ESD9B3.3ST5G-N
ESD Protection Diode
»Features
80Watts peak pulse power (tp = 8/20μs)
Tiny DFN1006 package
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±15kV contact ±25kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 10A (8/20μs)
»Applications
»Mechanical Data
Cell Phone Handsets and Accessories
DFN1006 package
Microprocessor based equipment
Molding compound flammability rating: UL 94V-0
Personal Digital Assistants (PDA’s)
Packaging: Tape and Reel
Notebooks, Desktops, and Servers
RoHS/WEEE Compliant
Portable Instrumentation
»Schematic & PIN Configuration
DFN1006
Revision 2018
www.born-tw.com
1/4
ESD9B3.3ST5G-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
80
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
10
A
VESD
25
15
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=3.3V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
Clamping Voltage1)
VCL
IPP=16A,tp=100ns
Clamping Voltage 2)
Max
Units
3.3
V
3.8
V
0.1
0.2
μA
10
A
8
V
IPP=5A,tp=8/20μs
6
V
IPP=10A,tp=8/20μs
8
V
VC
Clamping Voltage 2)
Dynamic resistance 1)
RDYN
Junction Capacitance
Cj
Ω
0.2
VR = 0V, f = 1MHz
15
12
pF
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
I PP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ I PP
V RWM
IR
V BR
IT
I
Parameter
Working Peak Reverse Voltage
V
Maximum Reverse Leakage Current @ V RWM
Breakdown Voltage @ IT
Test Current
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
ESD9B3.3ST5G-N
»Typical Characteristics
Figure 2: Power Derating Curve
10
110
1
80w 8/20µ s waveform
0.1
0.01
0.1
1
10
100
Percent of Rated Power for Ipp
P pp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
Waveform
Paramters
tr=8µs
td=20µs
90
Percent
Ipp
80
e
50
40
td=Ipp/2
150
8
-1
30
100
9
Clamping Voltage–VC (V)
100
60
75
Figure 4: Clamping Voltage vs.Ipp
110
70
50
Ambient Temperature - TA (℃)
7
6
5
4
Test
Waveform
Paramters
tr=8µs
td=20µs
3
2
1
10
Revision 2018
5
10
15
Time (µs)
30
4
6
8
10
12
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
ESD9B3.3ST5G-N
»Outline Drawing – DFN1006
»Marking
Pin 1
3E
Pin 2
»Ordering information
Order code
ESD9B3.3ST5G-N
Revision 2018
Package
DFN1006
Base qty
10k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“ESD9B3.3ST5G-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.37840
- 500+0.12540
- 5000+0.08404
- 10000+0.06886
- 国内价格
- 20+0.17820
- 200+0.14321
- 600+0.12377
- 2000+0.11211
- 10000+0.09299
- 20000+0.08748
- 国内价格
- 20+0.15819
- 1000+0.10435
- 4000+0.09281
- 10000+0.07394
