PESD5V0S2BT
ESD Protection Diode Array
»Features
300 Watts peak pulse power (tp = 8/20μs)
Bidirectional and unidirectionalconfigurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=120 pF typ.)
Protection two data lines
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 20A(8/20μs)
»Mechanical Data
»Applications
Dataline
SOT-23 package
Automatic Teller Machines
Molding compound flammability rating: UL 94V-0
Net works
Packaging: Tape and Reel
Power line
RoHS/WEEE Compliant
»Schematic & PIN Configuration
1
1
3
3
2
2
SOT-23 (Top View)
Revision 2018
www.born-tw.com
1/4
PESD5V0S2BT
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
300
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
A
VESD
30
30
kV
Lead SolderingTemperature
TL
260(10seconds)
JunctionTemperature
TJ
-55 to + 125
StorageTemperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2(Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-OffVoltage
Conditions
Min
Typical
Max
Units
5
V
7.0
8.5
V
0.5
1
μA
VRWM
VBR
IT=1mA
Reverse LeakageCurrent
IR
VRWM=5V,T=25℃
Peak PulseCurrent
IPP
tp =8/20μs
A
IPP=10A,tp=8/20μs
12
V
IPP=20A,tp=8/20μs
16
V
Reverse BreakdownVoltage
6.0
VC
Clamping Voltage
Cj
JunctionCapacitance
VR = 0V, f =1MHz
(pin1、pin2 to pin3)
120
pF
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RW M
IR
V BR
IT
I
IF
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RW M
VC VBR VRWM
IR V F
IT
Breakdown Voltage @ IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PESD5V0S2BT
»TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
100
Percent of Rated Power for Ipp
P pp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
300w 8/20μs waveform
1
0.1
0.01
0.1
1
10
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
90
Percent
Ipp
80
e-1
50
40
td=Ipp/
2
125
150
18
Clamping Voltage–VC (V)
100
30
75
Waveform
Paramters
tr=8µs
td=20µs
60
50
Ambient Temperature - TA (℃)
Figure 4: Clamping Voltage vs.Ipp
110
70
25
14
12
Test
Waveform
Paramters
tr=8µs
td=20µs
10
8
6
4
10
Revision 2018
10
15
Time (µs)
30
2
3
4
5
6
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
PESD5V0S2BT
»Outline Drawing – SOT-23
DIMENSIONS
D
SYMBOL
θ
1
L
0.25
2
e
MIN
MAX
MIN
MAX
0.900
1.150
0.035
0.045
A1
0.000
0.100
A2
0.900
1.050
0.035
0.041
D
2.800
3.000
0.110
0.118
A2
0.000
0.004
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
A
INCHES
A
3
E1 E
MILLIM ETER
0.950 BSC
0.037 BSC
L
0.300
0.500
0.012
0.020
θ
8○
A1
»Ordering information
Order code
PESD5V0S2BT
Revision 2018
Package
SOT-23
Base qty
3k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“PESD5V0S2BT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.47855
- 100+0.39042
- 300+0.34636
- 3000+0.24992
- 6000+0.22346
- 9000+0.21028
- 国内价格
- 10+0.44006
- 100+0.35927
- 600+0.31888
- 1200+0.31410
- 3000+0.23047
- 国内价格
- 1+0.45320
- 200+0.29260
- 1500+0.25520
- 3000+0.22550
