SI2301
SI2301
    BORN(伯恩半导体)
    SOT-23
    MOSFETs P-Channel SOT-23
SI2301 数据手册
SI2301-P MOSFET P-Channel MOSFET ROHS SOT-23 - Features  Advanced trench process technology  High Density Cell Design For Ultra Low On-Resistance Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Symbol Limit Drain-Source Voltage VDS -20 Gate-Source Voltage VGS ±10 ID -3 IDM -10 Continuous Drain Current Pulsed Drain Current 1) Maximum Power Dissipation TA = 25o 2) o TA = 75 C Junction-to-Ambient Thermal Resistance (PCB mounted) W o -55 to 150 C 100 RthJA 3) A 0.8 2) Junction-to-Ambient Thermal Resistance (PCB mounted) V 1.25 PD TJ, Tstg Operating Junction and Storage Temperature Range Unit o C/W 166 Notes 1) Pulse width limited by maximum junction temperature. 2) Surface Mounted on FR4 Board, t v 5 sec. 3) Surface Mounted on FR4 Board. Electrical Characteristics ( Ratings at 25℃ ambient temperature unless otherwise specified). Parameter Symbol Test Condition Min. VGS = 0V, ID = -250uA -20 Typ. Max. Unit Static Drain-Source Breakdown Voltage BVDSS 1) Drain-Source On-State Resistance Gate Threshold Voltage R DS(on) VGS(th) Zero Gate Voltage Drain Current 0 IDSS VGS = -4.5V, ID = -3.0A 64 110 VGS = -2.5V, ID = -2.0A 89 140 mΩ VDS =VGS, ID = -250uA 0.4 Forward Transconductance 1) 1 VDS = -20V, V GS = 0V IGSS VGS = ± 10V, VDS = 0V gfs VDS = -5V, ID = -2.8A V -1 uA o VDS = -16V, V GS = 0V TJ=55 Gate Body Leakage V C -10 ±100 6.5 nA S Dynamic Total Gate Charge Gate-Source Charge Qg Qgs Gate-Drain Charge Qgd Turn-On Delay Time td(on) 5.8 VDS = -6V, ID ^ -2.3A 10 nC 0.85 VGS = -4.5V 1.7 13 25 36 60 42 70 34 60 VDD = -6V, RL=6Ω Turn-On Rise Time tr Turn-Off Delay Time td(off) Turn-Off Fall Time tf Input Capacitance Ciss ID ^ -1.A, VGEN = -4.5V RG = 6 Ω ns 415 VDS = -6V, VGS = 0V Output Capacitance pF 223 Coss f = 1.0 MHz Reverse Transfer Capacitance 87 Crss Source-Drain Diode Max. Diode Forward Current Diode Forward Voltage 1) IS VSD IS = -1.0A, VGS = 0V -0.8 -1.6 A -1.2 V Pulse test: pulse width
SI2301 价格&库存
很抱歉,暂时无法提供与“SI2301”相匹配的价格&库存,您可以联系我们找货
SI2301
库存:3241
SI2301
  • 50+0.20050
  • 500+0.16580
  • 3000+0.12070
  • 6000+0.10910
  • 24000+0.09910
  • 51000+0.09370
库存:11846
SI2301
  • 1+0.57200
  • 200+0.19030
  • 1500+0.11880
  • 3000+0.09460
库存:34334
SI2301
    • 20+0.18543
    • 300+0.15335
    • 1200+0.15105
    • 3000+0.11167
    库存:4415
    SI2301
    • 50+0.20229
    • 500+0.16730
    • 3000+0.12183
    • 6000+0.11016
    • 24000+0.10001
    • 51000+0.09461
    库存:28700
