ESD9L5.0ST5G-N
ESD Protection Diode
»Features
45Watts peak pulse power (tp = 8/20μs)
Tiny DFN1006 package
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=0.6pF typ.)
Protection one data/power line
IEC 61000-4-2 ±10kV contact ±15kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 3A(8/20μs)
»Applications
»Mechanical Data
Cell Phone Handsets andAccessories
DFN1006 package
Microprocessor based equipment
Molding compound flammability rating: UL 94V-0
Personal Digital Assistants (PDA’s)
Packaging: Tape and Reel
Notebooks, Desktops, and Servers
RoHS/WEEE Compliant
Portable Instrumentation
»Schematic & PIN Configuration
DFN1006
Revision 2018
www.born-tw.com
1/4
ESD9L5.0ST5G-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
45
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
3
A
VESD
15
10
kV
Lead SolderingTemperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
StorageTemperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2(Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Conditions
Typical
VRWM
VBR
IT=1mA
Reverse LeakageCurrent
IR
VRWM=5V,T=25℃
Peak Pulse Current
IPP
Clamping Voltage
Junction Capacitance
Reverse BreakdownVoltage
Min
6.0
Max
Units
5.0
V
7.5
V
0.1
0.5
μA
tp =8/20μs
3
A
VC
IPP=3A,tp=8/20μs
13
V
Cj
VR = 0V, f =1MHz
0.9
pF
0.6
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
IPP
Maximum Reverse Peak PulseCurrent
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IF
Working Peak ReverseVoltage
Maximum Reverse Leakage Current @ VRWM
VC VBR VRWM
Breakdown Voltage @ IT
IR V F
IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
ESD9L5.0ST5G-N
»TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
100
Percent of Rated Power for I pp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
1
45w 8/20µswaveform
0.1
0.010.1
1
10
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Ipp
80
Percent
100
e-1
50
40
td=Ipp/2
10
Revision 2018
10
15
150
16
14
12
10
Test
Waveform
Paramters
tr=8µs
td=20µs
8
6
4
18
Clamping Voltage–VC (V)
90
Waveform
Paramters
tr=8µs
td=20µs
100
30
50
Figure 4: Clamping Voltage vs.Ipp
110
60
25
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
70
Time (µs)
30
2
2
3
4
5
6
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
ESD9L5.0ST5G-N
»Outline Drawing – DFN1006
»Marking
UB
»Ordering information
Order code
ESD9L5.0ST5G-N
Revision 2018
Package
DFN1006
Base qty
10k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“ESD9L5.0ST5G-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16820
- 1000+0.11830
- 4000+0.10761
- 10000+0.08524
- 国内价格
- 1+0.45100
- 500+0.15070
- 5000+0.10043
- 10000+0.08228
- 国内价格
- 20+0.18350
- 200+0.14850
- 600+0.12906
- 2000+0.11740
- 10000+0.09299
- 20000+0.08748
