ESD5Z7.0T1G
ESD5Z7.0T1G
    BORN(伯恩)
    SOD-523(SC-79)
    1线单向TVS二极管VRWM=7V SOD-523 100pF VC=25V IPP=15A PPK=400W
ESD5Z7.0T1G 数据手册
ESD5Z7.0T1G-N ESD Protection Diode »Features ■ 400Watts peak pulse power (tp = 8/20μs) ■ Unidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±8kV contact ±15kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 15A (8/20μs) »Applications »Mechanical Data ■ Microprocessor based equipment ■ SOD523 package ■ Personal Digital Assistants (PDA’s) ■ Molding compound flammability rating: UL 94V-0 ■ Notebooks, Desktops, and Servers ■ Packaging: Tape and Reel ■ Portable Instrumentation ■ RoHS/WEEE Compliant ■ Pagers Peripherals »Schematic & PIN Configuration SOD-523 Revision 2018 www.born-tw.com 1/4 ESD5Z7.0T1G-N »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs) PPP 400 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 15 A VESD 15 8 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) »Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Reverse Breakdown Voltage Conditions Min Typical VRWM Max Units 7.0 V VBR IT=1mA 8.0 V Reverse Leakage Current IR VRWM=7V,T=25℃ 1 uA Clamping Voltage VC IPP=15A,tp=8/20μs 25 V Junction Capacitance Cj VR = 0V, f = 1MHz 100 pF »Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter I PP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ I PP V RW M IR V BR IT I IF Working Peak Reverse Voltage Maximum Reverse Leakage Current @ V RW M VC VBR VRWM IR VF IT Breakdown Voltage @ IT V Test Current IPP Note:. 8/20μs pulsewaveform. Revision 2018 www.born-tw.com 2/4 ESD5Z7.0T1G-N »Typical Characteristics Figure 1: Peak Pulse Power vs. Pulse Time Figure 2: Power Derating Curve 110 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) 10 400w 8/20µs waveform 1 0.1 0.01 0.1 1 10 100 100 90 80 70 60 50 40 30 20 10 0 1,000 td – Pulse Duration - µs 90 Ipp 80 Percent 100 125 150 Test Waveform Paramters tr=8µs td=20µs 40 Clamping Voltage–VC (V) 100 e-1 50 40 td=Ipp/2 20 75 45 Waveform Paramters tr=8µs td=20µs 30 50 Figure 4: Clamping Voltage vs.Ipp 110 60 25 Ambient Temperature - TA (℃) Figure3: Pulse Waveform 70 0 35 30 25 20 15 10 5 10 0 0 5 Revision 2018 10 15 Time (µs) 20 25 30 0 5 10 15 20 25 Peak Pulse Current–IPP (A) www.born-tw.com 3/4 ESD5Z7.0T1G-N »Outline Drawing – SOD523 D -X-YE 1 DIMENSIONS 2 SYMBOL b 2x 0.08 (0.0032) X A b C D E HE L Y A C HE L MILLIMETER INCHES MIN MAX MIN MAX 0.50 0.25 0.07 1.10 0.70 1.50 0.15 0.70 0.35 0.20 1.30 0.90 1.70 0.25 0.020 0.010 0.0028 0.043 0.028 0.059 0.006 0.028 0.014 0.0079 0.051 0.035 0.067 0.010 »Marking 1 7U 2 »Ordering information Order code ESD5Z7.0T1G-N Revision 2018 Package Base qty Delivery mode SOD523 5000 Tape and reel www.born-tw.com 4/4
ESD5Z7.0T1G 价格&库存
很抱歉,暂时无法提供与“ESD5Z7.0T1G”相匹配的价格&库存,您可以联系我们找货
ESD5Z7.0T1G
    • 1+0.44660
    • 500+0.14960
    • 2500+0.09911
    • 5000+0.08129
    库存:4840
    ESD5Z7.0T1G
    • 1+0.08820
    • 10+0.08470
    • 100+0.07630
    • 500+0.07210
    库存:2354
