PESD8V0L2BT-N
ESD Protection Diode Array
»Features
350 Watts peak pulse power (tp =8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kVair
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 15A(8/20μs)
»Applications
Dataline
Automatic Teller Machines
Net works
Power line
»Mechanical Data
SOT-23 package
Molding compound flammability rating: UL 94V-0
Packaging: Tape and Reel
RoHS/WEEE Compliant
»Schematic & PIN Configuration
1
1
3
3
2
2
SOT-23 (Top View)
Revision 2018
www.born-tw.com
1/4
PESD8V0L2BT-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
350
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
15
A
VESD
30
30
kV
Lead SolderingTemperature
TL
260(10seconds)
JunctionTemperature
TJ
-55 to + 125
StorageTemperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2(Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-OffVoltage
Conditions
Min
Typical
Max
Units
8
V
10
12
V
0.1
0.5
μA
VRWM
VBR
IT=1mA
Reverse LeakageCurrent
IR
VRWM=8V,T=25℃
Peak PulseCurrent
IPP
tp =8/20μs
15
A
Clamping Voltage
VC
IPP=15A,tp=8/20μs
18
V
JunctionCapacitance
Cj
VR = 0V, f =1MHz
(Pin1、Pin2 to Pin3)
45
pF
Reverse BreakdownVoltage
9
40
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RW M
IR
V BR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RW M
VC VBR VRWM
IT
IR
IR
IT
Breakdown Voltage @ IT
VRWM VBR VC
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PESD8V0L2BT-N
»TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
300w 8/20 sµaveform
1
0.1
0.01
0.1
1
10
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
Waveform
Paramters
tr=8µs
td=20µs
90
Percent
Ipp
80
50
40
td=Ipp/
2
150
e-1
30
100
18
Clamping Voltage–VC (V)
100
60
75
Figure 4: Clamping Voltage vs.Ipp
110
70
50
Ambient Temperature - TA (℃)
10
16
12
10
8
Test
Waveform
Paramters
tr=8µs
td=20µs
6
4
2
Revision 2018
10
15
Time (µs)
30
10
15
30
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
PESD8V0L2BT-N
»Outline Drawing – SOT-23
DIMENSIONS
D
SYMBOL
3
E1 E
θ
1
b
L
0.25
2
e
INCHES
MIN
MAX
MIN
MAX
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
A2
0.900
1.050
0.000
0.035
0.004
0.041
D
2.800
3.000
0.110
0.118
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
A
A2
MILLIM ETER
0.950 BSC
0.037 BSC
L
0.300
0.500
0.012
0.020
θ
8○
A1
»Marking
8B2
»Ordering information
Order code
PESD8V0L2BT-N
Revision 2018
Package
SOT-23
Base qty
3k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“PESD8V0L2BT-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.56819
- 50+0.46451
- 150+0.41267
- 500+0.37379
- 3000+0.29646
- 6000+0.28091
- 国内价格
- 1+0.48730
- 200+0.31460
- 1500+0.27390
- 3000+0.24200
- 国内价格
- 1+0.42300
- 100+0.39480
- 300+0.36660
- 500+0.33840
- 2000+0.32430
- 5000+0.31584
