PESD5V0U1UT-N
ESD Protection Diode Array
»Features
60 Watts peak pulse power (tp = 8/20μs)
Bidirectional and unidirectionalconfigurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=0.7 pF typ.)
Protection two data lines
IEC 61000-4-2 ±15V contact ±15kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 3.5A (8/20μs)
»Mechanical Data
»Applications
Dataline
SOT-23 package
Automatic Teller Machines
Molding compound flammability rating: UL 94V-0
Net works
Packaging: Tape and Reel
Power line
RoHS/WEEE Compliant
»Schematic & PIN Configuration
1
1
3
3
2
2
SOT-23 (Top View)
Revision 2018
www.born-tw.com
1/4
PESD5V0U1UT-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
60
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
3.5
A
VESD
15
15
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Conditions
Min
Typical
Max
Units
5
V
7
8
V
0.5
1
μA
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=5V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
3.5
A
Clamping Voltage
VC
IPP=3.5A,tp=8/20μs
17
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
0.8
pF
Reverse Breakdown Voltage
6
0.7
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RWM
IR
V BR
IT
I
IF
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC VBR VRWM
Breakdown Voltage @ IT
IR V F
IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PESD5V0U1UT-N
»TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
1
60w 8/20µswaveform
0.1
0.010.1
1
10
100
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
90
80
70
60
50
40
30
td – Pulse Duration - µs
90
Ipp
80
Percent
100
125
150
18
Clamping Voltage–VC (V)
100
e
-1
50
40
td=Ipp/2
Waveform
Paramters
tr=8µs
td=20µs
30
50
Figure 4: Clamping Voltage vs.Ipp
110
60
25
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
70
14
12
Test
Waveform
Paramters
tr=8µs
td=20µs
10
8
6
4
10
2
Revision 2018
10
15
Time (µs)
30
2
3
4
5
6
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
PESD5V0U1UT-N
»Outline Drawing – SOT-23
DIMENSIONS
D
SYMBOL
θ
1
L
250.
2
e
MIN
MAX
MIN
MAX
0.900
1.150
0.035
0.045
A1
0.000
0.100
A2
0.900
1.050
0.035
0.041
D
2.800
3.000
0.110
0.118
A
0.000
0.004
b
0.300
0.500
0.012
0.020
E
2.250
2.550
0.089
0.100
E1
1.200
1.400
0.047
0.055
e
A2
INCHES
A
3
E1 E
MILLIMETER
0.950 BSC
0.037 BSC
L
0.300
0.500
0.012
0.020
θ
8○
A1
»Marking
5ML
»Ordering information
Order code
PESD5V0U1UT-N
Revision 2018
Package
SOT-23
Base qty
3k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“PESD5V0U1UT-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30600
- 50+0.28440
- 200+0.26640
- 600+0.24840
- 1500+0.23400
- 3000+0.22500
- 国内价格
- 10+0.28415
- 100+0.22713
- 300+0.19862
- 3000+0.17280
- 6000+0.15563
- 9000+0.14710
