PESD5V0U1BL-N
ESD Protection Diode
»Features
40Watts peak pulse power (tp = 8/20μs)
Tiny DFN1006 package
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=2.7pF typ.)
Protection one data/power line
IEC 61000-4-2 ±10kV contact ±15kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 3.0A (8/20μs)
»Applications
»Mechanical Data
Cell Phone Handsets and Accessories
DFN1006 package
Microprocessor based equipment
Molding compound flammability rating: UL 94V-0
Personal Digital Assistants (PDA’s)
Packaging: Tape and Reel
Notebooks, Desktops, and Servers
RoHS/WEEE Compliant
Portable Instrumentation
»Schematic & PIN Configuration
DFN1006
Revision 2018
www.born-tw.com
1/4
PESD5V0U1BL-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
40
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
3.0
A
VESD
15
10
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=5V,T=25℃
Peak Pulse Current
IPP
Clamping Voltage
Junction Capacitance
5.5
Max
Units
5.0
V
6.5
V
0.1
0.5
μA
tp =8/20μs
3.0
A
VC
IPP=3.0A,tp=8/20μs
12
V
Cj
VR = 0V, f = 1MHz
3.5
pF
2.7
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC V BR
V RWM
IT
IR
ITIR
VRWM
V BR V C
V
Breakdown Voltage @ IT
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
PESD5V0U1BL-N
»TypicalCharacteristics
Figure 2: Power Derating Curve
10
110
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
1
40w 8/20 sµaveform
0.1
0.01
0.1
1
10
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
Waveform
Paramters
tr=8µs
td=20µs
90
Percent
Ipp
80
e-1
50
40
30
td=Ipp/2
10
5
Revision 2018
10
15
150
16
14
12
10
8
Test
Waveform
Paramters
tr=8µs
td=20µs
6
4
2
18
Clamping Voltage–VC (V)
100
60
75
Figure 4: Clamping Voltage vs.Ipp
110
70
50
Ambient Temperature - TA (℃)
Time (µs)
30
2
3
4
5
6
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
PESD5V0U1BL-N
»Outline Drawing – DFN1006
»Marking
VB
»Ordering information
Order code
PESD5V0U1BL-N
Revision 2018
Package
DFN1006
Base qty
10k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“PESD5V0U1BL-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12682
- 1000+0.10009
- 4000+0.08524
- 10000+0.07633
- 国内价格
- 1+0.32120
- 500+0.10692
- 5000+0.07117
- 10000+0.05841
- 国内价格
- 50+0.13835
- 500+0.10919
- 1500+0.09299
- 10000+0.08327
- 20000+0.07485
- 50000+0.07020
