON
ZENER IMPEDANCE
FIG. 2-TYPICAL FORWARD VOLTAGE
1000
1000
I F, FORWARD CURRENT (mA)
Z ZT, DYNAMIC IMPEDANCE( Ω )
T J = 25 OC
I Z(AC) = 0.1 I Z(DC)
f = 1kHz
100
I Z = 1mA
5mA
10
100
O
150 C
10
O
75 C
1.0
O
0 C
1.0
10
3.0
80
0.4
0.5
0.7
0.6
V Z, NOMINAL ZENER VOLTAGE (V)
0.8
0.9
1.0
FIG. 3-TYPICAL CAPACITANCE
FIG. 4-TYPICAL LEAKAGE CURRENT
1000
0V BIAS
1V BIAS
100
BIAS AT
50% OF VZ NOM
10
100
I R, LEAKAGE CURRENT (uA)
T A = 25 OC
10
1.0
O
+150 C
0.1
0.01
+25 OC
0.001
0.0001
1.0
O
-55 C
0.00001
10
4.0
70
40
50
70
60
FIG. 5-ZENER VOLTAGE VERSUS ZENER CURRENT
(V Z UP TO 12V)
FIG. 6-ZENER VOLTAGE VERSUS
ZENER CURRENT(12V TO 75V)
100
100
O
O
T A = 25 C
I Z, ZENER CURRENT (mA)
T A = 25 C
1.2
1.1
V F, FORWARD VOLTAGE (V)
1000
C J , CAPACITANCE(pF)
O
25 C
10
1
0.1
0.01
10
1
0.1
0.01
4
6
8
10
12
10
V Z, ZENER VOLTAGE (V)
30
50
70
90
FIG. 7-STEADY STATE POWER DERATING
POWER DISSIPATION (%)
100
80
60
40
50
75
100
125
150
O
AMBIENT TEMPERATURE ( C)
www.fuxinsemi.com
Page 3
Ver2.1
BZT52CxxxS Series
Diodes - 2.4V-51V
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Suggested solder pad layout
C
A
B
www.fuxinsemi.com
PACKAGE
A
B
C
SOD-323
0.033 (0.83)
0.025 (0.63)
0.063 (1.60)
Page 4
Ver2.1
BZT52CxxxS Series
Diodes - 2.4V-51V
Suggested thermal profiles for soldering processes
1.Storage environment: Temperature=5 oC ~40 oC Humidity=55%±25%
2.Reflow soldering of surface-mount devices
Critical Zone
TL to TP
Tp
TP
Ramp-up
TL
TL
Tsmax
Temperature
Tsmin
tS
Preheat
Ramp-down
25
o
t25 C to Peak
Time
3.Reflow soldering
Profile Feature
Soldering Condition
Average ramp-up rate(T L to T P )
o
很抱歉,暂时无法提供与“BZT52C5V6S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.05888
- 50+0.05446
- 200+0.05078
- 600+0.04710
- 1500+0.04416
- 3000+0.04232
- 国内价格
- 50+0.06033
- 500+0.04718
- 3000+0.03603
- 6000+0.03169
- 24000+0.02787
- 51000+0.02586
